MartinFahrer
    163
Everything posted by MartinFahrer
  1. Well peter I was on 8 hours straight WASTING a days pay getting it sorted out. Still issues, like having to resize class drop down menu every time you open a file, extra steps. Went to edit drawing stamp today and an extra step was added in order to make a custom stamp = MORE TIME WASTED. Anyone know if Auto Cad has these issues?
  2. I don' know. Took me $8 hours to get 2024 to look more like 2023 menu bar as far as icons together. Some one should let Vworks know we care more about efficient DRAWING tha lights on truss and how much tie line is needed. I sure hope they don't waste time on how many sheets of luan for a flat. If that happens I need to find a different drafting program geared toward DESIGNING.
  3. Trying to marque multiple objects to delete them. marque doesn't show up and no objects selected. After hours of failure i opened 2023 and was able to do it first time and easily. Productivity slowed down to a snails pace ever since "upgrading" to 2024. Used to be a big supporter of the program, wuth 2024 you guys screwed the pooch. drafying in 2023 now and looking for alternate programs.
  4. This has been a problem since 2011 or so. When using multiple screens the various palettes will jump around, be glitchy and otherwise nit behave. Personally I would rather have that fixed than icons changed from color to black and whit, or revamping and messing up the user interface like you did for 2024.
  5. Was wondering/ requesting if Vectorworks for iPad. Maybe even a light version to edit/ review 2d drafting. thanks
  6. I don't know how many times I have gone to change the width of the object and somehow unintentionally hit the use material box. Its annoying. Thanks
  7. Anyone notice or have had issues with snapping just not working? No I am not talking about accidentally hitting the snapping suspend button. It happens between view ports or when I am referencing in another drawing. I have to restart and it works fine. am I the only one??
  8. I noticed recently when I Import a DWG into a current Vectorworks drawing & or Reference to another VW file that I am running into a bug. The program will lock up and crash. I also wonder if it's a issue maybe with auto back up running in the background. When it locks up often it is when I m trying to edit the title block I try to double click to get the setting to come up and nothing. I see the viewport is selected but there is no data showing in the object info bar. If I don't crash I have to close and re open the program. This has been happening multiple times a work day and is KILLING my workflow and efficiency. Any thoughts?
  9. UPDATE: @JuanP Still no solution found. It is a consistent repeatable error. I have found out it is only when exporting a sheet layers or multiple sheet layer. I export too the design layer to DWG works fine. I also exported as several different file types with out a problem including EPSF and PDF etc. I am pretty sure that it's not a graphic display driver. After uninstalling and reinstalling, as well as downgrading the video driver to the same results. I used DDU to delete all of my video drivers at go back to "Microsoft basic driver" Still the same results. Open Vectorworks/ open Vectorworks file/ Export DWG as a sheet/. I also Opened my older copy of Vectorworks 2021. and no issues exporting at all. That trouble shooting I'm sure it's a Vectorworks 2022 problem. I did uninstall and reinstall Vectorworks, importing all my custom settings. Going to try and do a clean intall with out my settings and see if that works.
  10. Yes but this didn't start a month ago, but two days ago and Vectorworks is a daily used program.
  11. Except this is a brand new problem and I have been using Vectorworks on this computer for a while. My computer is not being "Taxed" that is for sure, not with the processor etc I have on board.
  12. Here are some photos and a video of what happens https://www.dropbox.com/s/058e13vw8b2t022/2022-05-27 17.50.59.mov?dl=0
  13. Before blaming anything else, I opened, saved, ran and exported all other programs on my PC including Sketchup, Ai, PS and some others. Nothing happened but ewhen I do the following in V works text on screen disapears Open Vectorworks/ open Vectorworks file/ Export DWG/ The save bar goes funky and I can't see text in explorer. I will attach photos of occurrence this evening can't do a screen capture. Yes I turned it on and back off again, yes I uninstralled and reinstalled vectorworks. Attached are machine specs
  14. Doing a nine light window pane that has 1/2" EQ spaced muntins. I was going to use the 1/2" double line set to polygons and over lap them using equal spacing. I then wanted to trim all the intersections out WITHOUT using the cut tool. I have done this before I thought using <Modify> clip to surface or add surface. It literally took two steps. Now I am trying it again and don't know if the function isn't the same in 2021 or if I am just doing it in the wrong order.
  15. After the update this starts happening. Rotating horizontally or vertically places object at the other side of the drawing. Anyone else have this issue?
  16. Can you screen shot where "Edit design Layer" box is? I have been looking for it when I am editing the design view port and also in the OIP with viewport selectred. Just not finding the box to uncheck.
  17. The gang on phone support have always been fantastic and knowledgeable. I have happily re subscribed every year so I can have premium technical support, I don't mind that at all. Here is my question. Today when I called in it went to VM saying leave my name and phone number and they will call me back in 24 hours. Did the premium tech support turn into a call back service, sometimes I don't have 24 hours to wait on a solution, did Vworks lay off tech support workers and now they can't handle the volume. I am hoping it was just an odd day of hi call volume and it isn't the way things are going to be for now on.
  18. I may be missing something here. A. - If I am in a view port and right click to go to my design layer. All other layers are now hidden by default. Is there a way to undo this so tired of taking the extra step righ click and show snap layers. I do this because I want to see my plan layer with my elevation layer when I work on them through a view port. B- In the 2021 reference marker (yes I know I can use legacy but hate the exclamation point with it makes me feel I am doing something wrong). How do I change styles of the marker from section, to detail, to elevation? they all have different arrows I use. Thanks for your help
  19. Agreed. not as bad as I feared once I learned the way they re did it. Pat Stanford: Yes you can use legacy to make a label but cant default legacy to default viewport label.
  20. So you took something that was easily customizable that NO ONE was complaining and made it more difficult to adjust font and sizes on the fly? WHY!?!?! and is there a way I can go back to the more customizable version?
  21. For some reason the original resource was created as nurbs instead of lines. I had to edit in the 3D objects. I basically Copied the nurbs, pasted into a document, converted to lines then composed. Finally saving the symbol. Just in case some one has the same problem.
  22. I have a moldings resource manager. Some I double click then on the third click I can place the resource in the drawing. Others I double click and Vworks places it seemingly randomly on the design layer. My question is there any way to edit the properties of placing a resource object on the design layer?
  23. True but if clients are looking at the software we use and think it's less than autocad, then the job will go to the person who is perceived to have the more professional program. It is about efficiency true but also about perception. Throwing the bathwater out for 1/3 at the most of the users is a mistake.
