skeyshubber
    45
Reputation
7 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
1,553 profile views
  1. I have placed an enscape plant asset in my design and the placeholder is not visible unless I hover my mouse over it or select it, then it becomes highlighted but there is still no line work. My layers and classes are turned on and visible. This is only the case in one project file I am working with. I am trying to figure out what setting is turned on or off to make this happen in this one file. The enscape plant behaves normally in another file.
  2. Weirdly enough, my program just crashed with the experimental plant placed in hedge mode.
  3. It didn't happen when I placed a different plant. When I place the experimental plant and check 'apply fill across plant grouping' my plants filled white. I've checked the geometry of the plant and made sure that the bottom layer is not white. Can you help me with this also? GUARD STREET TOWNHOMES.vwx
  4. I am experiencing an issue when I'm attempting to place a Laurel hedge. I'll place the plants in hedge mode and when I attempt to 'mass' them so I don't have so much busy line work my program stalls out requiring a reboot. What am I doing wrong?
  5. I have been using Globe Plants and Enscape for my renderings and love it! My question is.....Enscape w/VW is only compatible for low poly models. There seems to be a greater variety of high poly models available and usually the type/species that I want/need. Is there any way to utilize high poly models in VW or, better yet, is there a way VW can accept high poly models?
  6. Having the same issue! Whether I make it an auto hybrid or a symbol no fill, no texture, nothing. Super frustrating!
  7. Has there been a fix to this? It's happening to me as well and very very frustrating.
  8. Actually, I JUST solve the issue by inserting duplicate doors in each wall instance when in plan view. Found a workaround but seems like there should be a better way....
  9. This is exactly the issue I am trying to solve at the moment! I am building a model with a 36" concrete stem wall and timber framed wall from there on up. I can build the walls no problem but the door will only 'punch' through one wall. Help!
  10. Hi, This issue started yesterday afternoon after a few hours of working on a simple building with basic walls. One of the walls just disappeared and when I attempted to re-draw it with all of the same specifications that I had used earlier in the session the issues listed below began to occur. 1. When Show/Snap/Modify other classes is turned on all walls are able to be selected in both ISO and 2D Plan view. When Active Only classes are turned walls are able to be selected in ISO view only. 2. All walls that have been selected or edited in 2d top plan view begin to randomly disappear in ISO view with Active Only classes are turned on. 3. The newly drawn wall is unresponsive to height adjustments and the OIP reflects correct dimensions but the wall itself is still at 0' high in both Active Only and Show/Snap/Modify others class specifications. 4. When switching between Active Only and Show/Snap/Modify others the newly draw wall will suddenly land a different location at be 5000' long. I'd call it a ghost in the machine but i think it may be worse than that. macOS Catalina Version 10.15.5 4.2 GHz Quad-Core Intel Core i7 64 GB 2667 MHz DDR4 Radeon Pro 575 4 GB
  11. Hi Dave, It's a 2d object mimicking a ground plane. Stephanie
  12. Hi, I am encountering issues and inconsistent results when rendering my viewports. Attached is one viewport in openGL and the second in final quality RW. Any suggestions on what is causing the blocking out in some areas and the white square behind my human figures? Thanks
  13. Hi there, I am having inconsistent results when viewing hardscapes. The hardscape will disappear in open GL in both veiwports and design layer and when rendered an annoying red line appears. Any suggestions on what could be happening?
