2,863 -
Everything posted by Jeff Prince
Yes, Edit Subdivision, Add Edge. if the object has thickened, you’ll have to add an edge for each face, typically.
There are a lot of good ways to do this in VWX or Rhino, it depends on if you are documenting something that is already figured out or designing and developing the form. If the latter, SubD with iteration set to 0 is a quick and easy way to make these shapes. I find it best to use SubD when I'm designing something and sculpting it as I go since it's essentially a parametric mesh or digital clay. Iteration 0 keeps it planar, which works for @suz's project. The SubD editor has a provision for extruding, but I prefer to make a rectangle, extrude it, and convert it to a SubD. I can then add creases and combine vertices to create the form. It's easier if you break the shapes down into simple pieces and combine them rather than try to do an element as one continuous SubD. Although, it's possible to go crazy with them... https://forum.vectorworks.net/index.php?/topic/98446-subdivision-challenge/#comment-444459 I posted a bunch of useful information about Rhino SubD on this thread, if you ignore the naysayer. https://forum.vectorworks.net/index.php?/topic/107517-vectorworks-vs-rhino-3d-vs-home-depot/#comment-468312 It took me longer to write this post than to make the attached example, which is pretty typical with SubD 🙂
Turn it into a 3D face or extrude it. Then you can apply a texture to it.
What tool did you use to model the floor, aka, what type of object is it listed as in the OIP? generally, if you select your object and change it’s attributes to “byclass” you can use the class settings to control the graphics and textures. If it it a complex object, you might have to use component settings.
Is this possible with site modeling?
Jeff Prince replied to demetris ktorides's topic in Site Design
I guess the take away here is you can take your advice from people in the trenches that know how the tools work, or people who play with trenches and software that is not Vectorworks. Either way is viable, one is useful for achieving the stated goal.- 11 replies
@demetris ktorides That's why I provided the second technique. DTMs are really just a model of the top facing surface, the sides and bottoms are just provided as a frameworks to help depict the top surface. This might change in the future, but it's a good way to think about it in the mean time. So, if you actually need a DTM for the portion of the site that will sit over an irregular roof, you might want to use a similar technique to what I describe in this thread... The recommended deviation... use the DTM with out a skirt to represent the ground surface for the purpose of receiving plants and other DTM specific workflows. Also, where I mention export/import to AutoCAD, you can simply take a copy of the DTM and ungroup it to get the contours, which is a handy trick for a lot of things,I didn't know that in 2019 when that I wrote that post 🙂 Then, use the solid modeling tools tool to sculpt the volume you are interested in depicting which exists above the roof. This gives you the best of both worlds and allows you to calculate volumes above structure.- 11 replies
- 3
You can likely create a passable site model just using the data on following classes: Kaikki objektit StakeOutStringStructure_ StakeOutStringTopLevel_ This will get you pretty close to a good solution without any editing. Then you can can go in and delete the messes around the intersections and such, if required Adding the site data, which you have not provided, will fill in the areas between roads, presumably. Then, you can graphically depict the roads by convert the meshes representing the topmost surface to 2D polys. Once you have added those together, you could convert it to texture beds for mapping to the site model surface... depending on your desired workflow and outcome. Just the layers mentioned will produce something like this: Without editing, you get errors at the intersections, though it did a nice job with the swales along the roads and cuts into the presumed hillsides adjacent to the road. Converting the road meshes to polys and then to texture bed site modifiers will give the a semblance of a road pretty quickly. The same strategy could be used for the texture of the roadway cut slopes and swales to depict vegetation, cut stone, etc.
That's why I keep telling people to post a file... the solution jumps of the screen typically.
Simple solution to fill in empty space?
Jeff Prince replied to Michael Gillis's topic in Solids Modeling
You could draw a poly of the plan view shape of these two conditions and extrude those new shapes and Add the resulting solids. or You could push/pull the background shape forward and curved pieces backwards. Then, grab the resulting geometry and use Intersect to create geometry where the two occupy the same space. The latter should work, depending on how you created the geometry, but I think the former is a better method. -
You don't. Accessories only work on Roofs, not Roof Faces. See help menu and/or tutorials on the subject.
Nice wall @zoomer😉 Good catch @Tom W.
How you approach this depends on the desired end result. It's difficult to provide helpful guidance without knowing where your site is within this roadway context and what data you have to represent that surface. Based on your most recent post, it looks like you just want to add the roads for visual rendering purposes, not for construction documentation. Is that correct? When you look really close at this roadway data, there is a lot of conflicting geometry. The swales next the road for instance, their geometry is not valid where two roads intersect. Then there are problems with the road surfaces where they intersect, sometimes meeting at unequal camber. I would ask the roadway person for a point file representing the topmost surface of the areas of interest and then just map 2D graphics to the site model to texture the roads and related structures, assuming it's not that important.
Select the roof. Look at the OIP. Add the Roof accessories by hitting the appropriate button in the OIP.
Based on all the problems people have been having with 3DConnexion drivers, I wouldn't buy another one of their products until they start dealing with things in a timely fashion.
Or they could just post a file with the offending objects and the guessing game could come to a tidy conclusion 🙂
You can’t do an undercut or tunnel with the site modeling tools currently. However, you can use a trick to do it…. Use two different site models, one for the site and one for the fill. Alternatively, you can do one site model and then use object modeling tools to create the fill above. There are a ton of threads here on the forum about the topic if you need more ideas.- 11 replies
- 5
Best Practice for Importing Building Model into Site Model?
Jeff Prince replied to drock019's topic in Site Design
You are going to hear some varied opinions on that topic. I prefer to do it as you describe, building in one file which is then referenced into the site. I have not seen a tutorial that explains it, but in a nutshell.... Set up your building how you like, typically FF= 0' elevation, lower leftmost corner of the building at 0,0 Set you site up with correct georeferrencing of the location, best to coordinate with the surveyor and structural folks as to their preferred staking out method and coordinate system. Then, it's simply a reference of the building into the site. You can move the building around freely on the site that way without effecting your building drawings. Be sure to place it at the desired site elevation so it shows up correctly in sections and such. Back in the building file... If you like to have real world elevation on your building in section or elevation, you can make a data tag that adds real world elevation to measured and everything will be work nicely. Ask away if you have questions. -
You could use a Report and/or a Data Viz Legend Bonus, you could use a Data Visualization to color the cubes 🙂 I'm not sure how you could go about adding quantities to a Data Viz Legend though, I haven't done that yet and handle quantities with Reports typically. See if the attached VWX gets you going in the right direction. Maybe @Pat Stanford will chime in... cube vis.vwx
That doesn't seem right, you must have something set up incorrectly and it's hard to identify what that might be from the information provided. See attached VWX file for an example of how it should behave using very basic settings. renovation wall help.vwx
My pleasure, I had the time to give 🙂
Turbosquid models - textures not importing
Jeff Prince replied to ajemutt's question in Troubleshooting
@ajemutt I made a quick video which shows some of the difficulties one can run into when importing .obj models. It might be an hour or so before the HD and 4K videos are available on Youtube.... https://youtu.be/whCL5xvrLBk -
Did you watch the video I posted? Did you see where I imported the dwg, hit the "advanced" button, and made sure the Conversion settings were such that it Convert Object = 2D & 3D? This is what I am referring to. You gotta do some training man, the forum can only do so much for you.
Thanks for looking into it. Note, I tried turning a portion of the ribbon into a light fixture and made the other portions glow materials. I would like to learn more about lighting within Vectorworks, solving this lit fog effect would be really useful. spiral final-to forum.vwx
Simplifying a planting plan for construction documentation
Jeff Prince replied to Marcus bLD's topic in Site Design
Have you done the Landmark classes on Vectorworks University? -
@JHEarcht3 Here's a video showing the steps to import the .dwg you provided and the result. You'll note that the errors are not present in the .dwg and a few tricks for inspecting and cleaning these things up before building a site model... site model example.mp4
