82 -
Everything posted by Walter Lutzu
Yes, I can do the same also in box, but I wanted to try using the possibility to interact directly with the web 😉
Hi to everybody. Working in a big project where all the team is connected by BOX. I use a lot of referenced file, like DWG or PDF, working opening directy the vwx file from box. The problem is that I can reference only files saved on my PC and can't flag "path relative to current document". Any workaround?
Yes, I confirm. MVR from Vectorworks to Wysiwyg works very well if you start to design in Spotlight, also merging parts of the project. I never try from Wysiwyg to Vectorworks
Light beams of GDFT Fixtures in Vision 2020
Walter Lutzu replied to MarcoNJ's topic in Vision and Previsualization
Hello everybody! I've the same problem: fixture in a place and beam in another... Exported mvr from vw with gdtf mode. If I sent to vision all works well but I don't have the correct mode to set, this is why I choose mvr. see attached -
Thanks Klinzey!
yes, going to test installation on clean boot and other things. I'll keep you updated
here what I'm using Processors ------------------------------------------------------------------------- Number of sockets 1 Number of threads 12 Socket 1 ID = 0 Number of cores 6 (max 6) Number of threads 12 (max 12) Name Intel Core i7 8750H Codename Coffee Lake Specification Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz Memory Type DDR4 Memory Size 32 GBytes Channels Dual Memory Frequency 1330.5 MHz (1:20) Graphics card NVIDIA Gforce GTX 1060, 6gb memory
yes is the last version sp3. I also tried to remove everything in detail and reinstal but doesn't work. Is there a log somewhere to check?
hi to everyone! anyone of you has problems updating library in vision? When I press "update library", the screen stays on "downoading update" for hours and doesn't download anything. See attached image. Thanks for your support!
Could be usefull to have a tool that allow to build a strip LED with some parameters like brand of LED, kind of LED (white, multichip etc...), size of the strip, distance between LEDs and soo on
Hi to all, I've a similar problem with Vision 2020. When I press "Update Library" it show "Downloading Update" but nothing happen. I set the windows 10 firewall correctly, run as admin, but nothing change
Spotlight instrument focus
Walter Lutzu replied to Walter Lutzu's question in Wishlist - Feature and Content Requests
Please ASAP 😄 😄 😄 -
Walter Lutzu posted a question in Wishlist - Feature and Content Requests
Could be usefull to allow the editing of focus position without the use of Focus Position Tool. Just setting the pan/tilt value of one or more fixture. For example could be usefull when I select 50 fixtures in a row and put all pan=90°, tlt 20°. Now 've to create 50 focus point and.... -
spotlight fixture request form doesn't work
Walter Lutzu replied to Walter Lutzu's question in Troubleshooting
Thanks a lot Rob! I have just sent some requests 😉 I can also provide additional documentations about the fixtures (3d cad files, specification of external power/DMX units, email address of the factory product specialists, etc...) Just tell me how to do it (on the form I can upload only one file). Thanks a lot! Walter -
Thanks Rob! -
There's an error on the request fixture form page. https://serviceselect.vectorworks.net/support/fixturerequestform Need two fixtures asap... 😉 I s
Fixture Request DTS Katana
ok, I just wanted to test it in a real situation. I'll wait ;-) -
Thanks to all! -
In it possible to have the fixture DTS Katana both in Vectorworks and Vision? Here you can find download area with cad, DMX table etc... http://dts-lighting.it/products/moving-heads-leds/katana/ Thanks
