Speedy Gonzales
154 -
Everything posted by Speedy Gonzales
Thanks, we'll give it a go.
Hi all, We are on Vectorworks Architect 2012 on the Mac and wondering if there are any issues with anyone on the recently released SP-3? Thanks!
Convert pdf drawing to line drawing
Speedy Gonzales replied to Speedy Gonzales's topic in Architecture
A-W-E-S-O-M-E ! TIMESAVER DELUXE!!! Thank you so much for not only the quick reply but also the fabulous humor. -
Hi all, When we first considered upgrading to VWA 2009, one of the selling points at a Nemetschek presentation was the drag and drop feature with files being brought into VWA. With PDFs, if they were of a drawing that was originally created in a CAD program, you could import the PDF and then convert its contents into line drawings (text, not so much). Can someone walk me through how this is done, please? I can't find this feature in the help menu. Thanks!
Hidden lines are no longer in annotation view
thanks everyone for the quick and informative discussion. desperately, through trial and error, we found that billtheia was alluding to in the annotation viewport settings. Somehow, when we updated to SP5 back in December, some of our settings changed without our realizing. For everyone else who may find this issue as well, when you double-click on the viewport and select edit viewport annotation, click and check the radio button that says "Display Viewport Cache". That brought it back for us! -
Just recently (even prior to SP5 update), we began to notice that our exterior elevations within viewports were rendering fine, but when we went to add annotations or refine the elevations by drawing, the model would no longer render in hidden line mode. So now, we see all of the lines (wireframe) throughout. What could have changed? Is this a bug? We've tried opening various files on different computers and are now discovering that this is a global issue. Can someone please suggest a fix, or how we can correct a render setting? Thanks!
How to render elevations in "Sketch" mode?
thanks so much! -
Hey, this is great news to hear. But I've got a higher level question that I can't seem to readily find on the BB. A. When exporting to DWG for say, use by consultants for backgrounds, what is the best practices method, steps and settings to give them good clean drawings? (We've had reasonable success, albeit through trial and error, with plans only. We have used eDrawings to preview, but it is not reliable as it would be to open in AutoCAD, which we don't have. I will be trying TrueView using Parallels running Windows XP next.) B. As we have gotten into the habit of building our models in 3D to generate elevations and sections, etc., what is the process to export 2D elevations to DWG format in hidden line format, so that it essentially matches our WYSIWYG view in out viewports. Again, step-by-step instructions would be GREATELY APPRECIATED. I only have so much stress-related hair to pull out, and my designers are too young to go bald. If there is an existing thread that I've missed, please provide the link and we can take it from there. We are transitioning from VWA 2008 to 2009. Thank you!
We set up our drawings with viewports on sheets to show floor plans and exterior elevations. We are able to have the plans render in "careful sketch" to our liking, but we can't seem to apply the same rendering attribute to the exterior elevations. What are we missing? Thanks!
We've just upgraded to VWA 2009 (Mac) and are getting familiar with the great new stuff, but as always, missing where some of the tried and true old stuff has gone. How do we get back the dotted lines to the locus? And how do we create non-printing construction lines and interact with them? Thanks all!
v12.5.3 version number after update
Speedy Gonzales replied to Christiaan's topic in General Discussion
The version number shows up properly for me on the Intel iMac, but says 12.5.2 until you repair permissions. So far, all is GOOD! I can actually think about using it in our work environment. I'll test it out over the weekend on some simple projects to make sure. Thank you NNA and all involved for doing the right thing, and continuing to support your base. -
I feel your pain and agree with the gist of your sentiments, Kerry. NNA has been very good to us and our 3 licenses in the past, including discounted software upgrades at local trade shows, and because we have been LOYAL customers over the years. I trust that they will do the right thing. That said, I would agree that not every upgrade is necessary, and the decision is ours to make, and not to be forced upon us. In fact, our situation is that an upgrade to our OS is on $199 (family pack) vs. nearly $1,500 for the 3 licenses we have of VWA 12.5.2. That too, is a big difference. And it is true, the new OS 10.5 (Leopard) does make it feel like we have new Macs, and would increase our productivity and enjoyment of use in a work environment. I definitely relish the time I use my computers at home, which have Leopard. Alas, I can't bring that upgrade into the office environment as VWA will not work properly. End result: no upgrades to Leopard OR VWA 2008. Hmm. There's a silver lining here: A savings of over $1,700! Let's keep hope alive.
VW 12.5 / Leopard Specific Compatibility Issues
Speedy Gonzales replied to Ethan's topic in General Discussion
I did a brief and fruitless test on one of my laptops running Leopard. The killer to using VWA with Leopard is that the cross hairs for the cursor are no longer visible, and when you draw ANY object, you have no visual cues to what you are drawing. For example, if you draw a single rectangle, circle, polygon or line, all you see are line bits or dots during the click and drag or point-to-point. The object you've drawn wont' be seen until you release the mouse/complete the drawing action. This, effectively, kills the ability to use VWA for even the most basic of drawing under Leopard. It appears to be some sort of incompatibility with the drawing engine, perhaps QuickDraw, or the like. I sincerely hope that a fix can be developed as we don't see our office making an investment in VWA 2008 anytime soon, but the move to Leopard would be welcome with many of its productivity enhancements. -
Vectorworks and Mac OS X 10.5 Leopard
Speedy Gonzales replied to Bob at GDA's topic in General Discussion
I would echo Bob at GDA's last request. It may be sometime before I upgrade to VW 2008 (uh, if it ain't broke, don't fix, plus I would like to see how all this new spiffy Mac software coming out plays with each other). In the meantime, I have ordered Leopard and would like to know about VWA 12.5.2. Thanks! -
What happens with the VWA 12.5.2 file opened in VWA 2008? Is it converted to a new format for 2008? If you work on that file, and decide to revert to VWA 12, can I save it back to 12.5.2 without the loss of work? Thanks in advance for your reponses.
Hi Katie, I think your suggestion is reasonable. If I understand you correctly, you can purchase an upgrade and try for 30 days. If you don't like it or feel it's not worth the price, we can return the disk and get a full refund. Is that correct? Secondly, if I use the software to work on a current file, will VW 2008 update/upgrade to a new version of the file as 12 has done for older versions? And if it does, can I do a save-as or export back to 12 from 2008 without loss of data from any changes made in the new version? Thanks in advance for your reply. I am considering an upgrade of one of my licenses to put it through its paces before I deploy throughout the office. I will say this, many of the noted new features are what many of us have wished/requested/begged/demanded for a long time. And I emphasize, a long time. Thanks for listening.
How can I trim multiple lines simultaneously?
Thanks everyone for the assist. Along with discovering another method using duplicate area along an arc from a point after trimming the first line, it was gratifying to see that there is more than one way to skin a cat! Or trim a line. -
This may sound like a dumb question, but is there a way to do this? I've created an array of lines from the center point of an arc and want to remove the section of lines from the center point of the arc and leave only those that extend beyond the arc. In AutoCAD, there is a "fence" command to trim the selected lines. I do know that I can first set up the trimmed lines to array, but there are many cases where I find a series of objects/lines that already exist and need to be trimmed. Thanks in advance for your thoughts and solutions.
So, how do YOU do schedules, really
Speedy Gonzales replied to Francois Levy's topic in Architecture
A common problem very well submitted. I've always wondered and struggled with the same, especially as it pertains to dimensioning. I look forward to the dialogue from others and possible solutions. -
Mac OS X 10.4.9 and VectorWorks 12.5.1
All working fine here, although no speed boost in the opening of the application. -
I was diging around to find a .plist file to throw away a possibly corrupt preference file and couldn't find one. But lo and behold what I did find. It was an "Error Output" located in the VectorWorks folder of the Application Support folder in my user Library folder. Opening the file it says: "Warning: _2344 _2345 - Object passed to routine is not the proper type." It is dated 02.27.07, probably the last time I had VWA in use. Coincidence? Related? Help!
Thanks for your insight. I guess that is the oddity of this situation: nothing has changed. And while some files open up without a problem, others won't (only 2 at last count). I have attempted to open these problem files from the server, my desktop and from within VWA with the same result. That's what led me to file corruption and requesting some direction on rescuing the file. Interestingly, I had a colleague email me one of those files, as it had last been worked on at their location. It came over without an identity (no VectorWorks graphic on the file icon). I tried to double click and open, and I was asked what application to open it with. And it had the ".mcd" suffix! I tried to open from within VWA and it crashed again. I suppose it is VectorWorks itself. Perhaps a corrupted preference file (.plist), although I can't seem to find where on my computer that might reside to trash and create anew. Any thoughts on these?
I'm not sure if this helps, but it appears don't only a couple of files are causing the crash upon opening. All other current files I've attempted to open are fine. I've checked the server, VWA back-ups and the application and all seems well. That is the good news. It appears that the two or so files that crash VWA may be corrupted somehow. So how do I go about rebuilding those files or getting them fixed? Thanks.
Hi all, I am getting this problem all of a sudden as well. I've been using 12.5.1 since the second update back in January without problem on an identical set-up as anev reports above. I do have external firewire and USB attachments, including a 23" Cinema Display. Oddly, this problem only cropped up as of today! Some files do open, but others don't. And here's a case where size doesn't matter. I've tried what you suggested as well as opening under Rosetta with the same results: application opens, but some files won't. I've tried opening from within VWA and from the Finder. Odd. Incidentally, my report is quite lengthy, but perhaps anev didn't include the text that followed the initial screen. Any help is greatly appreciated.
Thanks everyone for the great ideas.
