Nicolas Goutte
411 -
Everything posted by Nicolas Goutte
Using Project Sharing across mixed PC and Mac user environment and server
Nicolas Goutte replied to anton5's question in Troubleshooting
Yes, it is surely tricky. May-be users having migrated from AFP to SMB can give you tipps. (I can only re-iterate the theory... like a parrot. 😉)- 5 replies
- vectorworks
- project sharing
(and 3 more)
Tagged with:
It has little to do with project or non-project VW files. The root problem is the different lock types between SMB and AFP. Of course, as you are supposed to share project-type VW files, the risk to have a real damage is higher. That is why the "one protocol only" way is recommended, for all VW files.- 5 replies
- vectorworks
- project sharing
(and 3 more)
Tagged with:
If you want mixed environment, you have to use SMB as network protocol, as you should only use only one protocol (and Windows cannot do AFP). See what I had written and referenced in a previous thread. (Probably you can read that entire thread too)- 5 replies
- 1
- vectorworks
- project sharing
(and 3 more)
Tagged with:
Would the list documented in http://developer.vectorworks.net/index.php/VS:InitXML be what you search?
For resetting the serial number, you have to contact your VW tech support with your serial number (do not post the serial number here).
Polylines are indeed better... just be careful that a polyline can also contain Bézier and cubic... which not all CNC can handle.
I have found a previous official answer by Tamsin Slatter on such a kind of question:
If I remember well, just do not use that computer for a certain time (a day or so). If it does not work automatically, I suppose that you have to go through support to reset your serial number.
How To Convert A String To A Number In Python?
Nicolas Goutte replied to adisharma's topic in Python Scripting
Just to be picky: that is print from Python 2. In Python 3 you need parentheses: print(int("1") + 1) As for tutorials, I would start with the official one of the Python documentation (here the Python 3.5 version, as VW uses Python 3.5.2): https://docs.python.org/3.5/tutorial/index.html -
The post in the German forum I have quoted earlier gives this command line for checking the last available version /Applications/Vectorworks\ 2019/Vectorworks\ 2019\ Updater.app/Contents/MacOS/Vectorworks\ 2019\ Updater cli check
That is the difference between Windows and macOS. Windows tries at great pain to keep compatibility to old software, macOS does not. (Also the 2017 hardware was surely not delivered natively with macOS 10.14.) As for the fact that this is "annoying", see other threads in this forum.
Have you already tried out VW 2019 SP5.2. (There is supposed to be fixes for Nvidia GPU inside. May be it would fix your problem.)
VW 2017 and older are not guaranteed to work on Mac OS 10.14. Only VW 2018 and higher were adapted.
"many" perhaps, but dongles are not the standard installation anymore. But how can something be done on the VW side? VW cannot invent a dongle driver if the dongle supplier has not released its own version of the driver. (Except, of course, by changing installations from B to E serial numbers, like the current program for the German VW... for other reasons).
If I remember well, a few years ago, I tried to get that translated name too... and I have not found a way. So, unfortunately, I am not the one who can help.
Has the Plug-Ins a localized named at all? Tools, menus, objects have translations, but Plug-Ins? (At least in C++, I do not think that they have any.)
Nice to hear that you could find out more.
Well, personally I did encrypt on Windows on VW 2019. (Yes, sure by VS call, not by VW directly) As for HFS/APFS difference, I have just thought of it because we were bitten by some differences just last week (on something else in VW's world, not encryption) Good question, indeed, to double-check if there would be still any error or warning
OK, that leaves not many options left for you to have a quick workaround. I can only think of two possible ways you could try: - a Mac running an older macOS - a Mac running macOS 10.14 but on another filesystem (HFS versus APFS, of course case-insensitive, as VW does not work on case-sensitive file systems) Also, you might try to encrypt a brand-new VS. Does it work?
The simplest solution would be probably to try to encrypt on Windows (if possible for you).
That was for VW 2018 (where the switch to Unicode was done).
It was the first idea I had when I have seen this thread. However I am not sure if it is need or not, if you do not encrypt per script (unlike we do). (That is why I have answered with such a delay.) As for documentation, see http://developer.vectorworks.net/index.php/VS:EncryptPlugin
