Nicolas Goutte
411 -
Everything posted by Nicolas Goutte
Sorry, then I cannot help, as apparently the problem is something else as the one we had.
macOS notarization and VW plug-in development
Nicolas Goutte replied to Hans Martin Kern's topic in SDK
How do you release your plugins? For example downloading a ZIP per Safari and unpacking the plug-ins, that will lead to quarantined plug-ins. -
OK, then I re-phrase what I have meant: does it happen with any kind of template documents or only with certain ones?
Is the "new" document completely empty or has it already a format record for the PIO? (We had similar problems, using the C++-SDK. In old documents, the indentation did not show up, only in new documents.)
Re-Using Classes from my Student Days
Nicolas Goutte replied to NickyC's question in Troubleshooting
Pro versions of VW cannot load student files. If you want to convert files, asks your VW support for the conditions.- 3 replies
- 1
- vectorworks 2020
- classes
(and 2 more)
Tagged with:
Well, I suppose that if it was documented in the help, then the menu entry would not need to be hidden. So somebody somewhere seems to have made a decision that a normal user should (or is only able to) use the online update. For power users, admins, support and similar there is the hidden menu entries, like going back to older version or handling an off-line installer. And for those users there is even a command line. (No, that too is not officially documented.)
That was the old system, where there was not an online update as nowadays (since VW 2019).
The VW 2020 system requirements do list macOS 10.15:
I am not sure that the offline updaters are to be publicly available. However they constitute a fallback level for support.
2020 Migration Issue - Favorites Folder
Nicolas Goutte replied to MadXD's question in Troubleshooting
You can convert the files afterwards too. When the files are converted, best is to run the "Update Libraries" in the cog wheel menu of the Resource Manager. -
VW 2018 - "The file save operation failed" when saving to network
Nicolas Goutte replied to sbutler's question in Troubleshooting
Can you outside VW: write a file, rename a file and delete a file with your user account in the same folder? -
gSDK->DuplicateObject() does not send object events?
Nicolas Goutte replied to Tobias Hauß's topic in SDK
Yes, but our problem is that it is not our script. So we are not in control what happens in the case of our PIO, which is very unpractical, as not all data should be simply duplicated. -
No, I am not trolling. If updating an OS breaks vital software for one's business, then I would not update. And curiously that argument is always applied to VW, seldom to macOS.
For such kind of arguments, I still fail to understand why macOS has to be updated the day it comes out. Why must VW wait 6 months, why not macOS?
VW2018 does not support macOS10.15. So you will have to downgrade to macOS10.14 or update to VW 2019 or 2020.
We use the functions SetStyle and SetColor only when creating the controls.
Ich have checked in our code base. In 2019 VWStaticTextCtrl does not work with styles. In 2020 it was corrected. In 2019, you have to use ISDK::CreateStyleStaticText instead of ISDK:CreateStaticText (as VWStaticTextCtrl does) to been able to have style.
Cancel Your Subscription and Stop Supporting Garbage
Nicolas Goutte replied to sbarnett's topic in General Discussion
As for subscribing of online services, unsubscribing too can be achieved by malicious third parties. Therefore it is always better to inform the real user that he is in the process of being unsubscribed. -
Python recommends using 4 spaces: https://www.python.org/dev/peps/pep-0008/#indentation However the most important in Python is to avoid mixing spaces and tabs, as mixing is the way to get discrepancies between what the human sees and the Python interpreter understands. (Python is picky on indentation.) I have checked quickly (on VW 2020): indenting works for me, if I use tabs or spaces. Of course be careful to set the VW code editor to "Python" *before* you edit any Python code in the windows or you risk mismatches. As you use IDLE, here two tips: - use Run/Check module (Alt-X) to be sure that the indentations are right - Edit/Tabify Region or Edit/Untabify Region. can help you in case you have to correct the indentation.
I am not sure what you mean. Assuming that the first code has not been corrupted by this forum, you have your code indented by tabs. So it is 4 spaces width in the VW code editor but much larger displayed in this forum. Indenting with tabs is allowed in Python, even if not recommend. As for how to change it in VW, I do not think it is possible. (The VW code editor has just the basic tools to edit code.)
DoMenuTextByName can't call menu command
Nicolas Goutte replied to GioPet's topic in Python Scripting
I suppose that you have to call DoMenuTextByName using 'Site Model Processor' and using an index. (Probably you need to experiment a bit to find out which index it is). http://developer.vectorworks.net/index.php/VS:DoMenuTextByName -
However I am checking the VWSDK 2016 (the oldest I have still available here) VWTransformMatrix.h seems to declare that function, but I cannot find a definition for it, neither inline in VWTransformMatrix.h nor in VWTransformMatrix.cpp. I suppose that it was already the case in 2015. It seems to be still the case in 2020 (even if there is a function more, but that exact signature is still only declared not defined.) Therefore I suppose that you will have to compute your rotation another way, for example using matrix multiplication.
