Nikolay Zhelyazkov
Vectorworks, Inc Employee-
1,891 -
Reputation
690 SpectacularPersonal Information
Occupation
Software Engineer
Location
Bulgaria
Recent Profile Visitors
Where's my custom title block?
Nikolay Zhelyazkov replied to Luxedavid's question in Troubleshooting
@Luxedavid The tutorial that you were watching is too old and much has changed since then. You can check for tutorials here https://university.vectorworks.net/course/index.php?mycourses=0&tagfilter[category]=0&tagfilter[type]=0&tagfilter[difficulty]=0&search=title+block&langfilter[]=0#coursestab The Title Block Coffee Break course should be enough as a start I think. -
- Which version of Vectorworks are you using? Which tutorial were you following? Can you share a screen recording, screenshot or test file showing the issue? -
I WANT MY TRANSMITTAL TO SHOW REVISIONS INSTEAD OF ISSUES !
Nikolay Zhelyazkov replied to Florane's question in Troubleshooting
Hello @Florane, The Issues are always sorted so that the newest issue comes first and then come the rest. So if you add a new issue it will shift all the rest to the right and that might be why your report is shifted. Best Regards, Nikolay Zhelyazkov -
Cable paths are shared between spotlight and connectCAD and are the same objects just 2 different tools.
Hello all, As of VW 2024 U4 equipment items that are standalone can be connected directly to the cable paths without the need of drop points. Best Regards, Nikolay Zhelyazkov
Cable problems, cable going way off course.
Nikolay Zhelyazkov replied to kevin.hayward's question in Troubleshooting
Thanks - You seem to be working in VW 2024 Update 0. We have been making improvements to the cables in the 2024 Updates, and this seems to have been resolved with them. If you update to the latest 2024 Update this should be working correctly there. -
Adapter Slots: Have to draw every time?
Nikolay Zhelyazkov replied to spettitt's topic in ConnectCAD
Hello @spettitt, I have just tested creating an equipment item using Create Equipment and having a symbol with the equipment item named make_model and it got correctly created from the symbol, preserving the adapter slots. Can you provide a sample file showing what is your setup? Best Regards, Nikolay Zhelyazkov -
Can you then make a sample test file showing the issue or PM me the file? Another important question is which version of Vectorworks are you using? -
Hello @kevin.hayward, Can you share the file with these cables and let me know how did you create them (with the cable tool, power patch selected menu command or OIP editing)? Best Regards, Nikolay Zhelyazkov -
Fastest should be through the Title Block Manager. Another way to do this is to create a worksheet report listing all TBBs and their Active parameter and then edit the value in the worksheet. Note, in worksheets you can copy multiple cells and paste them on multiple cells. This means that you can create a column of False values and paste it in the TBB Active parameter column.
Circuit Tool "Cable Length" Drop-Down
Nikolay Zhelyazkov replied to Thomas Peters's topic in ConnectCAD
Thanks for reporting this, it seems like a bug and we will look into it. -
Hello @Jeff G, I think that the problem here is that your socket symbols are all colored white now and that is why it looks like there are gaps in the device. One way to go for this is to publish with the CC-Socket-Symbol class hidden, then you will not see the socket symbols at all. Let me know if this gets the job done. Best Regards, Nikolay Zhelyazkov
Title Block Manager - Drawing Stamp Text Editing
Nikolay Zhelyazkov replied to LMRE's question in Troubleshooting
Hello @LMRE, The custom stamp text options are saved in the user folder in the file <userFolder>\Plug-ins\Common\Data\StampTextOptions.xml. The user folder settings are accessible only to you. In order to get these changes visible to your colleagues you can set up a workgroup folder which all can use and then copy this file from your user folder to the workgroup folder and then all will see these changes if they do not have their own user specific changes (meaning the same file in their user folders). Let me know if this got the job done. Best Regards, Nikolay Zhelyazkov
