Claes Lundstrom
227 -
Reputation
233 SpectacularPersonal Information
Homepage
www.touchcad.com , www.lundstromdesign.com
Location
Sweden
Contact Info
Skype
touchcad
Recent Profile Visitors
3,433 profile views
Something like this ? Note that water is highly reflective and does not have a color of it's own. The color comes from the surroundings like the sky, clouds, land in the background, objects in the water, depth of the wet and from the water itself if it's polluted by something. The main feature of a water consist of being very shiny and some degree of bump map, but no texture picture like for example wood or stone. The bump map can probably be reduced in size and file format (sorry but I usually need very high quality texture maps in my work). Water 2009 v2024.vwx
Here is a small test on a similar room size. As you say, you can't order a prefabricated kitchen based on these scans, but I have found it useful in many ways, for making quick estimates on floor and wall areas etc, and you get a lot of details you risk missing by just measuring manually and using photos. The error margin in this case is just over 1 % compared to measurements using a Leica laser. I used the trick of just scanning the roof, as lots of for example furniture tends to mess it up, and of course hoping that the walls are fairly vertical. I also used the clip cube to trim off the edges in the corners, where scanners tend to create a "worn soap effect" (rounding off the corners), which makes it difficult to extract the true wall surface. I guess a few such basic measurements can extract a calibration factor the you can use on the dimensions used.
Have you tried turning off simplifications in Scaniverse ? It may generate more points. Not sure more points necessarily means better result though. Simplify can also remove irrelevant stuff and make the files smaller. One limitation with lidar is that it only sees up to 5 meters, so there is an edge for photogrammetry in areas where you can't physically go a given point within the range. I have tried a few other apps that generates more points but I'm not sure it added much in quality. Generally speaking, I wish there was an efficient method to extract edges, as a few edge points is often better as a base for modeling. This applies to most of these apps regardless of method.
Scaniverse is free app to start with if you want to experiment. It exports several formats that can be used with VW, both for mixing scans and CAD elements as well as processing with the terrain modeller points. It also exports USDZ models that can be seen in Apples' Preview app as well as augmented reality on the iPhone or iPad with no installation needed. Expect an accuracy at about 0.5%. The example is about 180 s q m and took about ten minutes to scan in one session.
Adobe Illustrator simply needs a major update. The DXF import / export features are notoriously unreliable and they have been so for a very long time now. Its' surprising that such a large company can't do better in this respect considering how important the communication between the CAD and printing world is. Most of us use this type of communication a lot, usually on daily basis at least in my business.
Yes, it would help a lot to have two way SVG for communication with illustration programs such as Illustrator, Photoshop CorelDraw, Affinity Designer and so on. Not sure it would help in accuracy though, as these programs are on a different and much lower level of accuracy than CAD programs in general, so expect a lot of patching when importing, unfortunately. The same applies to PDF's when importing elements containing vector data. Sure, you can decompose and extract the vectors, but it is always a bit crappy. Perhaps it could be a fixed to some extent by adding a cleaning filter, but it would be based on guessing instead of knowing.
Vectorworks MUST have .FBX Import
Claes Lundstrom replied to MGuilfoile's question in Wishlist - Feature and Content Requests
USD still feels a bit unfinished and buggy, though promising. Why does it so different in Preview as it does on the iPhone (as augmented reality and as a stand alone)? Looks better that it does in Adobe Aero though, which seemed to have stalled in development lately. Let's hope Apple put som effort into this. -
I agree with MGuilfoile. There is a wealth of pre-drawn and highly specialized models available for download on the web. If you need a very specific model of a person or a plant or a car or a piece of furniture, there is a very good chance that somebody else has modeled it before, so why waste time re-inventing the wheel ? As an example, I wanted this particular car model, and sure enough, somebody had done a very nice job for the love of it, and it was free too. FBX is a format where you get a more or less ready to rendering model, so yes please. -
I usually use Keyshot for product renderings as delivers results very quickly with its high quality realtime rendering. It works very well with my main freeform modeling program (OK with VW too), as I seldom spend more than a few minutes in it to generate a quick visual on a simple model. I would perhaps not use it for architectural renderings though. The models where just examples of fairly complex closed but hollow mesh based shapes being trimmed afterwards with solid subtractions in VW. The discussion started with meshes from Rhino and whether they could be used as solids. I don't use Rhino but have a similar situation from the program used. Here is a practical example, where I imported a "solid" mesh, and divided it into two parts in VW using solid modeling, and to be used for 3D printing. The result was a 523 mm long scale model printed in one session, which took just under five hours. Lapstrake 523mm 3D print model.568.mp4
A mesh is indeed a solid provided that the shape is closed and leak free, and that all normals are facing the correct direction. You can use it for solid subtractions just like ordinary solids. To check that it's valid and leak free, check the volume. If it's OK the volume should be bigger than zero, like it is in the picture. I imported the mesh in the picture, and converted the parts (in this case four meshes) into a single mesh. I then added a smaller version inside the original, and ran Subtract Solids, and it worked ok. It still had a volume and the clip cube showed an edge as a solid.
Weird cursor cue behaviors can sometimes be caused by Photoshop. Seen it in other programs than VW too, so it may not be a VW issue.
3D model unfold question
Claes Lundstrom replied to drawer3d's question in Wishlist - Feature and Content Requests
