nlands
14 -
Reputation
2 NeutralPersonal Information
Location
United States
Recent Profile Visitors
Thank you Tom! I think our layers may have been below the site model design layer and we’ll keep an eye on the layer elevations, relatively. Will let you know how it goes! Appreciate your time.
Hi all, I can’t seem to get this workflow figured out nor find it in all the videos we’ve watched. We thought it has to be fairly simple but we’re missing it so we’re reaching out. Every time we import survey data and create a site model, it sits at its true elevation on the page — which, locally, is 5,000 ft above the ‘ground plane’ on our drawing — so everything we add to that layer (text, dims, massing models) sits 5,000 ft below it on the ground plane. Can someone please give us the workflow to set the ground plane equal to an elevation point of the site? Thanks so much!
I'll give it a try!
Hi All! I'm new to Glow and just read through this thread. Super helpful but I've still got a problem that I'm hoping is an easy solve I'm trying to render a PMS202 (HEX 5B1F1E) with a Glow Texture but it's coming out Pink -- BOTTOM in the image below. I was able to do a workaround by putting a Glow Texture behind the red letters in the TOP image but it's still not what I want -- is there a way to make the dark red look like it's either neon or backlit?
Wall Recess -- why is this happening?
nlands replied to nlands's question in Wishlist - Feature and Content Requests
I'll try that! Thank you for responding! -
nlands posted a question in Wishlist - Feature and Content Requests
No matter what we do, the wall recess doesn't cut through to the full length of the wall. The 3D block were using expands past the ends of the wall, on each end, but when it's cut, it ends about a foot short & only here. Why is this happening? Any insight would be absolutely appreciated -
Turning around inside a Twinmotion Model
Thanks. Did that. Can't seem to figure out how to rotate / pan -- What combination of buttons do you use? (the download say Rotate = 5, Pan = 4 -- but they're not working as such)... what are we missing? -
New to Twinmotion. Imported a VW model and can't figure out how to rotate inside of a room to see what's behind me -- on a Mac. Is the navigation limited to L, R, Up, Down? What am I missing... -
All of a sudden I can't select anything on my drawings
nlands replied to nlands's question in Troubleshooting
Thanks Pat -- (Layers and classes are all turned on to show/snap/modify) -- what do you mean 'the options'? -
The only way to select a wall, window, text is to 'force select' it -- what happened? Layers and classes are all turned on to show/snap/modify and we restarted the computer and VW2020... did we accidentally turn something on / off?
Hello! Still Looking For Some Help? I am a one-man residential design & construction services office outside of Denver, Colorado. Reach your customers with professional imagery that truly connects and sparks engagement and effective follow-through for your builders. I specialize in: ● Thoroughness ● Honesty ● Gaining the trust of clients Spec Houses / Custom Houses / Floor Plans / Site Plans / Plot Plans / Sections / Structural Drafting / Electrical Plans / Demolition Plans Drafting / 3D Renderings / Exteriors / Sites / Landscaping /Interiors / Specifications / 27 yrs of Residential Design / Interior Design Professional with a track record in ranging from planning to project completion. Excellent team player. Can be trusted with the responsibility and stress that goes with the job. My business designs large scale custom homes (typically 2-3 projects/year -- design / interiors / construction services) Looking for solid side hustle to help you out and keep myself busy (I have consistent gaps in my business days/weeks while designs are with clients, plans are in building departments or zoning/HOA -- don't worry; I'd never take a job that I couldn't do or meet a deadline for either of us -- I love what I do and can manage making you successful) N. Lands landsdesign@comcast.net 303-665-1428 Elevator Addition, Sheet A5.pdf
