Hassan Raza
    37
Everything posted by Hassan Raza
  1. @Christiaan to my understanding it has to do with how VW2020 deals with heavy geometry and so far it is disappointing.
  2. @RussU If it has to do with any hardware issue, it would have been the same for VW2019.
  3. @Tamsin Slatter I have the error log switched on but they never mentioned or used those logs to come up with a diagnosis.
  4. I am having such an awful time working on VW2020. SP0 has some graphical issues but then I installed SP1 and the problem started happening. Talked to a bunch of VW technical team members, tried a bunch of things from updating my IOS to disconnected my 4K secondary display to downgrading to SP1 but nothing is working. My question to VW is why do you guys release such an unstable version of the software?
  5. I am having issues with Slab drainage tool in VW 2019. Every time I use a slab drainage tool on a slab and close the file. When I open the file again, the slab drainage gets disappear and shows only a slab with error- See attached. Anyone having a similar issue?
  6. I could see the section line but the related viewport has disapeared. Has anyone else encountered similar issue or knows how to resolve it?
  7. What is the most up to date recommended workflow to export BIM objects from Vectorworks to Revit while keeping their properties intact?
  8. Hi, I have come across this problem with one of my Vectorworks file. When I try to open the file it gives me this error "Unexpected end of file encountered during file read operation" and when I hit ok, it goes into recovery mode and recovers only a few layers out of all. I am trying to find out a way to recover this file completely. Please if anybody who had a similar experience and successfully recovers the file can guide me through the process. Thanks!
  9. Hi Everyone, I have noticed ramps has its own rail but there are not many setting available to customize it. Is there a way to use normal railing for ramps or change railing for ramps to be more flexible. What I am trying to achieve is to match ramp guard rail to match with my other railing-See attached Thank you!
  10. @Andy Broomell Geometry is around 1500' away from 0,0 in the document and it also happens with the renderwork camera.
  11. @Wes Gardner Restarting Vectorworks didn't help. @Boh it is not being clipped on viewport but the design layer 3d view. I have noticed it is only happening in narrow and normal perspective and not in orthogonal view of that specific file.
  12. Hello Everyone, I may have changed some setting for renderworks camera or something else happened but now all the orthogonal views in one of my files appear to have a cutting plane that does show the whole model. It may be a tiny bit of setting but its really annoying. Please guide anyone who has the same experience. See attached a screenshot. Thanks
  13. I am trying to import a Revit *.rfa file for a product, VW is giving me this error "This version of Revit file is not supported". Does anybody have a solution to this? Thanks
  14. @Matt Panzer How long does it take usually for Vectorworks to fix such issues?
  15. I believe I have placed them correctly. I am using Architect 2018 SP3. Interestingly this forum is giving me an error when I am trying to upload a file with skylights but I am able to upload a VW file without it.
  16. Hi everyone, I have used few of skylights symbols on roof face but it not showing up on hidden line elevation viewports. Has somebody faced a similar situation? Thanks! Hassan
  17. Hi All, I am having continuous trouble while saving and checking out layers in Vectorworks 2018. I have been using dropbox for quite a while and never encountered such long delays for project file to update even when I was alone working in it. Attached see image showing the message I get every time I try to check out layers. It would be huge help if anybody has any insight on this topic.
  18. I am having issue exporting web view in Vectorworks 2018. I am wondering if someone has anymore info on this. Thanks! H
  19. I am thinking to use subdivision tool for modeling a character. Has anybody have any experience with it. I have used Autodesk Maya and Blender earlier for similar purposes. I would really appreciate suggestions and comments!
  20. For me checking out each layers from project sharing through drop down menu works rather then checking out objects while making changes. Sp1 definitely resolve few issues specially graphics glitches but still it is far from being perfect.
  21. Hi Everyone, We are having difficulties with sometimes work is not being saved even after saving and committing in a project sharing file since we updated to 2018. We tried making a new project file after making previous project file into normal Vectorworks file. I am wondering if someone is having the same issue or know anything about it. Thank you!
  22. Can please somebody tell me the overall difference between Sectional viewport tool and Interior Elevational viewport tool? I have been using Sectional viewport tool for interior elevations and started to use Interior elevational tool for elevation for super small spaces due to its small marker on plan. For me they both work in same manner but if anyone has a better understanding about the difference between these two tools.
  23. Is there a way to remove the line shows up in Interior elevation viewport?Please see attached images
