143 -
Posts posted by Kazemester
More bugfixing, less pointless changes! Bring back old icons!
- 2
I've tried to ungroup a pdf into lines and polygons...sometimes VW2020 makes it sometimes it does not with the same pdf.
I mean sometimes it ungroups into bitmap, "white rectangle" and lines and polys group....sometimes its only bitmap and white rectangle...
Please fix this.
ps.: new tools icons look weird (there was no need to change them...devs should have foused on bug fixing instead), please make it switchable back to "old style"
psps.: does anyone have the old icon set and know how to replace thm in VW2020? thanks
pspsps.: when will be some european standards included??? Example: usable and informative centerline marker... (learn from archicad please as Nemetcshek has bought Graphisoft...)
Dear VW Users,
is there any way to export a pointcloud in any pointcloud format? I've used some softwares now which are capable of registering pointclouds, but i've found out that Vectorworks is far more agile registering pointclouds (manually) together than others. But after that I have to give the registered (best fitted pointcloud to pointcloud together) data to others in any kind of pointcloud file format. Is there any way or export plugin that i could export pointcloud with from VW? (Obj and dwg or other formats are not good, only E57, or XYZ...etc.)
Thanks for the help.
Zoltan
Never mind...found the "tapered" setting in the slab component settings...
Murphy...
- 1
As far as i know there is no such thing as "architectural perspective", when the vertical lines are parallel only if you match your camera look to height to camera height.
(I've been complaining about this for a while with multipass rendering...but hey...there are always workarounds....)
Hi,
I was searching the forums for this, but i couldn't find anything relevant...Is there any options to set the drainage slope to a specific slab component when i place a slab drainage or can i set that after? Is this even in VW yet or the drainage tool always sets the slope for the top component? ( I want it to be set on 2-3 layers below and set the above components parallel to the sloped one.)
Sorry for the question if its a simple thing, i just can't find a solution for it.
Thank you!
14 minutes ago, Stephan Moenninghoff said:
I know how to isolate points, what i ment is imagine a big pointcloud and you just want to hide some points in the middle. There are always other points in your way from your pov but using clipcube could solve this problem...or at least i thought it does. But when i isolated those points the other points were isolated as well outside the clipcube (which were not visible outside the clipcube).
I wish I could isolate (hide) specific points in a pointcloud while Im in clipcube. Clipcube is not an isolation itself, therefore while I try to isolate some visible points, the isolation “cuts” through the whole pointcloud even when the points are “behind” the clipcube’s plane.
Is there any workaround for this or it’s just not possible to program!?
Thanks
Im trying to make a viewport of my building with a 20million point pointcloud on one of the layers. Vectorworks just eats up all my 48GB of ram and crashes to desktop with the following error: Im using my VW2018 licence now on the same computer and it just does the work fine with the same settings...Can this be fixed fast please? It was all fine until SP2-3...
Please note that the screenshot is 5 days old and was on an older version of OSX, but i upgraded to the latest version and VW 2019 does the same crash.
Update: sleep - wake solves the issue...
- 1
@RossU i’ve sent you a file that has the same issue.
Only restart resets the cursor. Cursor is big on the left half of the screen and small on the right side. Not an OSX bug, i went through all the settings, resolution change, logout, etc.
It happens after a while i work with VW 2019 SP3 and an iMac 27" 5k.
Did anyone else experience this? Thanks
Edit: screen recording doesn't record this...
New video with iPhone:
- 1
Thanks but sadly it is. 😕
Thank you! I'll use that.
I've checked my example file though and in this case i don't have any georeferenced layers and all my geometry are near the origin and the scale isn't extreme.
This was my first idea, but when i need to work with georeferenced data, i can not move the geometry anywhere.
Every once in a while this happens. It happens sometimes when i work with imported mesh and-or 3d polys, but sometimes i experience this when i import a shape file downloaded from openstreetmap exported from qgis. (Than extrude some of those 2D polys.)
A simple VW restart usually fixes this, but it remains in the exported file for example to Cinema 4D.
Any idea what is this?
Thanks
I don’t have any antivirus on my mac and VW slows down significantly after a couple hours of work. It seems to be a memory related “problem”, as i see VW doesn’t really cleans memory efficiently and keeps eating ram until it dies.
I miss those good old days when a new VectorWorks release was actually released after it was tested and optimized even if it took more than a year. It's sad that the "dev team" focuses on the "new content" instead of fixing the old ones and implement stuff that is actually needed. (Freeform bendable walls, window and door centerline data...etc.)
19 hours ago, Kazemester said:
Process: Vectorworks [32088]
Path: /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/Vectorworks
Identifier: net.nemetschek.vectorworks
Version: 23.0.3 [418943] (23.0.3)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Vectorworks [32088]
User ID: 502Date/Time: 2018-04-01 20:20:45.413 +0200
OS Version: Mac OS X 10.13.3 (17D102)
Report Version: 12
Anonymous UUID: 8B83ED14-46B1-FDC6-DE3E-87A1E92F81D4
Time Awake Since Boot: 380000 secondsSystem Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000c8
Exception Note: EXC_CORPSE_NOTIFYTermination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]VM Regions Near 0xc8:
__TEXT 00000001013b2000-0000000104ac1000 [ 55.1M] r-x/rwx SM=COW /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/VectorworksApplication Specific Signatures:
{"sn":"EDXUSZ-XXXXXX-XXXXXX-G02TGN", "ts":"49dbb88037", "platform":"MAC", "os_ver":"10.13.3", "vw_ver":"2018 SP3 [23.0.3(418943)] (64-Bit app)", "error_reporting_mode":1}Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc1125b VGM::IndexRanges::Empty() + 7
1 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc7c906 VGM::RenderEngine::RenderPointBatches_Forward(bool) + 1480
2 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc7a88e VGM::RenderEngine::Render(VGM::ERenderMode) + 1200
3 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc2b5ce VGM::GeometryEngine::PointRender(std::__1::vector<VGM::Camera, std::__1::allocator<VGM::Camera> >&, VGM::StackingOrderDepthBaseArgs&) + 242
4 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc2d85f VGM::GeometryEngine::RenderScene(VGM::DisplayMode, bool) + 1133
5 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc4282e VGM::GraphicsEngine::RenderScene(glm::detail::tvec4<int> const&, unsigned int, unsigned int, unsigned int, VGM::FrameQuality const&, VGM::DisplayMode, void*) + 624
6 net.nemetschek.vectorworks 0x000000010391e284 0x1013b2000 + 39240324
7 net.nemetschek.vectorworks 0x0000000102ec3cd5 0x1013b2000 + 28384469
8 net.nemetschek.vectorworks 0x0000000102ecb8e9 0x1013b2000 + 28416233
9 net.nemetschek.vectorworks 0x0000000102eccc00 0x1013b2000 + 28421120
10 net.nemetschek.vectorworks 0x0000000102ec13ee 0x1013b2000 + 28373998
11 net.nemetschek.vectorworks 0x0000000102ec702c 0x1013b2000 + 28397612
12 net.nemetschek.vectorworks 0x0000000102eca9c6 0x1013b2000 + 28412358
13 net.nemetschek.vectorworks 0x0000000102ec8af6 0x1013b2000 + 28404470
14 net.nemetschek.vectorworks 0x0000000102ec101f 0x1013b2000 + 28373023
15 net.nemetschek.vectorworks 0x0000000102ec0fef 0x1013b2000 + 28372975
16 net.nemetschek.vectorworks 0x0000000102aae597 0x1013b2000 + 24102295
17 net.nemetschek.vectorworks 0x0000000102933d2c 0x1013b2000 + 22551852
18 net.nemetschek.vectorworks 0x00000001026b45a3 0x1013b2000 + 19932579
19 net.nemetschek.vectorworks 0x000000010157fe5d 0x1013b2000 + 1891933
20 com.apple.AppKit 0x00007fff44664422 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 1961
21 com.apple.AppKit 0x00007fff4466385c -[NSWindow(NSEventRouting) sendEvent:] + 497
22 net.nemetschek.vectorworks 0x00000001015b521c 0x1013b2000 + 2109980
23 com.apple.AppKit 0x00007fff444c4617 -[NSApplication(NSEvent) sendEvent:] + 307
24 net.nemetschek.vectorworks 0x00000001016ad182 0x1013b2000 + 3125634
25 net.nemetschek.vectorworks 0x00000001016ad02d 0x1013b2000 + 3125293
26 com.apple.AppKit 0x00007fff43d25d9d -[NSApplication run] + 812
27 com.apple.AppKit 0x00007fff43cf4f1a NSApplicationMain + 804
28 libdyld.dylib 0x00007fff6e061115 start + 1Thread 1:
0 libsystem_kernel.dylib 0x00007fff6e1b0f0a __recvfrom + 10
1 net.nemetschek.vectorworks 0x0000000101f6bf82 0x1013b2000 + 12296066
2 net.nemetschek.vectorworks 0x0000000101f51bff 0x1013b2000 + 12188671
3 net.nemetschek.vectorworks 0x0000000101f51e4e 0x1013b2000 + 12189262
4 net.nemetschek.vectorworks 0x0000000101f52769 0x1013b2000 + 12191593
5 net.nemetschek.vectorworks 0x0000000101f576c0 0x1013b2000 + 12211904
6 libsystem_pthread.dylib 0x00007fff6e2ec6c1 _pthread_body + 340
7 libsystem_pthread.dylib 0x00007fff6e2ec56d _pthread_start + 377
8 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 2:: CVDisplayLink
0 libsystem_kernel.dylib 0x00007fff6e1b0cee __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff6e2ed662 _pthread_cond_wait + 732
2 com.apple.CoreVideo 0x00007fff482fb9b8 CVDisplayLink::runIOThread() + 660
3 libsystem_pthread.dylib 0x00007fff6e2ec6c1 _pthread_body + 340
4 libsystem_pthread.dylib 0x00007fff6e2ec56d _pthread_start + 377
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 3:
0 libsystem_kernel.dylib 0x00007fff6e1a77fe semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff6e03782e _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff6e02f911 _dispatch_semaphore_wait_slow + 101
3 net.nemetschek.vectorworks 0x0000000101f57185 0x1013b2000 + 12210565
4 net.nemetschek.vectorworks 0x0000000101f57953 0x1013b2000 + 12212563
5 net.nemetschek.vectorworks 0x0000000101f4d6bb 0x1013b2000 + 12170939
6 net.nemetschek.vectorworks 0x0000000101f4cffe 0x1013b2000 + 12169214
7 net.nemetschek.vectorworks 0x0000000101f576c0 0x1013b2000 + 12211904
8 libsystem_pthread.dylib 0x00007fff6e2ec6c1 _pthread_body + 340
9 libsystem_pthread.dylib 0x00007fff6e2ec56d _pthread_start + 377
10 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 4:
0 libsystem_kernel.dylib 0x00007fff6e1b105a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff6e12c75c nanosleep + 199
2 libsystem_c.dylib 0x00007fff6e12c650 usleep + 53
3 net.nemetschek.vectorworks.Renderworks 0x0000000116256e7a melange::IpKillThread::Main() + 58
4 net.nemetschek.vectorworks.Renderworks 0x0000000116230888 melange::BaseThread::Action() + 88
5 net.nemetschek.vectorworks.Renderworks 0x0000000116230769 0x1160be000 + 1517417
8 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 5:
2 libpskernel.dylib 0x000000010ac104f2 create_wrapper + 578
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 6:
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 7:
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 8:
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 9:
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 10:
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 11:
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 12:
5 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 13:
2 libc++.1.dylib 0x00007fff6c096cb0 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
3 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc238cb 0x12db9f000 + 542923
4 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc234cf ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::WorkerThread() + 305
5 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc23a65 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >*> >(void*) + 62
8 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 14:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff6e1a77c2 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff6e1a6cdc mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff4674f575 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff4674e8c7 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff4674df43 CFRunLoopRunSpecific + 483
5 com.apple.AppKit 0x00007fff43e6e3c8 _NSEventThread + 184
8 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 15:: QThread
0 libsystem_kernel.dylib 0x00007fff6e1b0fca __select + 10
1 QtCore 0x00000001ea5eedb3 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*) + 547
2 QtCore 0x00000001ea5efcf8 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timespec*) + 680
3 QtCore 0x00000001ea5f0d9b QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 251
4 QtCore 0x00000001ea5989ad QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 381
5 QtCore 0x00000001ea39007e QThread::exec() + 126
6 QtCore 0x00000001ea3943f2 QThreadPrivate::start(void*) + 338
7 libsystem_pthread.dylib 0x00007fff6e2ec6c1 _pthread_body + 340
8 libsystem_pthread.dylib 0x00007fff6e2ec56d _pthread_start + 377
9 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 16:
4 net.nemetschek.vectorworks 0x0000000101f5a20e 0x1013b2000 + 12222990
5 net.nemetschek.vectorworks 0x0000000101f59a96 0x1013b2000 + 12221078
6 net.nemetschek.vectorworks 0x0000000101f576c0 0x1013b2000 + 12211904
9 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 17:
9 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 18:
9 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 19:
9 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 20:
9 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 21:
9 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 22:
9 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 23:
3 net.nemetschek.vectorworks 0x00000001039402ab ThreadGroup<DrawingUnit*>::WorkerThread() + 123
4 net.nemetschek.vectorworks 0x00000001039408d1 void* std::__1::__thread_proxy<std::__1::tuple<void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 113
5 libsystem_pthread.dylib 0x00007fff6e2ec6c1 _pthread_body + 340
6 libsystem_pthread.dylib 0x00007fff6e2ec56d _pthread_start + 377
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 24:
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 25:
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 26:
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 27:
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 28:
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 29:
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 30:
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 31:
8 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 32:
8 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 33:
8 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 34:
0 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc21bbd VGM::VisitMesh(VGM::VisitMeshArgs&) + 2306
1 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc222ab 0x12db9f000 + 537259
2 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc20b0a VGM::FramerateMgr::ManageFramerate(std::__1::shared_ptr<VGM::FramerateJob>&) + 634
3 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc2341c ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::WorkerThread() + 126
4 net.nemetschek.vectorworks.VWGraphicsModule 0x000000012dc23a65 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >*> >(void*) + 62
7 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 35:
8 libsystem_pthread.dylib 0x00007fff6e2ebc5d thread_start + 13Thread 36:
0 libsystem_pthread.dylib 0x00007fff6e2ebc40 start_wqthread + 0
1 ??? 0x0000700000000001 0 + 123145302310913Thread 37:
0 libsystem_kernel.dylib 0x00007fff6e1b1562 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff6e2ec26f _pthread_wqthread + 1552
2 libsystem_pthread.dylib 0x00007fff6e2ebc4d start_wqthread + 13Thread 38:
1 ??? 0x0000000000000001 0 + 1Thread 39:
1 ??? 0x0000000000000010 0 + 16Thread 40:
2 libsystem_pthread.dylib 0x00007fff6e2ebc4d start_wqthread + 13Thread 41:
2 libsystem_pthread.dylib 0x00007fff6e2ebc4d start_wqthread + 13Thread 42:
2 libsystem_pthread.dylib 0x00007fff6e2ebc4d start_wqthread + 13Thread 43:
2 libsystem_pthread.dylib 0x00007fff6e2ebc4d start_wqthread + 13Thread 44:
1 ??? 0x00007fffa6f7b480 headPagePairs + 48Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x000000012dcfb32c rcx: 0x0000000000000001 rdx: 0x0000000000000784
rdi: 0x0000604001408048 rsi: 0x000000012dcf83a6 rbp: 0x00007ffeee84abc0 rsp: 0x00007ffeee84abc0
r8: 0x000000012dcfcc71 r9: 0x00007fb1bac16fb0 r10: 0x0000000000000000 r11: 0x0000000000000001
r12: 0x00007fb1b606b938 r13: 0x00007fb1c2192200 r14: 0x000000012dcfb652 r15: 0x00007fb1c21922b8
rip: 0x000000012dc1125b rfl: 0x0000000000010202 cr2: 0x00000000000000c8
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x1013b2000 - 0x104ac0c97 +net.nemetschek.vectorworks (23.0.3 [418943] - 23.0.3) <E78D4930-4EB4-3FD5-AAFB-080C38461E59> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/Vectorworks
0x105546000 - 0x105a38fff +libdcu2d65.dylib (0) <5961C038-836F-3D2B-A0D6-A8D7BB3B701A> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libdcu2d65.dylib
0x105cd6000 - 0x105cd8fff +libboost_system.dylib (0) <FD3A0297-3214-3F2C-95BE-FAAC54953B5E> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libboost_system.dylib
0x105ce6000 - 0x105d0bff7 +libosdCPU.2.5.0.dylib (0) <D1EBC34A-EFA2-3362-A101-5EC18DE33AF7> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libosdCPU.2.5.0.dylib
0x105d2c000 - 0x105f3dfef +org.python.python (3.5.2, [c] 2001-2016 Python Software Foundation. - 3.5.2) <E72CC169-DB75-78E3-129F-F74F5A5058F8> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/Python.framework/Versions/3.5/Python
0x106081000 - 0x106087ffb +net.nemetschek.VWMM (1.0 - 1) <CCD25092-D8D0-3301-94D9-1DBA1227E38B> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/VWMM.framework/Versions/A/VWMM
0x106094000 - 0x10778dfff +libPDFNetC.dylib (6.5) <8242FC4C-361D-CF28-9E08-7F7C9201156B> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libPDFNetC.dylib
0x107d36000 - 0x107d3bff7 +libpsassemblyrep.dylib (0) <08BEDFB2-C7EE-3F06-80AA-170FA486D24D> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsassemblyrep.dylib
0x107d4c000 - 0x107e35fff +libpsgeneric.dylib (0) <FAF8F195-D749-3A51-BC66-2F3114F71CE9> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsgeneric.dylib
0x107ea4000 - 0x107ec3ff7 +libpsiges.dylib (0) <0D544614-7178-366A-BD1F-8381C3868205> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsiges.dylib
0x107eed000 - 0x107f13ff7 +libpsinterop.dylib (0) <6DB65E9F-E500-3D04-A189-0473329FC165> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsinterop.dylib
0x107f53000 - 0x107f56fff +libpspropertiesbase.dylib (0) <DCFBB48F-983F-389C-9313-CD383B66920D> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpspropertiesbase.dylib
0x107f62000 - 0x108000fff +libpsxlatorbase.dylib (0) <669E0E16-1F27-315E-8746-8F101B5805E3> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsxlatorbase.dylib
0x108068000 - 0x10806cff7 +libpspropertiesbrepimporter.dylib (0) <2EDB7C06-14BA-3076-94CD-94021F5FD328> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpspropertiesbrepimporter.dylib
0x108077000 - 0x108199ff7 +libpsxcore.dylib (0) <EA2395CA-CBB0-30D3-96C8-7A9C6834C01C> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsxcore.dylib
0x108218000 - 0x1083c0fff +libpsxiges.dylib (0) <85B64C62-1ED7-356F-92BB-62D7BC1867F9> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsxiges.dylib
0x108472000 - 0x108494ff7 +libpsxmil.dylib (0) <1C447EBD-15CA-3762-8750-A7EC3E0EC4B5> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsxmil.dylib
0x1084b7000 - 0x10b327ff7 +libpskernel.dylib (0) <DA1B8C12-3E7B-31C6-803D-82F161922290> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpskernel.dylib
0x10b5ca000 - 0x10b5cdff7 +libmessagehandler.dylib (0) <FC4D5F00-F6DE-3675-9E61-E59188FD3F81> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libmessagehandler.dylib
0x10b5d8000 - 0x10b610fff +libHSIMac.dylib (0) <6D170DB2-9A66-30AD-9F23-2E7B4950C8F9> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libHSIMac.dylib
0x10e5a7000 - 0x10e5f4ff7 +net.nemetschek.vectorworks.VWLibrary (1.0) <C84BFF90-5D11-3FC6-95BB-80DBE290EDD6> /Applications/Vectorworks 2018/*/VWLibrary
0x10e688000 - 0x10e696fff +libboost_filesystem.dylib (0) <90F19FCF-752F-37D5-B04A-4898920178C5> /Applications/Vectorworks 2018/*/libboost_filesystem.dylib
0x10e6a1000 - 0x10e6a3ff3 +libboost_system-mt.dylib (0) <28E41007-7056-3375-A009-BB8E0FC78AF1> /Applications/Vectorworks 2018/*/libboost_system-mt.dylib
0x10e6a7000 - 0x10e6b5fff +libboost_filesystem-mt.dylib (0) <2DDA5D7A-2A09-33BB-B0BF-F63477DCF8BC> /Applications/Vectorworks 2018/*/libboost_filesystem-mt.dylib
0x10e6c0000 - 0x10e6c2ff3 +libboost_system.dylib (0) <50023B1D-95F2-3C02-877F-5C7B5E6CAD4E> /Applications/Vectorworks 2018/*/libboost_system.dylib
0x10e919000 - 0x10e966fff +net.nemetschek.vectorworks.AlignLayerViews (1.0) <267127E8-A1C2-3816-BEF1-250E29B6C726> /Applications/Vectorworks 2018/*/AlignLayerViews
0x10eb4e000 - 0x10ebc3ff7 +net.nemetschek.vectorworks.CheckSpelling (1.0) <EFF5E969-B805-32E3-B5B9-148A7CFF477F> /Applications/Vectorworks 2018/*/CheckSpelling
0x10ec22000 - 0x10ece5ffb com.apple.AMDRadeonX4000GLDriver (1.60.26 - 1.6.0) <0066C672-7627-310C-8DBD-1D23BB746AE4> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x10ed35000 - 0x10ee6afff com.apple.AMDMTLBronzeDriver (1.60.26 - 1.6.0) <7C3FAF5B-05D0-3AE7-B3DB-8D50D98E3072> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x10f0b9000 - 0x10f10398f dyld (519.2.2) <6695F30B-4E88-3C0B-9867-7D738C44A3E6> /usr/lib/dyld
0x110d5d000 - 0x110daafff +net.nemetschek.vectorworks.TesterModule (1.0) <A68B4FCC-E0D6-3EF0-9FF3-4157492916FA> /Applications/Vectorworks 2018/*/CheckForUpdates
0x110dcb000 - 0x111082ff7 +de.computerworks.vectorworks.CWLibraryUniversal1 (D23.0.3 R1 - 1.0) <5F689514-206C-3901-9739-965EB2BA89CB> /Applications/Vectorworks 2018/*/CWLibraryUniversal1
0x111377000 - 0x111618fff +net.nemetschek.vectorworks.DebugModule (1.0) <917B0591-CAC4-3418-B85D-B35EACA1C3F2> /Applications/Vectorworks 2018/*/DebugModule
0x11172c000 - 0x1118c8ff7 +net.nemetschek.vectorworks.Marionette (1.0) <72853949-9EFE-3EA6-ADE0-2A0CA82282E9> /Applications/Vectorworks 2018/*/Marionette
0x111982000 - 0x1119d2fff +net.nemetschek.vectorworks.TesterModule (1.0) <2CC15F09-8412-3C3E-B579-D6FCF0111D7C> /Applications/Vectorworks 2018/*/OnlineResources
0x1119f7000 - 0x111b2cff7 +net.nemetschek.vectorworks.SpotlightVision (1.0) <BA175F15-26BE-3B2F-B5C4-A18499197010> /Applications/Vectorworks 2018/*/SpotlightVision
0x111bba000 - 0x1120c9ff7 +org.qt-project.QtCore (5.5 - 5.5.1) <D07C940F-8EB1-3F47-942F-6A00BCBCCD06> /Library/Frameworks/QtCore.framework/Versions/5/QtCore
0x1121bc000 - 0x1121f3fff +org.qt-project.QtXml (5.5 - 5.5.1) <6B22AC36-E02D-3902-98E6-8678065F9E4C> /Library/Frameworks/QtXml.framework/Versions/5/QtXml
0x11220a000 - 0x112259ff3 +libsVisionPlugin.dylib (0) <A71BAFCF-617C-3370-A61F-50FD16741E99> /Applications/Vectorworks 2018/*/libsVisionPlugin.dylib
0x112276000 - 0x1122b4fff +org.qt-project.QtOpenGL (5.5 - 5.5.1) <4BE1F8E5-6B6E-3988-A746-440D80603FB7> /Library/Frameworks/QtOpenGL.framework/Versions/5/QtOpenGL
0x1122dc000 - 0x1127f1ff7 +org.qt-project.QtWidgets (5.5 - 5.5.1) <1AF6065B-6055-3DC7-B92D-AA106307735B> /Library/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x1129ae000 - 0x112e42fff +org.qt-project.QtGui (5.5 - 5.5.1) <64584329-006F-386F-B498-C7D0E5FC241E> /Library/Frameworks/QtGui.framework/Versions/5/QtGui
0x112f7f000 - 0x113027fff +libqcocoa.dylib (0) <56ADBA40-C8E0-38A5-8C62-B485E4784B5D> /Library/Frameworks/QtPlugins/plugins/platforms/libqcocoa.dylib
0x113084000 - 0x1130ebfff +org.qt-project.QtDBus (5.5 - 5.5.1) <245EE4C3-2FE2-3C91-92A3-F2E781973C9A> /Library/Frameworks/QtDBus.framework/Versions/5/QtDBus
0x113116000 - 0x11314bfff +org.qt-project.QtPrintSupport (5.5 - 5.5.1) <9F5C686D-7C6D-327D-8D1A-DEF6977D4004> /Library/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
0x114b41000 - 0x114bb6ff7 +net.nemetschek.vectorworks.VCSClient (1.0) <F8B30AD5-A653-3C64-A1AF-7235C2AE959A> /Applications/Vectorworks 2018/*/VCSClient
0x114bf0000 - 0x114c4bfff +net.nemetschek.vectorworks.VectorScriptEditor (1.0) <050D7AD1-5524-3396-B7D1-3AF888096A45> /Applications/Vectorworks 2018/*/VectorScriptEditor
0x114c6e000 - 0x114d97ff7 +com.sun.Scintilla (1.0) <57E3650E-5878-3AF1-84E9-4BA05D528C03> /Applications/Vectorworks 2018/*/Scintilla.framework/Versions/A/Scintilla
0x114df3000 - 0x1154c6fef +net.nemetschek.vectorworks.Support (1.0) <47B57DAA-B6F2-3886-AC0E-AFCC484E05A3> /Applications/Vectorworks 2018/*/Support
0x1157ab000 - 0x1157adff3 com.apple.textencoding.unicode (4.0 - 4.0) <B2304E3E-5ECA-30E0-8387-AFB1AE0B659D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x11583c000 - 0x1158fffff +net.nemetschek.vectorworks. (1.0) <FB729825-0643-3998-B8F0-B699F6977CF3> /Applications/Vectorworks 2018/*/VS Shared Library
0x115e0f000 - 0x11602aeff +net.nemetschek.vectorworks. (1.0) <0114E86E-FF6C-3B9E-B42A-8EBCC3E1D5D4> /Applications/Vectorworks 2018/*/Plug-In Support
0x1160be000 - 0x1162d8fff +net.nemetschek.vectorworks.Renderworks (1.0) <057E8C86-C985-3250-9C53-FA984EA75D0F> /Applications/Vectorworks 2018/*/Renderworks
0x117040000 - 0x11717bfff +net.nemetschek.vectorworks. (1.0) <2DE6EB00-A95B-3CC3-BF46-5F7F3FCED6E5> /Applications/Vectorworks 2018/*/3DS Library
0x11722c000 - 0x117367ff7 +net.nemetschek.vectorworks.Animation (1.0) <41FD72CB-C451-3A08-A228-934EDA151EFF> /Applications/Vectorworks 2018/*/Animation
0x1173fe000 - 0x117714ff7 +net.nemetschek.vectorworks.ArchitecturalObjects (1.0) <7A326F61-F14C-37B5-B902-99B4D81860CC> /Applications/Vectorworks 2018/*/ArchitecturalObjects
0x117816000 - 0x117ad1ff7 +com.deersoft.braceworxs.braceworxsvwxplg (0.13.2) <60975DA4-78C9-3E1F-9C72-72E0ECFF50D8> /Applications/Vectorworks 2018/*/BraceWorxsVwxPlg
0x117c2d000 - 0x118016fff +net.nemetschek.vectorworks.EnergyAnalysis (1.0) <794E99DA-D38F-3BDE-AE73-D432BB7207C7> /Applications/Vectorworks 2018/*/EnergyAnalysis
0x118214000 - 0x1183c8ff7 +net.nemetschek.vectorworks.GIS (1.0) <A0A1A37B-C7C7-36CF-BAF2-A8F4BA2BDE52> /Applications/Vectorworks 2018/*/GIS
0x118499000 - 0x11902cfe7 +libgdal.20.dylib (0) <F84040B7-44E4-3789-8D2B-EADD6EFD32EB> /Applications/Vectorworks 2018/*/libgdal.20.dylib
0x119486000 - 0x11973cfff +net.nemetschek.vectorworks.SpotlightModule (1.0) <05323D2D-1B84-3134-BAE1-7AA77A5D9C2B> /Applications/Vectorworks 2018/*/Spotlight
0x119850000 - 0x119935ff7 +net.nemetschek.vectorworks.DetailCallout (1.0) <C2337180-1270-334F-8B92-04339C393491> /Applications/Vectorworks 2018/*/DetailCallout
0x11999e000 - 0x119b82fff +net.nemetschek.vectorworks.Fundamentals (1.0) <9053FB57-A47F-3AE7-8126-BF63842798AE> /Applications/Vectorworks 2018/*/Fundamentals
0x119c6b000 - 0x11a2ebfff +net.nemetschek.vectorworks.LandscapeModule (1.0) <091134B1-E53D-3FCD-9DCD-96D4BAA96BC0> /Applications/Vectorworks 2018/*/Landscape
0x11a514000 - 0x11a79fff7 +net.nemetschek.vectorworks.LandscapeIrrigation (1.0) <827E0076-00AA-37E2-B6DF-8D07790DAD3C> /Applications/Vectorworks 2018/*/LandscapeIrrigation
0x11a8ba000 - 0x11aedafff +Raum CW (D23.0.3 R1 - 1.0) <9522A138-E8AE-342F-ABBF-88ED29F5F31C> /Applications/Vectorworks 2018/*/Raum CW
0x11b3ee000 - 0x11b556fff +net.nemetschek.vectorworks.TesterModule (1.0) <6D449E6B-66C1-35FE-BA88-4C312D984594> /Applications/Vectorworks 2018/*/StructuralMember
0x11b5fe000 - 0x11bbb4ff7 +de.computerworks.vectorworks.Treppen (D23.0.3 R1 - 1.0) <3047387E-FA36-39AF-AB33-89CBDA85025A> /Applications/Vectorworks 2018/*/Treppen
0x11c0a9000 - 0x11c1f8ff7 +net.nemetschek.vectorworks.VectorworksRemote (..) <33FA779D-C7D0-3E42-8940-46E91BC6EED3> /Applications/Vectorworks 2018/*/Vectorworks Remote
0x11c648000 - 0x11c6c6fff +net.nemetschek.vectorworks.Workspaces (1.0) <BE21420C-D696-3CE5-92E4-79243353DD4A> /Applications/Vectorworks 2018/*/Workspaces
0x120169000 - 0x1202a7ff3 +com.deersoft.GDTFExport (1.0) <6F1770BC-B1CC-3310-A9F4-04F78A6D334B> /Applications/Vectorworks 2018/*/VWGDTFExchange
0x120364000 - 0x1203bfff7 +net.nemetschek.vectorworks.UpdateCheck (1.0) <C667B728-4F4A-3F50-A052-2CC925905887> /Applications/Vectorworks 2018/*/UpdateCheck
0x1203e7000 - 0x123020fff +net.nemetschek.vectorworks. (1.0) <0A6C8D1D-9663-3ABB-B16F-BF0B06063C97> /Applications/Vectorworks 2018/*/DWG Library
0x123ec6000 - 0x124527ff7 +net.nemetschek.vectorworks.IFCLibrary (1.0) <42AAFB29-7058-3F1D-B41C-828A0940C078> /Applications/Vectorworks 2018/*/IFCLibrary
0x1246df000 - 0x124815fff +net.nemetschek.vectorworks.Export3DPDF (1.0) <49213AAA-A332-3363-BE1F-4FB4F23817FF> /Applications/Vectorworks 2018/*/Export3DPDF
0x1248a7000 - 0x1249eefff +net.nemetschek.vectorworks.TesterModule (1.0) <8F5305F6-4A3F-3553-A0DC-0C48F6BD0142> /Applications/Vectorworks 2018/*/OBJExporter
0x124a88000 - 0x124e44ff3 +libexiv2.26.0.0.dylib (0) <A0D2724E-5C06-34F8-A2CE-FC59EAA59046> /Applications/Vectorworks 2018/*/libexiv2.26.0.0.dylib
0x124f91000 - 0x1250f8ff7 +net.nemetschek.vectorworks.TesterModule (1.0) <25C596BC-C66F-3938-ACDA-6E1B8EB04CC4> /Applications/Vectorworks 2018/*/ExportWebGl
0x125af9000 - 0x125c03ff7 +net.nemetschek.vectorworks.PDFUtilityLib (1.0) <BEF5D29A-818C-3A42-B3A0-684F41CDADD1> /Applications/Vectorworks 2018/*/PDFUtilityLib
0x125c69000 - 0x125d1bfef +com.adobe.ICUConverter (4.0 - 4.0) <6787A609-28A2-0813-16F8-4C410B9A01C2> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x125d48000 - 0x125db5ff7 +com.adobe.ICUData (4.0 - 4.0) <563D24B9-1EC2-A553-E8BA-8D56FD7C3882> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x125dba000 - 0x125ed3ff7 +DL100ACE (101.0.14) <A8725993-7185-33CC-B1CD-9BD0B5CB615C> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100ACE.framework/Versions/A/DL100ACE
0x125f14000 - 0x125f6aff7 +DL100AdobeXMP (101.0.2) <86EEDA4B-CDA3-3408-BD25-FEE03534ECCC> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100AdobeXMP.framework/Versions/A/DL100AdobeXMP
0x125f8a000 - 0x126537fff +DL100AGM (101.0.23) <91FECB89-7118-3B7A-A56B-5BD1C7E9AC31> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100AGM.framework/Versions/A/DL100AGM
0x12679f000 - 0x1267d8fff +DL100ARE (101.0.6) <5BEC3796-0737-37E3-9242-AA1EB1F00426> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100ARE.framework/Versions/A/DL100ARE
0x1267fc000 - 0x12681aff7 +DL100AXE8SharedExpat (101.0.4) <0F1ED7BD-2B86-3D9D-87C7-1728A0D29D22> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100AXE8SharedExpat.framework/Versions/A/DL100AXE8SharedExpat
0x12682c000 - 0x126849fff +DL100BIB (101.0.5) <E172BAB4-C204-3681-B403-B3EE7EDF0C7C> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100BIB.framework/Versions/A/DL100BIB
0x126862000 - 0x126885ff7 +DL100BIBUtils (101.0.5) <368DB4F3-967E-3AE3-AA3A-3D3B7ABA35BA> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100BIBUtils.framework/Versions/A/DL100BIBUtils
0x1268a1000 - 0x126dccfff +com.datalogics.DL100CoolType (DL100CoolType 10.1.0.13 - 10.1.0.13) <B73980BE-CD1F-32EB-B3FF-279B8C5FE43A> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100CoolType.framework/Versions/A/DL100CoolType
0x126f9c000 - 0x127023fff +DL100JP2KLib (101.0.3) <178F9E7D-F62D-38B9-BFB1-3F8436C5FDD7> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100JP2KLib.framework/Versions/A/DL100JP2KLib
0x12703f000 - 0x127717ff7 +DL100PDFL (101.0.45) <2856B5F6-A0FE-3A50-9242-15AA84D969E8> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100PDFL.framework/Versions/A/DL100PDFL
0x129c20000 - 0x129c91ff7 +net.nemetschek.vectorworks.WebServices (1.0) <60A7F6FA-D69E-3FAD-8BE7-53DA98E08E0C> /Applications/Vectorworks 2018/*/WebServices
0x129d43000 - 0x12a9e3fff +net.nemetschek.vectorworks.PointCloud (1.0) <5F5C0435-C79B-355E-973A-0DD7D0EC5C1D> /Applications/Vectorworks 2018/*/PointCloud
0x12b296000 - 0x12b4bdfff +libxerces-c-3.1.dylib (0) <1950D4AB-692C-3EB0-A37F-520F462A04B0> /Applications/Vectorworks 2018/*/libxerces-c-3.1.dylib
0x12db9f000 - 0x12dd03fff +net.nemetschek.vectorworks.VWGraphicsModule (1.0) <25F74333-FD6A-30B2-B545-35F3043E21CA> /Applications/Vectorworks 2018/*/VWGraphicsModule
0x16b192000 - 0x16b1eeff7 +net.nemetschek.vectorworks.RenderSettings (1.0) <F6B34C8D-2EB4-3B4C-9C99-3B5145C993E9> /Applications/Vectorworks 2018/*/RenderSettings
0x170278000 - 0x17034bfff +net.nemetschek.vectorworks.SectionLine (1.0) <8E5EB638-6870-3868-8C9A-341E91FFEDEE> /Applications/Vectorworks 2018/*/SectionLine
0x1703b2000 - 0x170428fff +net.nemetschek.vectorworks.TaperedExtrude (1.0) <85851C7D-D162-3AFE-93CB-3342365D2D5F> /Applications/Vectorworks 2018/*/TaperedExtrude
0x170458000 - 0x17053cff7 +net.nemetschek.vectorworks. (1.0) <9967E84E-121D-3806-8E66-35335DBEEAD3> /Applications/Vectorworks 2018/*/ExtrudeAlongPath
0x190572000 - 0x1905bfff7 +net.nemetschek.vectorworks. (1.0) <723FD760-15C8-3E3F-B265-43152E04441D> /Applications/Vectorworks 2018/*/Fit To Objects
0x1c872c000 - 0x1c87f5ff7 +net.nemetschek.vectorworks.TesterModule (1.0) <945716BB-B988-3168-9598-BD7F00266B12> /Applications/Vectorworks 2018/*/PointTools
0x1c8b3b000 - 0x1c8c20ff7 +net.nemetschek.vectorworks. (1.0) <9CEACA85-4A88-35B5-848B-E561E2CC3BBA> /Applications/Vectorworks 2018/*/Offset Tool
0x1e8ff8000 - 0x1e9045fff +net.nemetschek.vectorworks.Guides (1.0) <787E9F72-D276-35C5-A706-68BDF74AACD0> /Applications/Vectorworks 2018/*/Guides
0x1e9144000 - 0x1e9165ffb +VectorworksRemoteServer (0) <C4568963-9F07-3D1C-937B-5F628EB75A67> /Applications/Vectorworks 2018/*/VectorworksRemoteServer.framework/VectorworksRemoteServer
0x1e95b7000 - 0x1e9799fff +net.nemetschek.vectorworks.NotesManager (1.0) <9F3B9F21-6A65-3FCF-9E05-E07CB331AC50> /Applications/Vectorworks 2018/*/NotesManager
0x1ea1ee000 - 0x1ea2fbfff +QtNetwork (5.3.2) <F6FAE5D5-FAA7-3F63-A3DB-A0D227F1A4EB> /Applications/Vectorworks 2018/*/VectorworksRemoteServer.framework/Libraries/QtNetwork.framework/Versions/5/QtNetwork
0x1ea361000 - 0x1ea895ff7 +QtCore (5.3.2) <94810710-91FA-308D-B210-3166F83FCA81> /Applications/Vectorworks 2018/*/VectorworksRemoteServer.framework/Libraries/QtCore.framework/Versions/5/QtCore
0x7fff3edf1000 - 0x7fff3f13fff7 com.apple.RawCamera.bundle (8.02.0 - 1017.2.2) <C799730B-C745-3775-BCE7-C67B8BD97FDB> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff3f387000 - 0x7fff3fbb1ff7 ATIRadeonX4000SCLib.dylib (1.60.26) <35CB9BC0-C664-38A7-96FA-0F07243E68D6> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff4290f000 - 0x7fff42913ffb com.apple.agl (3.3.1 - AGL-3.3.1) <5A110DE6-3EE7-343B-95FE-9642517D1B64> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff42914000 - 0x7fff42aeffff com.apple.avfoundation (2.0 - 1530.2) <30F528A4-548F-3E18-80A8-06481788E84C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff42af0000 - 0x7fff42baaff7 com.apple.audio.AVFAudio (1.0 - ???) <891340D8-A1F3-37B5-A183-EE5BE81F5296> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff42cb0000 - 0x7fff42cb0fff com.apple.Accelerate (1.11 - Accelerate 1.11) <5AA750F5-D633-32BA-B7F3-4F651FB1761E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff42cb1000 - 0x7fff42cc7fe3 libCGInterfaces.dylib (417) <27E09D39-51B5-3297-BE33-0DB1736B833A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff42cc8000 - 0x7fff431c6fc3 com.apple.vImage (8.1 - ???) <310976EE-E12D-39D7-8F58-6EE924E08576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff431c7000 - 0x7fff43321fcb libBLAS.dylib (1211.30.1) <0DB0D952-BCF4-3479-BA2F-785FB1A57479> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff43322000 - 0x7fff43350fef libBNNS.dylib (37) <49EB4DBA-877C-3D41-90A2-C3D982C72A54> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff43351000 - 0x7fff43711ff7 libLAPACK.dylib (1211.30.1) <2D4E4446-6B63-350C-BD68-A1B8FBE99539> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff43712000 - 0x7fff43727ff7 libLinearAlgebra.dylib (1211.30.1) <6C68F41D-1398-3AFE-BE72-C0ECA1B24BDC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff43728000 - 0x7fff4372dff3 libQuadrature.dylib (3) <3D6BF66A-55B2-3692-BAC7-DEB0C676ED29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff4372e000 - 0x7fff4378cfff libSparse.dylib (79.1.1) <7AD0F8A8-FD36-36FE-B83D-58648EBD0027> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff4378d000 - 0x7fff437a0fff libSparseBLAS.dylib (1211.30.1) <42506F6F-0F38-322E-9903-C1DB66E4DA05> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff437a1000 - 0x7fff4394dfc3 libvDSP.dylib (622.20.8) <6FFCA52B-7D60-326A-ADF2-601F39A8685A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff4394e000 - 0x7fff439fefef libvMisc.dylib (622.20.8) <54F90047-879F-3260-8604-6E453149B49E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff439ff000 - 0x7fff439fffff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <8A96A8ED-7B88-3D17-8D17-41D224E0EC90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff43a00000 - 0x7fff43a57ff7 com.apple.Accounts (113 - 113) <02AC0AF3-D620-340E-BE52-CD31119F9CD8> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff43a58000 - 0x7fff43ceefff com.apple.AddressBook.framework (11.0 - 1808.6) <1BE4B8EF-60A4-320C-91A5-5241E2118B82> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff43cef000 - 0x7fff44b4cfff com.apple.AppKit (6.9 - 1561.20.106) <AF59A3CF-E3C3-3046-86D9-0C9145E60CE4> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff44b9e000 - 0x7fff44b9efff com.apple.ApplicationServices (48 - 50) <7627DBD6-497B-3AB7-9B63-F0532EDF09B8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff44b9f000 - 0x7fff44c05fff com.apple.ApplicationServices.ATS (377 - 445) <CDF5F6D7-4E7D-3D28-9FBA-1B53AD9FA8F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff44c9e000 - 0x7fff44dc0fff libFontParser.dylib (222.1.2) <11BD5EEF-AF18-33FB-B114-DD611932E822> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff44dc1000 - 0x7fff44e0bff7 libFontRegistry.dylib (221) <A22F82C0-B4FE-3DB5-B968-79B28257DF2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff44eb0000 - 0x7fff44ee3ff7 libTrueTypeScaler.dylib (222.1.2) <33C245B4-E1AD-3C89-B735-5A5610E547C8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff44f4d000 - 0x7fff44f51ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <42C25E85-1CF3-3DEC-A434-BE69F68F4318> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff44ff1000 - 0x7fff45043ff7 com.apple.HIServices (1.22 - 622) <2E83CD6F-ED98-3C29-BD0A-8525E38AB5DB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff45044000 - 0x7fff45052fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <71A9C815-AC55-3E36-A618-F6778F5119AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff45053000 - 0x7fff4509ffff com.apple.print.framework.PrintCore (13 - 503) <A69E2BAD-2B66-38CC-9D3A-0A0EBC41341D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff450a0000 - 0x7fff450dafff com.apple.QD (3.12 - 403) <38D8106A-4FFA-3FE9-9999-714CADD7EE9C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff450db000 - 0x7fff450e7fff com.apple.speech.synthesis.framework (7.4.1 - 7.4.1) <9ABE85D9-6E4A-3CEF-AA09-F81E52730598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff450e8000 - 0x7fff45373fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <46EDC245-5877-3438-805C-3AA0316E3F5C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff45375000 - 0x7fff45375fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <0FC3B4FF-FFAB-3346-9A6A-C1DE033185EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff4568a000 - 0x7fff45a1cfff com.apple.CFNetwork (893.13.1 - 893.13.1) <3ECC6AD0-B47D-38D2-BF26-496B34847D25> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff45a31000 - 0x7fff45a31fff com.apple.Carbon (158 - 158) <FCD7A9FF-5E53-3B0C-8A52-691C11B2A0C5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff45a32000 - 0x7fff45a35ffb com.apple.CommonPanels (1.2.6 - 98) <39C8EBA3-EEB2-335B-8A88-D6C64BAA112F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff45a36000 - 0x7fff45d3bff7 com.apple.HIToolbox (2.1.1 - 910.4) <D1A799BC-146A-35E8-86FF-E36273123006> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff45d3c000 - 0x7fff45d3fffb com.apple.help (1.3.8 - 64) <18D02016-119A-33E8-AEB0-E9466BA4AD56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff45d40000 - 0x7fff45d45fff com.apple.ImageCapture (9.0 - 9.0) <2DE590E5-DF0E-3962-A2BE-06EBC79B3D72> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff45d46000 - 0x7fff45ddbffb com.apple.ink.framework (10.9 - 220) <D8AECAE3-9FD2-32E3-B659-026F33650BB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff45ddc000 - 0x7fff45df6ff7 com.apple.openscripting (1.7 - 174) <66899B51-ADFD-360D-88E9-B52439F531B4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff45e17000 - 0x7fff45e18fff com.apple.print.framework.Print (12 - 267) <E4CBAAFC-9045-38AC-9F93-8C931DDED9D8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff45e19000 - 0x7fff45e1bff7 com.apple.securityhi (9.0 - 55006) <E7668200-B4CB-3612-96B8-D57E94077787> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff45e1c000 - 0x7fff45e22fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1F10ED1F-12C7-39AC-88A0-43A1338F9316> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff45f2f000 - 0x7fff45f2ffff com.apple.Cocoa (6.11 - 22) <1553F279-3C7B-3A48-87E6-35237F7F452E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff45f3d000 - 0x7fff45ff6ff7 com.apple.ColorSync (4.13.0 - 546) <A5E013D9-7305-3026-879E-4D1F038A430D> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff46183000 - 0x7fff46216ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <F91FDE26-0702-3E44-8931-E2CAD8E36F5A> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff4627d000 - 0x7fff462a6ffb com.apple.CoreBluetooth (1.0 - 1) <942F88A5-AD68-3359-90D5-6F1A3311C51A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff462a7000 - 0x7fff465fbfe7 com.apple.CoreData (120 - 849.2) <CE0AF596-64C0-34F3-AFE0-B94D18C09957> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff465fc000 - 0x7fff466c8fff com.apple.CoreDisplay (1.0 - 81.7) <D8030B81-097E-3FA2-A85C-AE1A3B8EBCFB> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff466c9000 - 0x7fff46b69fe7 com.apple.CoreFoundation (6.9 - 1451) <7AFE9C8F-A562-3AFC-8402-117AA02F57E9> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff46b6b000 - 0x7fff47178fef com.apple.CoreGraphics (2.0 - 1129.5) <F37BFBD2-CC21-3521-B034-9D4D36197487> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff4717a000 - 0x7fff47469fff com.apple.CoreImage (13.0.0 - 579.2.9) <8AE143AB-6284-3B00-B56D-8C0C1826EF34> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff476f8000 - 0x7fff477d9fff com.apple.CoreMedia (1.0 - 2270.12.1) <B62CF714-D69A-38C3-9929-B70FF4CBB216> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff477da000 - 0x7fff47828fff com.apple.CoreMediaIO (812.0 - 4993) <CA47AF11-0EF4-33E1-9EC3-7A56661FFEE4> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff47829000 - 0x7fff47829fff com.apple.CoreServices (822.19 - 822.19) <44456ED2-59E4-34CB-B41B-C6A82B269949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff4782a000 - 0x7fff4789effb com.apple.AE (735.1 - 735.1) <D0C73200-90A7-3FD1-A6EC-97055AA367E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff4789f000 - 0x7fff47b76ff7 com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <A1FE74F8-953B-371E-A8AC-E87B30FB79C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff47b77000 - 0x7fff47babff7 com.apple.DictionaryServices (1.2 - 284) <3FCEE280-8DD0-37C9-BFD4-7BA87AAFC8EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff47bac000 - 0x7fff47bb4ff3 com.apple.CoreServices.FSEvents (1239 - 1239) <7BBC5CB7-DBC8-316B-99B0-781827159A2F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff47bb5000 - 0x7fff47d6dff7 com.apple.LaunchServices (822.19 - 822.19) <2895A919-0445-3CE2-9696-40122B5A46C5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff47d6e000 - 0x7fff47e1dff7 com.apple.Metadata (10.7.0 - 1191.2.6) <FB66B298-D55D-398A-BEDB-CB7B82956AE5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff47e1e000 - 0x7fff47e7bff7 com.apple.CoreServices.OSServices (822.19 - 822.19) <34BF1FAC-A0F7-37B4-950D-46408EBA9684> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff47e7c000 - 0x7fff47eeafff com.apple.SearchKit (1.4.0 - 1.4.0) <14053F88-2C76-35CA-9FC1-2A9BC0B63F88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff47eeb000 - 0x7fff47f0fffb com.apple.coreservices.SharedFileList (71.4 - 71.4) <4AA6DCF5-BAF8-36FA-A8B0-EDF518EFEF14> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff481aa000 - 0x7fff482f8fff com.apple.CoreText (352.0 - 578.12.1) <55B16B2D-F083-3B89-A5C2-52FB053331F2> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff482f9000 - 0x7fff48333ff3 com.apple.CoreVideo (1.8 - 279.2) <A8FC5325-D092-3A28-A1CF-5C94B8101F71> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff48334000 - 0x7fff483beffb com.apple.framework.CoreWLAN (13.0 - 1339) <16DDD47C-BBFE-3D49-8BDF-3652017240FD> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff4854c000 - 0x7fff48557ff7 com.apple.DirectoryService.Framework (10.13 - 207) <79F272D7-48AE-3D1E-AC5B-3CEB5F16E7D5> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff48558000 - 0x7fff48612fff com.apple.DiscRecording (9.0.3 - 9030.4.5) <2094BAC4-4F37-3741-B9BD-60158A63C503> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff48639000 - 0x7fff4863efff com.apple.DiskArbitration (2.7 - 2.7) <44836CE9-A9ED-3017-972A-7A0A3D6B472B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff487d8000 - 0x7fff487daff3 com.apple.ExceptionHandling (1.5 - 12) <47D558A6-45B1-3A1A-A619-9CA52225CB49> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
0x7fff487ff000 - 0x7fff48bc4fff com.apple.Foundation (6.9 - 1451) <B99F94E7-117E-39CC-A65D-B7AEA8998481> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff48c34000 - 0x7fff48c64fff com.apple.GSS (4.0 - 2.0) <3B4B4509-B5A3-396B-9C71-80BAE84476FA> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff48d76000 - 0x7fff48e79ff3 com.apple.Bluetooth (6.0.2 - 6.0.2f2) <718565B3-6DA7-3DF9-BB51-391FFCAEAFA5> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff48ed9000 - 0x7fff48f74fff com.apple.framework.IOKit (2.0.2 - 1445.40.1) <9CFA07B9-BA6E-31E4-AD4F-C47071A8C522> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff48f76000 - 0x7fff48f7dffb com.apple.IOSurface (209.2.2 - 209.2.2) <6D35A601-1C47-37BE-AD31-F8EB88F67573> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff48f7e000 - 0x7fff48fd3ff3 com.apple.ImageCaptureCore (7.0 - 7.0) <CBE349D4-2C8B-31F5-B5ED-B8E978DA9245> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff48fd4000 - 0x7fff4914bff7 com.apple.ImageIO.framework (3.3.0 - 1713) <D3CE3838-72C5-3860-B3A4-6937FD916329> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff4914c000 - 0x7fff49150ffb libGIF.dylib (1713) <C65B2846-1B94-3BB3-BBBF-5A9E5054CE1E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff49151000 - 0x7fff49238fff libJP2.dylib (1713) <332083DD-3D27-3DE7-9866-A36D590E511E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff49239000 - 0x7fff4925cff7 libJPEG.dylib (1713) <2D846A18-D8AF-3573-803B-BEABCBAC38D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff49538000 - 0x7fff4955efeb libPng.dylib (1713) <546F41CE-185C-31A0-B61C-1012AA932624> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff4955f000 - 0x7fff49561ffb libRadiance.dylib (1713) <31787C46-4A2B-3CDF-95E9-EC1BD4794917> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff49562000 - 0x7fff495affeb libTIFF.dylib (1713) <5319B2E1-83D2-30C7-A7BC-A0CE0B07885D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff4976b000 - 0x7fff4a326fff com.apple.JavaScriptCore (13604 - 13604.5.6) <5541E211-3248-3B89-9AE9-D5FE413F12D1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff4a33e000 - 0x7fff4a357ff7 com.apple.Kerberos (3.0 - 1) <CAF075C0-4C24-3ACE-9AE6-77BEFDEA3622> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff4a358000 - 0x7fff4a38dfff com.apple.LDAPFramework (2.4.28 - 194.5) <8419BDB5-12DF-3BC9-871D-7A270E080249> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff4a60f000 - 0x7fff4a616fff com.apple.MediaAccessibility (1.0 - 114) <D72C593A-AC32-3419-AB86-6B07217EBFD5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff4a6b9000 - 0x7fff4acd4fff com.apple.MediaToolbox (1.0 - 2270.12.1) <40802884-1347-3CDC-AAD3-D046463A528E> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff4acd6000 - 0x7fff4ad55fff com.apple.Metal (124.7 - 124.7) <F161C177-80B4-3674-8147-04343702CF08> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff4ad72000 - 0x7fff4ad87fff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <D4BCBA84-AD1B-33DC-99F3-16F9E5E50906> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff4ad88000 - 0x7fff4adf3fef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <E504EC97-FAD7-36DC-B151-6F89AB911E3A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff4adf4000 - 0x7fff4ae17fff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <A5B6F6FC-A19A-32C0-A999-98B6688760C7> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff4ae18000 - 0x7fff4ae98ff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <D0D8F13F-ACD4-3B61-BE54-121CCB05ECF4> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff4ae99000 - 0x7fff4ae99ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <2E8723FC-AA53-3596-B6A4-220A378B7A5A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff4bea2000 - 0x7fff4beaeffb com.apple.NetFS (6.0 - 4.0) <81B22AE7-7094-30F2-BF41-84CA05EDB95B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff4ec96000 - 0x7fff4ec9efef libcldcpuengine.dylib (2.8.7) <DD781325-D94E-3AD7-8D6C-817FB3068917> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff4ec9f000 - 0x7fff4ececffb com.apple.opencl (2.8.12 - 2.8.12) <7F9BF7F0-AFB2-349A-BF9B-2DE5288380C4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff4eced000 - 0x7fff4ed09ffb com.apple.CFOpenDirectory (10.13 - 207) <A229B355-337B-33F4-AAA8-C751BEF0B718> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff4ed0a000 - 0x7fff4ed15fff com.apple.OpenDirectory (10.13 - 207) <D8AA4C58-149E-3504-88CD-F5B59F882C25> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff4fe94000 - 0x7fff4fe96fff libCVMSPluginSupport.dylib (16.4.2) <A967BC8B-ABB3-393F-BF34-BD32B45831F7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff4fe97000 - 0x7fff4fe9bff7 libCoreFSCache.dylib (162.4) <B325B709-0C81-357A-B9F1-6E0027B64F9B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff4fe9c000 - 0x7fff4fea0fff libCoreVMClient.dylib (162.4) <B129DB84-39BA-34E4-9FB7-20A020A1BB86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff4fea1000 - 0x7fff4fea9fff libGFXShared.dylib (16.4.2) <07F1D947-F79B-3608-9080-E4DBFE13AF1D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff4feaa000 - 0x7fff4feb5fff libGL.dylib (16.4.2) <97D6871A-BAF1-33DD-9ED7-BE7BB437F378> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff4feb6000 - 0x7fff4fef1fe7 libGLImage.dylib (16.4.2) <3E2802DF-4998-31DB-B3A2-65720DE919A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff4fef2000 - 0x7fff5005efff libGLProgrammability.dylib (16.4.2) <3505EF20-FA3D-321B-8C11-D9CA74656F30> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff5005f000 - 0x7fff5009dffb libGLU.dylib (16.4.2) <ECABCFAB-E400-3667-8EE1-586C07E0E214> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff50a15000 - 0x7fff50a23ffb com.apple.opengl (16.4.2 - 16.4.2) <C8C31EF5-8DB4-336F-A87C-5D520C7EFDC5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff50a24000 - 0x7fff50bbbffb GLEngine (16.4.2) <8F35484D-9C09-3D79-9825-7E73661326D4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff50bbc000 - 0x7fff50be4ffb GLRendererFloat (16.4.2) <463BD481-6E1A-3EFC-A93B-C7E9292F76ED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff50d9b000 - 0x7fff50ee7fff com.apple.QTKit (7.7.3 - 3014) <CF2818E6-E215-3C24-A2AC-1B5F8AD7E398> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff50ee8000 - 0x7fff5114dff7 com.apple.imageKit (3.0 - 1040) <5A1261EA-76C5-386C-9F46-06EE804E2234> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff5114e000 - 0x7fff5123aff3 com.apple.PDFKit (1.0 - 677.4) <265C1FB2-4E62-3498-A86B-02C0F790F1ED> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff5123b000 - 0x7fff5174dff7 com.apple.QuartzComposer (5.1 - 364) <D99600D5-C066-3D49-8641-369A69300D16> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff5174e000 - 0x7fff51771fff com.apple.quartzfilters (1.10.0 - 1.10.0) <8CBE10F3-828F-373C-B92A-A5289CBCF77A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff51772000 - 0x7fff51869ff7 com.apple.QuickLookUIFramework (5.0 - 743.7) <B0352E2A-C582-3C86-A2ED-A30D4A3B785D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff5186a000 - 0x7fff5186afff com.apple.quartzframework (1.5 - 21) <3F3BE91F-A032-3E92-ACEA-E2DFEC999E93> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff5186b000 - 0x7fff51ab3fff com.apple.QuartzCore (1.11 - 584.8.102) <4479AF33-E6EA-3037-A2C1-3C6F12B1260A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff51ab4000 - 0x7fff51b0bff7 com.apple.QuickLookFramework (5.0 - 743.7) <0CB6717C-CCE2-3591-A31E-A8EF01DD4FC8> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff51cd0000 - 0x7fff51ce6fff com.apple.SafariServices.framework (13604 - 13604.5.6) <D71DE52A-9B30-381B-82CA-57473E7A0E7E> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff522ec000 - 0x7fff52603ff7 com.apple.security (7.0 - 58286.41.2) <EB297497-884A-362F-B566-73A14A2F25FE> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff52604000 - 0x7fff5268eff7 com.apple.securityfoundation (6.0 - 55185.30.4) <65144003-B9E2-3DE3-8923-F2BAA68BBF4E> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff5268f000 - 0x7fff526bfff3 com.apple.securityinterface (10.0 - 55109.30.2) <8BFD22AB-32C9-3AD1-9CB4-39EA2D18E865> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff526c0000 - 0x7fff526c3ffb com.apple.xpc.ServiceManagement (1.0 - 1) <B11C3C64-6FE7-3A78-B583-D790B7CCE95A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff52a68000 - 0x7fff52ad8ff3 com.apple.SystemConfiguration (1.17 - 1.17) <3C6B2BB9-43AB-39AD-8027-38E30A8A4186> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff52c8d000 - 0x7fff53006ff7 com.apple.VideoToolbox (1.0 - 2270.12.1) <77848D39-10DA-3AA3-88F4-2898F42FCA5A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff532ae000 - 0x7fff537c6fe7 libwebrtc.dylib (7604.5.6) <7C956A2C-8F14-310F-AE27-CCDA9F64AAE5> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff537c7000 - 0x7fff54caeff7 com.apple.WebCore (13604 - 13604.5.6) <558072BF-6134-3C19-B32E-4889C5C06C5C> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff54caf000 - 0x7fff54ea2ff3 com.apple.WebKitLegacy (13604 - 13604.5.6) <E0177202-32F5-3D0F-9F80-85F41AFF049E> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff54ea3000 - 0x7fff5529bff7 com.apple.WebKit (13604 - 13604.5.6) <5AB44A86-7C8C-3F24-A76B-80618F164763> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff5570b000 - 0x7fff55797ff7 com.apple.APFS (1.0 - 1) <9D67579C-7FB4-3AD9-AB4F-9174A552EB37> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff563aa000 - 0x7fff563d2fff com.apple.framework.Apple80211 (13.0 - 1345) <D1B8340A-41FB-35C3-88F0-3DDD9A2A1999> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff563d4000 - 0x7fff563e3ff7 com.apple.AppleFSCompression (96.30.2 - 1.0) <CFA90544-68EB-3CCE-A8F7-1B03974F3B85> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff5651f000 - 0x7fff56567ff3 com.apple.AppleJPEG (1.0 - 1) <8BBD5180-5BF9-33DB-8B91-974B1D0AECFB> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff5657a000 - 0x7fff56598ff3 com.apple.aps.framework (4.0 - 4.0) <932274E4-DCD5-30D5-9AC7-58CEF4571EB3> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff56599000 - 0x7fff565a1ff3 com.apple.AppleSRP (5.0 - 1) <4CEC34CF-63E3-3023-B61B-F8D133698534> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff565a2000 - 0x7fff565cafff com.apple.applesauce (1.0 - ???) <32FF4851-2F68-35BA-835F-91856A20C323> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff56693000 - 0x7fff56696ff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <A6795AC1-D528-3A2F-9C43-14EBFC57B7D6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff56697000 - 0x7fff566e7ff7 com.apple.AppleVAFramework (5.0.39 - 5.0.39) <4B830521-2A54-3116-8103-127E631FEDC8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff56db6000 - 0x7fff56dbdff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <47B6301F-D908-3811-BB9E-DA16D9B29A34> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff56dbe000 - 0x7fff56e45ff7 com.apple.backup.framework (1.9.2 - 1.9.2) <40C6CFA8-4013-3AFB-97CE-8A09388FA343> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff56ebb000 - 0x7fff56ef7fff com.apple.bom (14.0 - 194.2) <ED2FFB9D-4DA4-322B-89C0-102D790649CD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff57515000 - 0x7fff57542fff com.apple.CalendarAgentLink (8.0 - 250) <55B60B04-2EAA-3F22-88EF-1602129D5294> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fff57c09000 - 0x7fff57c58ff3 com.apple.ChunkingLibrary (188 - 188) <84E024A0-5F95-3A30-A60B-102343AE46B7> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff57c5f000 - 0x7fff57cefff7 com.apple.CloudDocs (1.0 - 572.2) <7549FED5-7C41-3E3E-ABB4-34DCB312F8A2> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff587d5000 - 0x7fff587deff3 com.apple.CommonAuth (4.0 - 2.0) <11B2D184-36B8-3624-B1AD-7B6037D76160> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff587f3000 - 0x7fff58808ff7 com.apple.commonutilities (8.0 - 900) <518FBC2C-0AF3-39DF-B454-526311796A49> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff5898c000 - 0x7fff589ecfff com.apple.AddressBook.ContactsFoundation (8.0 - ???) <9B39DF3E-5B7F-3467-AC17-23258F76A376> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff589ed000 - 0x7fff58a0ffff com.apple.contacts.ContactsPersistence (1.0 - 2330.3) <EE8079D4-E1E2-3EFF-A7E1-E97BD81F6C6F> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff58a6f000 - 0x7fff58e4ffff com.apple.CoreAUC (249.0.0 - 249.0.0) <7F406271-A215-3C75-BDAA-B9611BA2822E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff58e50000 - 0x7fff58e80ff7 com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <D0879D8F-488A-3D46-BC50-AD7B0642C0E8> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff5907b000 - 0x7fff59084ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <0A87A91C-A2CF-3BB1-9038-7F610111BC30> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff591eb000 - 0x7fff591fbff7 com.apple.CoreEmoji (1.0 - 69.3) <A4357F5C-0C38-3A61-B456-D7321EB2CEE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff59ab6000 - 0x7fff59accff7 com.apple.CoreMediaAuthoring (2.2 - 956) <A5003E93-68B3-3A0E-8252-454CC4CFEC4D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff59c0e000 - 0x7fff59c6bff7 com.apple.CoreNLP (1.0 - 130.4.1) <1F329E38-E7D0-3455-981B-48F434C9E8CC> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff59df4000 - 0x7fff59df9ff7 com.apple.CoreOptimization (1.0 - 1) <785B622B-8F7D-3B4D-83AF-EB98CB79FFF6> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff59dfa000 - 0x7fff59e9fff7 com.apple.CorePDF (4.0 - 414) <2F0447DB-826B-3CEC-A98C-B8A8DDEA1B26> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff59f3f000 - 0x7fff59f47ff7 com.apple.CorePhoneNumbers (1.0 - 1) <B782FEA6-ACAD-34C6-811F-635F319C3B71> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff59f48000 - 0x7fff59fa4fff com.apple.CorePrediction (1.0 - 1) <B1E687BA-4E62-321B-8C87-D37C540A5A68> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff5a0d1000 - 0x7fff5a102ff3 com.apple.CoreServicesInternal (309.1 - 309.1) <EB09CAFC-AE9B-3257-BE45-5471D9F64AAD> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff5a451000 - 0x7fff5a4e2fff com.apple.CoreSymbolication (63075) <2458D96C-1C31-34F8-93F0-73DB0042CB30> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff5a565000 - 0x7fff5a699fff com.apple.coreui (2.1 - 492.2) <FE0B32BC-958D-3445-866E-A3905626396D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff5a69a000 - 0x7fff5a7a5fff com.apple.CoreUtils (5.3 - 530.60) <D74B16CC-E2C5-3D8A-B9F4-6D1DB23092B1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff5a7fa000 - 0x7fff5a85efff com.apple.framework.CoreWiFi (13.0 - 1339) <7EBA8BA5-C650-3067-A805-8DD08FC816FD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff5a85f000 - 0x7fff5a86eff7 com.apple.CrashReporterSupport (10.13 - 1) <6B5B2B78-15D2-363F-BE34-8F9226E79E24> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff5a8eb000 - 0x7fff5a8faff7 com.apple.framework.DFRFoundation (1.0 - 191.1) <87B83349-C317-3E07-894C-5BC5C20AE08B> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff5a8fd000 - 0x7fff5a901ffb com.apple.DSExternalDisplay (3.1 - 380) <BEC07C7C-F3AC-3CF3-B13E-3EBFD6224C0D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff5a946000 - 0x7fff5a986ffb com.apple.datadetectors (5.0 - 376) <612C677D-BB71-35D2-BBF3-EA9EC51ADF12> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fff5a987000 - 0x7fff5a9fdfff com.apple.datadetectorscore (7.0 - 590.3) <792593BC-21C7-3E0C-929E-067CD725FCBD> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff5aa4b000 - 0x7fff5aa8bff7 com.apple.DebugSymbols (141 - 141) <99562E28-0E56-3F6F-93A1-EF997A5E1F87> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff5aa8c000 - 0x7fff5abbbfff com.apple.desktopservices (1.12.2 - 1.12.2) <8E068AF7-FB72-38E2-948E-6C13F359C69D> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff5ac1b000 - 0x7fff5ac1cff7 com.apple.diagnosticlogcollection (10.0 - 1000) <DFD57FDB-CB78-3FB0-B49B-4586F9E0DFC1> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x7fff5acae000 - 0x7fff5ad80ff7 com.apple.DiskImagesFramework (480.30.2 - 480.30.2) <4A7D01B5-0A30-3425-AC35-D349EC10454F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff5ad81000 - 0x7fff5adf8ff7 com.apple.DiskManagement (11.2 - 1339) <0B17E79A-0BF6-3FD8-8AD0-A8498545030F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff5adf9000 - 0x7fff5ae04ff7 com.apple.DisplayServicesFW (3.1 - 380) <FB1FBB24-7FD5-3B57-8D3C-39F953F8A9BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff5ae8c000 - 0x7fff5ae8eff7 com.apple.EFILogin (2.0 - 2) <5B6E5A73-C2B2-3188-ADE9-C29CE29BB225> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff5b5da000 - 0x7fff5b5f2fff com.apple.Engram (1.0 - 1) <93DC8AE3-B3F7-326E-93DB-C85A2BFD3C3F> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
0x7fff5b930000 - 0x7fff5bd5efff com.apple.vision.FaceCore (3.3.2 - 3.3.2) <80C97AD7-D5C2-311A-B268-4AA60CAD6CED> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff5bd91000 - 0x7fff5be1aff7 com.apple.FileProvider (124.1 - 124.1) <5BF434E7-7675-3877-B761-0281418BC633> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff5d9c6000 - 0x7fff5d9c6fff libmetal_timestamp.dylib (802.3.14) <567B1E2F-A6C4-3350-A72E-AF0E0C4A7788> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3802/Libraries/libmetal_timestamp.dylib
0x7fff5f026000 - 0x7fff5f031ff7 libGPUSupportMercury.dylib (16.4.2) <F5BA5D7A-FD23-3416-B9B3-7EABFD4279D5> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff5f3ce000 - 0x7fff5f3f3ff3 com.apple.GenerationalStorage (2.0 - 285) <07E7BC5F-8EF2-34FC-9EEC-B4E61EAAFA9A> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff5fd72000 - 0x7fff5fd81fff com.apple.GraphVisualizer (1.0 - 5) <0A93C5DE-0D28-312E-8764-6B0FB805ED91> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5fdf9000 - 0x7fff5fe6dfff com.apple.Heimdal (4.0 - 2.0) <ACC132E5-97F1-3B36-AD7B-4E6CC077E691> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5fe6e000 - 0x7fff5fe9bfff com.apple.HelpData (2.3 - 158) <4508839C-39FC-31FD-9AB8-A7ADA9284F5C> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff5ff07000 - 0x7fff60019ff3 com.apple.ids (10.0 - 1000) <F85463DF-6D86-33C6-B740-498B29D7ECC6> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x7fff6001a000 - 0x7fff600f8fff com.apple.idsfoundation (10.0 - 1000) <BE207DF9-8609-3A80-9132-87FEB8E817B6> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x7fff605ff000 - 0x7fff60665ff3 com.apple.imfoundation (10.0 - 1000) <32799DD1-91A2-3093-8D8C-4F4988560FC2> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fff60715000 - 0x7fff6071efff com.apple.IOAccelMemoryInfo (1.0 - 1) <E062BBA9-0857-384E-978B-4C6346825E51> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff6071f000 - 0x7fff60726ffb com.apple.IOAccelerator (376.6 - 376.6) <A47129CC-F386-3C31-AD66-C19A70615A50> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff6072a000 - 0x7fff60741fff com.apple.IOPresentment (1.0 - 32.1) <B95F06EA-9D5D-311D-9912-978AE42ECFCE> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff60b0b000 - 0x7fff60b30fff com.apple.IconServices (97.4 - 97.4) <C84A6CA5-8C50-3288-8572-CC3DABF5BBCE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff60c3a000 - 0x7fff60c3dff3 com.apple.InternationalSupport (1.0 - 1) <5AB382FD-BF81-36A1-9565-61F1FD398ECA> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff60cab000 - 0x7fff60cbbffb com.apple.IntlPreferences (2.0 - 227) <0FF7209B-0E4D-3411-B325-03938B7C0938> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff60dc5000 - 0x7fff60ebafff com.apple.LanguageModeling (1.0 - 159.3.1) <9B08E18E-69B4-3413-A03A-EF5AE4BE6277> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff60ebb000 - 0x7fff60efdff7 com.apple.Lexicon-framework (1.0 - 33.2) <5CC5E8EE-62A1-3EA5-B300-A39ABD0CF12D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff60f01000 - 0x7fff60f08ff7 com.apple.LinguisticData (1.0 - 238.3) <228AF7CA-649A-3E24-BBC7-8A24B39B3FC4> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff60fef000 - 0x7fff60ff4fff com.apple.LoginUICore (4.0 - 4.0) <33D9089B-ECDB-361D-973A-1FDDACC5BFDF> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff61040000 - 0x7fff6105dff3 com.apple.LookupFramework (1.2 - 239) <ACECB15D-1C21-3D3D-A4C5-F9736090E741> /System/Library/PrivateFrameworks/Lookup.framework/Versions/A/Lookup
0x7fff6172c000 - 0x7fff6172ffff com.apple.Mangrove (1.0 - 1) <13832222-8A6B-3790-8914-BE874B5ED4DD> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff617b8000 - 0x7fff617baff7 com.apple.marco (10.0 - 1000) <86E99D5C-D56D-3874-B465-833A9B40DE88> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fff61848000 - 0x7fff6187bff7 com.apple.MediaKit (16 - 871) <47A5B872-4139-315D-A047-581F9C485D15> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff61b6a000 - 0x7fff61bd3ff7 com.apple.gpusw.MetalTools (1.0 - 1) <F77943BC-0466-3700-BEDF-CDD13125D36A> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff61bdb000 - 0x7fff61bf0ff3 com.apple.MobileAssets (1.0 - 437.40.1) <589D6786-0C0F-3CDB-8093-3834402CE083> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff61d48000 - 0x7fff61d60ff3 com.apple.MobileKeyBag (2.0 - 1.0) <4C70F92C-BB58-393E-B613-EAB16790CCED> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff61dec000 - 0x7fff61e14fff com.apple.MultitouchSupport.framework (1204.13 - 1204.13) <6C5D778D-4AB7-39A4-989B-2E8D2D57B3A0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff62079000 - 0x7fff62084fff com.apple.NetAuth (6.2 - 6.2) <5C6F492A-28EF-3A0E-B573-6F3D60CFF0C7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff62091000 - 0x7fff6215eff7 com.apple.Network (1.0 - 1) <0221BFB3-3174-3D87-B6F2-4557367B770B> /System/Library/PrivateFrameworks/Network.framework/Versions/A/Network
0x7fff63886000 - 0x7fff638c6ffb com.apple.PerformanceAnalysis (1.183.1 - 183.1) <2BE359F2-DCE6-3E33-BA99-964507A3F540> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff6393e000 - 0x7fff6393eff7 com.apple.PhoneNumbers (1.0 - 1) <F8D10107-164F-39BE-8A3D-638E90678DDD> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff6564e000 - 0x7fff656a1fff com.apple.ProtectedCloudStorage (1.0 - 1) <BA92C805-2AAD-3C71-A8EC-C2A4DAFD5E7C> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff656a2000 - 0x7fff656c0fff com.apple.ProtocolBuffer (1 - 259) <D047A3FE-C7A8-3CAA-9891-6232BA88C247> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff6582d000 - 0x7fff65842ff3 com.apple.QuickLookThumbnailing (1.0 - 1) <0771325B-BBAD-3865-B2A3-BE7089641C52> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff65891000 - 0x7fff6589cfff com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.30.29) <E2AEA0D7-23E6-3198-96EF-2F1F8ACD98B4> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff6589d000 - 0x7fff658c0ffb com.apple.RemoteViewServices (2.0 - 125) <AEDBCE8C-88B7-315A-9F81-3E068F0D3EDC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff658c1000 - 0x7fff658d2ffb com.apple.xpc.RemoteXPC (1.0 - 1205.30.29) <1FD53EC6-A9E9-3AEC-86A7-C52729D1A135> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff671dd000 - 0x7fff672eefff com.apple.Sharing (972.14 - 972.14) <964AEC2D-8A2A-33BE-9334-98A7CBE7CC51> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff672ef000 - 0x7fff6730eff3 com.apple.shortcut (2.16 - 98) <B8A517F6-B872-3A71-B096-709A0CC6656F> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff67318000 - 0x7fff67319fff com.apple.performance.SignpostNotification (1.0 - 1) <D4C967BA-92C6-3BAB-AFB5-59F98B35F921> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0x7fff68016000 - 0x7fff682b0fff com.apple.SkyLight (1.600.0 - 312.23.4) <455CE6F6-CD58-3E08-8300-CA8BDD3377FC> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff68a61000 - 0x7fff68a6eff7 com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <AC026FB9-78F8-31F9-BB80-619D5378DB70> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff68b21000 - 0x7fff68d5cfff com.apple.spotlight.index (10.7.0 - 1191.2.6) <236BC19C-F361-344B-91DE-1B40C6E31878> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff68f07000 - 0x7fff68f2eff7 com.apple.StreamingZip (1.0 - 1) <F06F4CDC-138C-3991-A987-7C7332BE4508> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff69600000 - 0x7fff69684fe7 com.apple.Symbolication (9.0 - 63079.1) <177BC9CA-E6AE-3B40-806F-0080C0CDFF29> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff69695000 - 0x7fff6969cfff com.apple.SymptomDiagnosticReporter (1.0 - 820.30.7) <0188BA8D-0C88-3413-A199-666C7FBE4DF1> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff69946000 - 0x7fff69972fff com.apple.framework.SystemAdministration (1.0 - 1.0) <6AE03DE8-E5C1-38E5-B788-0A763CAACDC2> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff69b76000 - 0x7fff69b7dff3 com.apple.TCC (1.0 - 1) <C807D3F0-FE20-3FC0-8D61-306477ABEBC4> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff69d8a000 - 0x7fff69e47ff7 com.apple.TextureIO (3.7 - 3.7) <C98BFACA-7807-3DCA-945D-58EBA2B723C8> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff69e98000 - 0x7fff69eb3ffb com.apple.ToneKit (1.0 - 1) <A0242052-983B-3726-B5BD-D2E672CEFE2F> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff69eb4000 - 0x7fff69edbfff com.apple.ToneLibrary (1.0 - 1) <7EEABD7F-D0CB-327E-A772-ACF406B9C8F2> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff69eeb000 - 0x7fff69eecfff com.apple.TrustEvaluationAgent (2.0 - 31) <39F533B2-211E-3635-AF47-23F27749FF4A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff69ef2000 - 0x7fff6a0a1ff3 com.apple.UIFoundation (1.0 - 546.1.1) <D2DB451C-56CD-3249-B8EE-AF21DBDCFBF8> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff6ad6a000 - 0x7fff6ae39ff7 com.apple.ViewBridge (343.2 - 343.2) <B23D10F2-A5E8-30EF-964A-6E968F4017A1> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff6b7e4000 - 0x7fff6b7e6ffb com.apple.loginsupport (1.0 - 1) <5E2C4AA7-066D-3FDB-B0E1-4CDAF287392C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6b7e7000 - 0x7fff6b7fcfff com.apple.login (3.0 - 3.0) <140118A7-8FB9-35C5-92FA-BD79C9C32309> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff6b827000 - 0x7fff6b854fff com.apple.contacts.vCard (1.0 - 2330.3) <0417A3AE-7A95-37DB-895B-33EAAC7A1422> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff6b94a000 - 0x7fff6b97dfff libclosured.dylib (519.2.2) <48051216-5647-3643-B979-B77D0FD20011> /usr/lib/closure/libclosured.dylib
0x7fff6ba1d000 - 0x7fff6ba56ff7 libCRFSuite.dylib (41) <AB2DA745-F22C-30CF-81D4-35DD716463B8> /usr/lib/libCRFSuite.dylib
0x7fff6ba57000 - 0x7fff6ba62fff libChineseTokenizer.dylib (28) <D30A7DB6-058F-3286-9583-60C9EEB77A6E> /usr/lib/libChineseTokenizer.dylib
0x7fff6ba63000 - 0x7fff6baf0ff7 libCoreStorage.dylib (546) <B495D87B-FE21-3C14-9017-F02D9CA226D5> /usr/lib/libCoreStorage.dylib
0x7fff6baf4000 - 0x7fff6baf5ff3 libDiagnosticMessagesClient.dylib (104) <9712E980-76EE-3A89-AEA6-DF4BAF5C0574> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6bb2c000 - 0x7fff6bcf6ff3 libFosl_dynamic.dylib (17.7) <B2476843-7FA7-3E62-B79F-2B15FE557E63> /usr/lib/libFosl_dynamic.dylib
0x7fff6bd2e000 - 0x7fff6bd2efff libOpenScriptingUtil.dylib (174) <203D2C39-61BB-3713-A502-2D17B04A42AC> /usr/lib/libOpenScriptingUtil.dylib
0x7fff6be57000 - 0x7fff6be5bffb libScreenReader.dylib (562.13) <21638ECC-87BF-3CC5-B2D8-6F7883F5FDCA> /usr/lib/libScreenReader.dylib
0x7fff6be5c000 - 0x7fff6be5dff3 libSystem.B.dylib (1252) <47329E26-DC23-3EBA-9461-37755368327D> /usr/lib/libSystem.B.dylib
0x7fff6bedc000 - 0x7fff6beddfff libThaiTokenizer.dylib (2.2) <04AC7CD4-BD9A-3B1D-8CEB-9E2030B6B667> /usr/lib/libThaiTokenizer.dylib
0x7fff6bef0000 - 0x7fff6bef0fff libapple_crypto.dylib (109.40.1) <32252490-B1E9-363F-AEED-3EC97D919348> /usr/lib/libapple_crypto.dylib
0x7fff6bef1000 - 0x7fff6bf07ff7 libapple_nghttp2.dylib (1.24) <01402BC4-4822-3676-9C80-50D83F816424> /usr/lib/libapple_nghttp2.dylib
0x7fff6bf08000 - 0x7fff6bf32ff3 libarchive.2.dylib (54) <8FC28DD8-E315-3C3E-95FE-D1D2CBE49888> /usr/lib/libarchive.2.dylib
0x7fff6bf33000 - 0x7fff6bfb4fdf libate.dylib (1.13.1) <178ACDAD-DE7E-346C-A613-1CBF7929AC07> /usr/lib/libate.dylib
0x7fff6bfb8000 - 0x7fff6bfb8ff3 libauto.dylib (187) <A05C7900-F8C7-3E75-8D3F-909B40C19717> /usr/lib/libauto.dylib
0x7fff6bfb9000 - 0x7fff6c070fff libboringssl.dylib (109.40.1) <75F5F125-B919-3318-BD12-29CB5E868475> /usr/lib/libboringssl.dylib
0x7fff6c071000 - 0x7fff6c081ff3 libbsm.0.dylib (39) <770B341F-3BB7-3123-B53C-F2D58868A963> /usr/lib/libbsm.0.dylib
0x7fff6c082000 - 0x7fff6c08fffb libbz2.1.0.dylib (38) <0A5086BB-4724-3C14-979D-5AD4F26B5B45> /usr/lib/libbz2.1.0.dylib
0x7fff6c090000 - 0x7fff6c0e6fff libc++.1.dylib (400.9) <FCF5E1F6-2B04-3545-8004-F3AB32FED172> /usr/lib/libc++.1.dylib
0x7fff6c0e7000 - 0x7fff6c10bff7 libc++abi.dylib (400.7) <217656D5-BC40-37FF-B322-91CB2AAD4F34> /usr/lib/libc++abi.dylib
0x7fff6c10d000 - 0x7fff6c11dfff libcmph.dylib (6) <A5509EE8-7E00-3224-8814-015B077A3CF5> /usr/lib/libcmph.dylib
0x7fff6c11e000 - 0x7fff6c134fff libcompression.dylib (47) <E64D4416-DFBF-314B-BBB9-BED23C3A251C> /usr/lib/libcompression.dylib
0x7fff6c3e1000 - 0x7fff6c3f9ff7 libcoretls.dylib (155) <DFE2454F-2FE3-3B2B-A22B-422947C34C69> /usr/lib/libcoretls.dylib
0x7fff6c3fa000 - 0x7fff6c3fbffb libcoretls_cfhelpers.dylib (155) <D3F4B882-40C1-3CD4-927B-0E0ED6031D0B> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff6c594000 - 0x7fff6c724fff libcrypto.35.dylib (22) <067CFC21-249D-392D-ADE1-785100BF0F83> /usr/lib/libcrypto.35.dylib
0x7fff6c8bf000 - 0x7fff6c8caff7 libcsfde.dylib (546) <B6F6340A-F874-38BD-A7BB-FFADEBA54789> /usr/lib/libcsfde.dylib
0x7fff6c8cb000 - 0x7fff6c921ff3 libcups.2.dylib (462.1) <B78448A0-9C97-3D4A-823E-EBE37B2B7CA6> /usr/lib/libcups.2.dylib
0x7fff6c94c000 - 0x7fff6c9a0ffb libcurl.4.dylib (105.40.1) <17EC22AC-0CE7-3FA7-AD55-B636806F46F8> /usr/lib/libcurl.4.dylib
0x7fff6c9a3000 - 0x7fff6c9aaff3 libdscsym.dylib (183.1) <2DE012BF-CE9A-3BDF-9A2D-55D66B51AA35> /usr/lib/libdscsym.dylib
0x7fff6ca5f000 - 0x7fff6ca5ffff libenergytrace.dylib (16) <A92AB8B8-B986-3CE6-980D-D55090FEF387> /usr/lib/libenergytrace.dylib
0x7fff6ca60000 - 0x7fff6ca79ffb libexpat.1.dylib (16.1.1) <5E1796FA-4041-3187-B5C2-8E6B03D1D72A> /usr/lib/libexpat.1.dylib
0x7fff6ca91000 - 0x7fff6ca95ff7 libgermantok.dylib (17) <379C5DC6-BEDB-378D-B09C-A63D297EAA6D> /usr/lib/libgermantok.dylib
0x7fff6ca96000 - 0x7fff6ca9bff3 libheimdal-asn1.dylib (520.30.1) <14DC1451-6E22-3A48-80CB-5D33DC0F8C3B> /usr/lib/libheimdal-asn1.dylib
0x7fff6cac7000 - 0x7fff6cbb8ff7 libiconv.2.dylib (51) <0772997F-4109-38A1-91ED-0F3F16AE99E5> /usr/lib/libiconv.2.dylib
0x7fff6cbb9000 - 0x7fff6cde0ffb libicucore.A.dylib (59152.0.1) <E628882C-6F83-3DCD-B62A-2FE6F77EF6F7> /usr/lib/libicucore.A.dylib
0x7fff6cde1000 - 0x7fff6ce16ffb libiodbc.2.1.18.dylib (42.5) <053A2EDF-A24C-3F8D-AB83-1C1F4711CE94> /usr/lib/libiodbc.2.1.18.dylib
0x7fff6ce2d000 - 0x7fff6ce2efff liblangid.dylib (128) <39C39393-0D05-301D-93B2-F224FC4949AA> /usr/lib/liblangid.dylib
0x7fff6ce2f000 - 0x7fff6ce48ffb liblzma.5.dylib (10) <3D419A50-961F-37D2-8A01-3DC7AB7B8D18> /usr/lib/liblzma.5.dylib
0x7fff6ce49000 - 0x7fff6ce5fff7 libmarisa.dylib (9) <D6D2D55D-1D2E-3442-B152-B18803C0ABB4> /usr/lib/libmarisa.dylib
0x7fff6ce60000 - 0x7fff6cf0ffff libmecab.1.0.0.dylib (779.7.6) <4FFE8518-473B-378D-997B-9DB55AB66ADA> /usr/lib/libmecab.1.0.0.dylib
0x7fff6cf10000 - 0x7fff6d138ff7 libmecabra.dylib (779.7.6) <7E255F87-BBB4-3AE5-BC82-6DEE70566D05> /usr/lib/libmecabra.dylib
0x7fff6d310000 - 0x7fff6d3e7ffb libnetwork.dylib (1229.30.11) <4E7A6EBA-B3DD-3001-9C97-CB423922B78C> /usr/lib/libnetwork.dylib
0x7fff6d45d000 - 0x7fff6d84b7e7 libobjc.A.dylib (723) <93A92316-DE1E-378C-8891-99720B50D075> /usr/lib/libobjc.A.dylib
0x7fff6d84c000 - 0x7fff6d84dff7 libodfde.dylib (24) <1BBC519E-EF89-38F3-B226-70F086670D0F> /usr/lib/libodfde.dylib
0x7fff6d85e000 - 0x7fff6d862fff libpam.2.dylib (22) <7B4D2CE2-1438-387A-9802-5CEEFBF26F86> /usr/lib/libpam.2.dylib
0x7fff6d865000 - 0x7fff6d899fff libpcap.A.dylib (79.20.1) <FA13918B-A247-3181-B256-9B852C7BA316> /usr/lib/libpcap.A.dylib
0x7fff6d918000 - 0x7fff6d934ffb libresolv.9.dylib (65) <E8F3415B-4472-3202-8901-41FD87981DB2> /usr/lib/libresolv.9.dylib
0x7fff6d96f000 - 0x7fff6d981fff libsasl2.2.dylib (211) <D9E281A2-D7BA-32CD-8B96-54972B1D9E66> /usr/lib/libsasl2.2.dylib
0x7fff6d982000 - 0x7fff6d983ff7 libspindump.dylib (248) <12E8B8BA-072F-39AE-8BC9-7D5840DA80EB> /usr/lib/libspindump.dylib
0x7fff6d984000 - 0x7fff6db17fe7 libsqlite3.dylib (274.5) <A1DEB5AB-8FE8-332E-A7E5-F493F2223FE3> /usr/lib/libsqlite3.dylib
0x7fff6db73000 - 0x7fff6dbc6ffb libssl.35.dylib (22) <4D77B502-E065-3794-90E7-39E83F9683F6> /usr/lib/libssl.35.dylib
0x7fff6dc19000 - 0x7fff6dc67fff libstdc++.6.0.9.dylib (104.1) <92CC5BBD-2FB2-3864-BF6B-B4B1BFF4C1EE> /usr/lib/libstdc++.6.0.9.dylib
0x7fff6dc9b000 - 0x7fff6dcd0fff libtidy.A.dylib (15.18.1) <3E33A53A-53AB-3FD5-BBAB-DFA6A3A90132> /usr/lib/libtidy.A.dylib
0x7fff6dce8000 - 0x7fff6dd21fff libusrtcp.dylib (1229.30.11) <537F14D0-84DF-349F-8EA0-52BB7A241E60> /usr/lib/libusrtcp.dylib
0x7fff6dd22000 - 0x7fff6dd25ffb libutil.dylib (51.20.1) <216D18E5-0BAF-3EAF-A38E-F6AC37CBABD9> /usr/lib/libutil.dylib
0x7fff6dd26000 - 0x7fff6dd33fff libxar.1.dylib (400) <0316128D-3B47-3052-995D-97B4FE5491DC> /usr/lib/libxar.1.dylib
0x7fff6dd37000 - 0x7fff6de1efff libxml2.2.dylib (31.7) <49544596-BCF8-3765-8DC5-DB1A9A90EF92> /usr/lib/libxml2.2.dylib
0x7fff6de1f000 - 0x7fff6de47fff libxslt.1.dylib (15.10) <66682AF6-C2D5-374C-901F-25A3E72814DC> /usr/lib/libxslt.1.dylib
0x7fff6de48000 - 0x7fff6de5affb libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
0x7fff6def8000 - 0x7fff6defcff7 libcache.dylib (80) <354F3B7D-404E-3398-9EBF-65CA2CE65211> /usr/lib/system/libcache.dylib
0x7fff6defd000 - 0x7fff6df07ff3 libcommonCrypto.dylib (60118.30.2) <674286D3-7744-36A3-9AAA-49DFCD97A986> /usr/lib/system/libcommonCrypto.dylib
0x7fff6df08000 - 0x7fff6df0ffff libcompiler_rt.dylib (62) <4487CFBA-A5D7-3282-9E6B-94CAD7BE507E> /usr/lib/system/libcompiler_rt.dylib
0x7fff6df10000 - 0x7fff6df18ffb libcopyfile.dylib (146.30.2) <2C7C67D7-562B-3FFA-973D-BACF4C10E1EC> /usr/lib/system/libcopyfile.dylib
0x7fff6df19000 - 0x7fff6df9efff libcorecrypto.dylib (562.30.10) <8A53EFE1-AFCA-3676-BEE1-FA5ED9F0E222> /usr/lib/system/libcorecrypto.dylib
0x7fff6e026000 - 0x7fff6e05fff7 libdispatch.dylib (913.30.4) <7D0E3183-282B-3FEE-A734-2C0ADC092084> /usr/lib/system/libdispatch.dylib
0x7fff6e060000 - 0x7fff6e07dff7 libdyld.dylib (519.2.2) <C50D02BC-A333-3313-B787-02F255A6783F> /usr/lib/system/libdyld.dylib
0x7fff6e07e000 - 0x7fff6e07effb libkeymgr.dylib (28) <6D84A96F-C65B-38EC-BDB5-21FD2C97E7B2> /usr/lib/system/libkeymgr.dylib
0x7fff6e07f000 - 0x7fff6e08bff3 libkxld.dylib (4570.41.2) <661F47FA-F6FC-3FB1-8023-9DFE108AEEF7> /usr/lib/system/libkxld.dylib
0x7fff6e08c000 - 0x7fff6e08cff7 liblaunch.dylib (1205.30.29) <E66F58ED-C15E-3DFB-BC22-A861E13918C6> /usr/lib/system/liblaunch.dylib
0x7fff6e08d000 - 0x7fff6e091ffb libmacho.dylib (900.0.1) <756F2553-07B6-3B42-ACEA-2F0F1A5E8D0F> /usr/lib/system/libmacho.dylib
0x7fff6e092000 - 0x7fff6e094ff3 libquarantine.dylib (86) <6AC8773F-3817-3D82-99C2-01BABB9C3CBB> /usr/lib/system/libquarantine.dylib
0x7fff6e095000 - 0x7fff6e096ff3 libremovefile.dylib (45) <912FA211-DD8C-3C92-8424-21B89F8B10FD> /usr/lib/system/libremovefile.dylib
0x7fff6e097000 - 0x7fff6e0aefff libsystem_asl.dylib (356.1.1) <94972913-9DF0-3C78-847C-43E58919E3DA> /usr/lib/system/libsystem_asl.dylib
0x7fff6e0af000 - 0x7fff6e0affff libsystem_blocks.dylib (67) <F2493BB5-B1C6-3C4D-9F1F-1B402E0F1DB7> /usr/lib/system/libsystem_blocks.dylib
0x7fff6e0b0000 - 0x7fff6e139ff7 libsystem_c.dylib (1244.30.3) <E0136C71-0648-36F0-9F84-82EA2748A8D7> /usr/lib/system/libsystem_c.dylib
0x7fff6e13a000 - 0x7fff6e13dffb libsystem_configuration.dylib (963.30.1) <0F8D0B76-4F7D-34EC-AB6C-50F9465809DA> /usr/lib/system/libsystem_configuration.dylib
0x7fff6e13e000 - 0x7fff6e141ffb libsystem_coreservices.dylib (51) <21A488D0-2D07-344E-8631-CC8B2A246F35> /usr/lib/system/libsystem_coreservices.dylib
0x7fff6e142000 - 0x7fff6e143fff libsystem_darwin.dylib (1244.30.3) <2F750CB1-BC26-3FA3-AE59-553EE30D451B> /usr/lib/system/libsystem_darwin.dylib
0x7fff6e144000 - 0x7fff6e14aff7 libsystem_dnssd.dylib (878.30.4) <EB9BB165-45A4-367C-B33A-688D4F383A95> /usr/lib/system/libsystem_dnssd.dylib
0x7fff6e14b000 - 0x7fff6e194ff7 libsystem_info.dylib (517.30.1) <7D79E167-4B5C-3833-81EE-3AF3FB53616D> /usr/lib/system/libsystem_info.dylib
0x7fff6e195000 - 0x7fff6e1baff7 libsystem_kernel.dylib (4570.41.2) <5155A4C3-825B-3178-AC51-0D2D2F2A6618> /usr/lib/system/libsystem_kernel.dylib
0x7fff6e1bb000 - 0x7fff6e206fcb libsystem_m.dylib (3146) <ABB1B85F-9FFE-31B8-AD4F-E39A30794A93> /usr/lib/system/libsystem_m.dylib
0x7fff6e207000 - 0x7fff6e226fff libsystem_malloc.dylib (140.40.1) <36B22C99-D772-3039-9A4C-AA31389965E1> /usr/lib/system/libsystem_malloc.dylib
0x7fff6e227000 - 0x7fff6e2cbff3 libsystem_network.dylib (1229.30.11) <40BAD301-8744-3AD8-A688-E7925C587B00> /usr/lib/system/libsystem_network.dylib
0x7fff6e2cc000 - 0x7fff6e2d6ffb libsystem_networkextension.dylib (767.40.1) <CEDC330D-28F0-3902-BEB0-10B92ACEC69F> /usr/lib/system/libsystem_networkextension.dylib
0x7fff6e2d7000 - 0x7fff6e2e0ff3 libsystem_notify.dylib (172) <98EA3D62-7C86-30DE-8261-D020D2F1EFF3> /usr/lib/system/libsystem_notify.dylib
0x7fff6e2e1000 - 0x7fff6e2e8ff7 libsystem_platform.dylib (161.20.1) <C049250F-8C35-314D-810F-4E28AEAED983> /usr/lib/system/libsystem_platform.dylib
0x7fff6e2e9000 - 0x7fff6e2f4fff libsystem_pthread.dylib (301.30.1) <ABA848E1-6978-3B42-A3A7-608B2C36FA93> /usr/lib/system/libsystem_pthread.dylib
0x7fff6e2f5000 - 0x7fff6e2f8ff3 libsystem_sandbox.dylib (765.40.2) <922D3D15-AB4C-3F1A-A94F-39214AF1ADB3> /usr/lib/system/libsystem_sandbox.dylib
0x7fff6e2f9000 - 0x7fff6e2faff3 libsystem_secinit.dylib (30) <F06ADB8F-9E94-34A7-B3C9-2C22FDD14BAD> /usr/lib/system/libsystem_secinit.dylib
0x7fff6e2fb000 - 0x7fff6e302ff7 libsystem_symptoms.dylib (820.30.7) <DC3586C2-AA56-3419-88D3-FC0DBF08E3C0> /usr/lib/system/libsystem_symptoms.dylib
0x7fff6e303000 - 0x7fff6e316ff7 libsystem_trace.dylib (829.30.14) <69EBF017-D40F-30D7-9B0B-BFC862D761A5> /usr/lib/system/libsystem_trace.dylib
0x7fff6e318000 - 0x7fff6e31dff7 libunwind.dylib (35.3) <6D4FCD49-D2A9-3233-95C7-A7635CE265F2> /usr/lib/system/libunwind.dylib
0x7fff6e31e000 - 0x7fff6e34aff7 libxpc.dylib (1205.30.29) <F7E5F1BC-614B-39CB-B6CE-92A9C7B7EC0B> /usr/lib/system/libxpc.dylibExternal Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 58871
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 109942451
thread_create: 0
thread_set_state: 0VM Region Summary:
ReadOnly portion of Libraries: Total=866.3M resident=0K(0%) swapped_out_or_unallocated=866.3M(100%)
Writable regions: Total=6.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.7G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 1280K 9
Activity Tracing 256K 2
CG backing stores 123.2M 11
CG image 1712K 244
CoreAnimation 52.5M 111
CoreGraphics 8K 2
CoreImage 256K 31
CoreUI image data 5784K 41
CoreUI image file 292K 5
Foundation 24K 3
IOKit 7940K 2
Image IO 2728K 200
Kernel Alloc Once 8K 2
MALLOC 6.0G 3322
MALLOC guard page 64K 14
MALLOC_LARGE (reserved) 2816K 2 reserved VM address space (unallocated)
Memory Tag 242 12K 2
OpenGL GLSL 256K 4
STACK GUARD 56.2M 46
Stack 32.3M 294
VM_ALLOCATE 518.1M 286
__DATA 62.0M 498
__FONT_DATA 4K 2
__GLSLBUILTINS 2588K 2
__LINKEDIT 277.8M 109
__TEXT 588.5M 441
__UNICODE 560K 2
mapped file 88.6M 36
shared memory 716K 13
TOTAL 7.7G 5707
TOTAL, minus reserved VM space 7.7G 5707Model: iMac17,1, BootROM IM171.0147.B00, 4 processors, Intel Core i7, 4 GHz, 24 GB, SMC 2.33f10
Graphics: AMD Radeon R9 M390, AMD Radeon R9 M390, PCIe, 2 GB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x198, 0x4B48583138363643313153334C2F38472020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1867 MHz, 0x198, 0x4B48583138363643313153334C2F38472020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x802C, 0x384B54463531323634485A2D314739453220
Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1867 MHz, 0x802C, 0x384B54463531323634485A2D314739453220
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.77.37.5.1a3)
Bluetooth: Version 6.0.2f2, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST1000DM003, 1 TB
USB Device: USB 3.0 Bus
USB Device: iPad
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: Keyboard Hub
USB Device: DeathTaker Gaming Mouse
USB Device: Apple Keyboard
Thunderbolt Bus: iMac, Apple Inc., 28.1 -
Editing nurbs Path objects inside of an Extrude along path object in ortogonal view with Scale objects command makes the extrude along path command fail.
Only works while in top/plan view. Is that a bug or a feature?
The message i got 99% of the time...than with the same item the command just makes the fillet later after a couple hundred tries.
Anyways...VW2018 crashes more than any other VW combined together (the RAM is not the problem i have 48gb...or is that still not enough?)
Working with pointclouds is a pain in the *** over 40million points...Extrude along path just became so sensitive it just doesn't make anything...and VW doesn't even let me know that after a couple minutes of "rainbowing", calculating the error.
Gamer mode walkthrough still doesn't work in Multiple View Panes mode since i reported it to tech staff a couple months ago using the latest SP3.
There are still no EU (eastern) standards in VW such as centerline data for windows and doors...etc. Doesn't Nemetschek own VW the same comany that owns Archicad? Please copy paste these "features" from there. By the way is there any way to classify building elements by deafult not by class? (Uniclass or Omniclass...etc?)
Thank you.
(I know nobody reads these entries here on the forums from VW staff but im so pissed off i had to write them down somewhere.)
Oh and please use your own software and try it out on user affordable computers how it works. It is not optimized at all. (I'm using a late 2015 27" 5K CTO iMac i7 though and it struggles...)
On 9/2/2016 at 7:27 PM, JimW said:
Still not able to replicate this, however it may be possible the issue is related to QuickLook, open Terminal on your Macs (Applications > Utilities > Terminal) and then enter the following:
qlmanage -r
Then press enter. Reboot the machine and then see if the thumbnails start updating as expected. The thumbs SHOULD be showing exactly what was in your drawing area at the moment of the last save, whether it was top/plan or otherwise.
Doesn't work with VW 2016 SP6 latest OSX (10.13.2).
Any solution yet?
How can i automatically add height and width (+sill height) to doors and windows center line as a text / Dimension marker? 2nd and 3rd columns on attached picture.
(I know i can add these manually if i convert a symbol from a door or window, but this should be a basic feature...not to mention that this is a standard over here in Europe...)
Pdf ungroup bug?
in General Discussion
Posted
As i said it sometimes works with the SAME pdf sometimes it does not.
