126 -
Calendar
Everything posted by Kazemester
I don’t have any antivirus on my mac and VW slows down significantly after a couple hours of work. It seems to be a memory related “problem”, as i see VW doesn’t really cleans memory efficiently and keeps eating ram until it dies.
I miss those good old days when a new VectorWorks release was actually released after it was tested and optimized even if it took more than a year. It's sad that the "dev team" focuses on the "new content" instead of fixing the old ones and implement stuff that is actually needed. (Freeform bendable walls, window and door centerline data...etc.)
Editing nurbs Path objects inside of an Extrude along path object in ortogonal view with Scale objects command makes the extrude along path command fail. Only works while in top/plan view. Is that a bug or a feature?
Editing nurbs surfaces extracted from a solid subtraction works fine as wel...NOT.
The message i got 99% of the time...than with the same item the command just makes the fillet later after a couple hundred tries. Anyways...VW2018 crashes more than any other VW combined together (the RAM is not the problem i have 48gb...or is that still not enough?) Working with pointclouds is a pain in the *** over 40million points... Extrude along path just became so sensitive it just doesn't make anything...and VW doesn't even let me know that after a couple minutes of "rainbowing", calculating the error. Gamer mode walkthrough still doesn't work in Multiple View Panes mode since i reported it to tech staff a couple months ago using the latest SP3. There are still no EU (eastern) standards in VW such as centerline data for windows and doors...etc. Doesn't Nemetschek own VW the same comany that owns Archicad? Please copy paste these "features" from there. By the way is there any way to classify building elements by deafult not by class? (Uniclass or Omniclass...etc?) Thank you. (I know nobody reads these entries here on the forums from VW staff but im so pissed off i had to write them down somewhere.) Oh and please use your own software and try it out on user affordable computers how it works. It is not optimized at all. (I'm using a late 2015 27" 5K CTO iMac i7 though and it struggles...)
Doesn't work with VW 2016 SP6 latest OSX (10.13.2). Any solution yet?
How can i automatically add height and width (+sill height) to doors and windows center line as a text / Dimension marker? 2nd and 3rd columns on attached picture. (I know i can add these manually if i convert a symbol from a door or window, but this should be a basic feature...not to mention that this is a standard over here in Europe...)
I'm still looking for the formula to list wall surface areas (with wall IDs and different wall components listed) within one space (when the data is not in the space north,east...etc. wall finishes, because that can't handle that when i have more than 4 walls around a space). It would be nice to list wall component areas that a space boundary touches or contains. I could only list all my wall component areas, but that doesn't tell me which is in which space.
Can i extract visible wall component areas from spaces somehow? Or is there any way to show the wall finishes in a worksheet shown in each room? I want to have a worksheet with columns named: Room name, Floor, Wall ID, Wall surface name component name, Wall surface (component) area without the doors and windows in the space (not the whole wall, only inside each space one by one) Thanks
Is it possible to open another Navigation window to have layers and classes visible at the same time?
Great! Thanks for the info. By the way...is it possible to export a .vrl file from Vectorworks or is there any plug-in, add-on that makes VW capable doing so?
Yeah, sorry...i was just mentioning Unity as an example (a bad one)... Archiving stuff would be a good reason to use IFC 4 in that case though. Well, we hope the best and still looking for the best solution.
I'm not sure there is, was just looking for a way what can be standardized (is that a word?:D )...anyways i know that some model elements can be exported by color and transparency, but i was looking for textures. As Mihail wrote IFC 4 is not certified in Vectorworks (still have no idea why is it there as a feature and how Building Smart let Nemetschek to use it)...so we need to look for another solution.
Neither Solibri or Autodesk online viewer open IFC4 with textures. We are working on making a "standard" for architects to save their projects to IFC 4 and than we can integrate that to a software such as Unity to make VR for customers...but i guess we have to make it the hard way as usual...export OBJ, or FBX and textures and lights and IES...etc...
I get all that. I just wanted to know that if i have a wall classified as an IfcWallStandardCase (by deafult) is there any options i can put a data set into that as a texture and export that in an IFC 4. Or is there any way i can get any objects exported with textures with IFC4 in Vectorworks or not?
I didn't want to open a new topic for this: Is it possible to export an IFC file that contains model textures? As i classify a wall to IfcWallStandardCase, there is no data set for textures. If i classify my wall as an IfcSurfaceTexture than the model is not exported in the IFC ( tested in Solibri Model Viewer or Autodesk Viewer, neither of them imported the model). Is there any way i could attach this IFC property to an IfcWallStandardCase as a data set inside of the IfcWallStandardCase? Or how can i get this done? How is IFC 4 export in VW 2017-2018 certified if it doesn't work as it should? Thanks for the replies. EDIT: When i add the IfcSurfaceTexture data set to a Wall object in the IFC Data Mapping window, it doesn't show up in the wall's psets when i draw a wall and check it's IFC properties.
Lots of graphical bugs are in VW2018... Is there any way to select different components from a wall and join them to a slab's components? Or is it only "automatic"? 1.pdf 2.pdf 3.pdf only edit section in place is good.pdf section.pdf
Is multipass rendering option in VW 2018 renderworks already? (Have been asking for it since 2013...)
IFC property values disappear after placing schedule
Kazemester replied to Kazemester's topic in Architecture
Is there any option to turn off the fking schedule deleting-switching off properties and sh*t from my items??????? -
Nope..it does not work. All the sudden 50 items forgot the 'other' property from their ifc dataset out of 300. And when i turn it on, all the values are blank of course.... WTF??? -
Well...i think the deafult Objects with IFC Entity schedule is bugged and cleares the stuff in the IFC Entity itself. I've made a blank worksheet and it seems fine...or at least for now. By the way...VW 2016 imports an IFC file (let's call it 001.ifc) with all the properties, but VW 2017 imports it as a group. VW 2017 imports 002.ifc perfectly, exported the same way out of Revit as 001.ifc. Why doesn't VW 2016 import any ifc materials as colours as VW 2017 does? -
Dear VW Users, I have more than 500 custom furnitures with a custom property set and different values to import from Revit. Doing this one by one is another pain (is there any way to import more than 1 IFC file to VW at once?) but the more frustrating thing is that after the import something goes wrong. The first IFC entity appears to be good. Than I import the second one, still seems everything ok. Than I make a schedule to show my custom properties with the values, still ok...but after a while, when I import more IFC files my custom properties don't show up anymore and even the ones I've imported before are turned off in the IFC data sets. I have a custom property set called "Other". When I import the IFC this property shows checked as active. Than later on it switches off itself somehow and forgets all the values were in it. I only use =GETIFCPROPERTY('Other.Customvalue') command to list my data, no big magic. Any ideas what do i do wrong? Oh...and now I see while im typing...after I restart VW the IFC entity even forgets my custom property. It is not anymore in the Data Sets for my objects. What is going on?????? VW 2017 SP4 Entity: IfcFurnishingElement 2X3
Hi, is there anything similar to multipart polygon? I want to import a shapefile containing a couple hundred polygons with records attached. I can custom select by different records, but than i want to make the similar ones "work" as one polygon for later work. Making a group is not an option, because after exporting the group that forgets the attached records. Does anyone have any solution for this or it is not coded in VW at all to work with multipart polygons?! Thanks!
Selecting objects with selected objects (for GIS selection)
Kazemester replied to Kazemester's topic in Workflows
Custom selection is not good when i want to select polys touched by one poly...because they have different names (given by a shape file and database) and usually there are couple thousand that i want to select this way.
