24 -
Reputation
3 NeutralPersonal Information
Location
United Kingdom
Recent Profile Visitors
796 profile views
Has anyone experienced a lack of colour when using a surface hatch within a texture in a wall component? The block on the left is an extrusion with the SAME blue brick texture as the wall behind it, however the wall hatch shows as white. The only way I can get the wall to show blue is by selecting the render tab and choosing "by object" instead of "by component. This work around ruins my sections, and removes the nice component textures in 3D. Please help before I implode!
Snapping to geometry in referenced layers in rotated plan view not working VW2017
Jakerhp replied to JJe's question in Troubleshooting
Whilst this is an old thread, I too have been experiencing this in VW2020, and I found a fix for anyone else searching! My internal origin is set to the true location somewhere in Devon, UK as is the reference file. However in order to draw walls easily on a 0 or 90 degree angle I have to rotate the drawing/plan 8.95degrees. I am then unable to snap to the reference file. By heading to File>Document settings>Georeferencing I simply change the "Angle to true North" to match the rotation of my file (8.95 degrees) and I am now able to snap snap SNAP! If anyone wants to comment on the implications this will have on my file please do, I plan on setting it back to 0 when I'm finished. -
@zoomer I have cut a section through a curved wall in the past and the result was as expected, 90 degree lines representing the wall as it actually would be, upright! Im sure this must be a bug, I'll see if I can report it.
Jakerhp changed their profile photo
I seem to be having an issue with creating a section through a curved wall. As you can see by the picture, the wall in the section is curving on a 2nd axis. I expected the wall to show on the section as it would through a straight wall, Can anyone explain why my walls are showing as if they are domed?
@line-weight I ended up getting around this temporarily by either moving the section line by 5mm (which worked sometimes, I'd then re-open the file to find no fill again) or by manually drawing on the fill i needed, which of course should not be necessary and was wasted time. I will try your method out soon and see if it works, we are now on 2019 so perhaps they fixed the bug?! Ill have to check the old file to find out. Will post here with further updates.
@Nikolay Zhelyazkov Thank you for clarifying. My company should be rolling 2019 pretty soon, so will be patient.
When revising drawings sheets in multiple files via the title block manager, I am experiencing a consistent issue in that whilst the revisions are assigned to the drawings, they dont actually appear until I open the file and double click on the title block. You can imagine how frustrating this is when I am revising 65 drawings and ultimately have to open 65 files and double click the title block of each one just ensure the correct revision is showing. Is anyone else experiencing this? Currently on 2018 SP5
Thats great news! Thank you for pursuing this Nikolay!
So In answer to my own question, When changing the class attributes of the viewport, we now have the option to turn off or on the render works texture. Turn it off and your windows go solid again! (we didn't have this option in 2017)
- 1 reply
- 1
HI All, I simply CANNOT get my glazing class on my viewports to appear solid. Im trying to create some elevations from my 3D model, the glazing in my doors is showing as solid but the glazing in my windows is not showing up at all. The glazing is the same class through out, using the default class attributes, which is solid. i have even forced it to be solid on the viewport classes and still nothing, and yet the glazing on my door is solid!! please see attached Pic. any clues?
Great Thank you Nikolay, Ill do just that!
Hi All, Does anyone know how to change the default "NONE" from the (title block border.current revision number) to just a blank space? Ive not come across a Architectural practise yet that define a drawing with no revisions yet as "NONE", I just want a blank text box until revision "A" or "1" appears. thanks in advance.
This is Fantastic, @Nikolay ZhelyazkovIs there a way to, when there is no revision yet, just have a blank space rather than a VERY intrusive "NONE" show up?
Hi Guys, Does anyone know how to, in the Resource browser, either: 1. Make the render texture thumbnails larger or 2. Have the thumbnail zoom in on the texture Basically I have loads of different textures for the same thing, eg 10 different brick textures and Id like to be able to actually see which brick texture Im clicking on! Thanks in advance
Thank you for your effort and compliments there Alan, You should see the model now! I ended up exporting it to a 3D web view and successfully walked around it with my 3D VR goggles! However, I am familiar with the settings your video ran through and had previously tried changing the classes etc. I have attached a screen shot to show you that I am still having the same problem even after ensuring I followed your instructions precisely. I have attached 3 screen shots. 1 shows the section still with no fill 1 shows the section with a little bit of fill after increasing the minimum elevation 1 is just me showing you what the finished site model looked like Thanks again, and thank you in advance for any further help you can be.
