Christian Soria
    5
Everything posted by Christian Soria
  1. Hello everybody, here I am having the same problem with that tool... any updates about a solution? I am using VW 2018 SP6 on a macOS Mojave 10.14.6. Greetings!
  2. Hello guys, I have a very simple question, and it is how to sum individual sub-rows within a report. When I do it, it sums immediately the total amount of the row, but not of specific sub-row values. Thanks in advance!
  3. Hello guys, Do you know a way to change/edit/add different styles to Stake objects? Specifically, I would like to modify the circle cross style so the circle would be partially filled with color. Thanks in advance!
  4. Hello guys! I am new VW, currently using the 2018 SP6 edition on a iMac 2017 (Mojave). I have been trying to use the Standard Naming command, but I've have had problems trying to bring the layers and classes with all their line styles and pre-sets into a Template file I've been trying to create. I have activated the auto-classing and it creates new classes when bringing objects like doors from the Resource Manager, but I have not succeeded on trying to bring or import the rest of the classes, layers or VP that I can see in the Standard Naming's dialog box. Is there a way to import them into a blank new file, so I can create a Template file for example? Thanks in advance, Christian
  5. Hello everybody. So this plugin doesn't work for Vectorworks 2017? (That AR-Media plugin also gives me error while using VWS 2017) Do you know any other plugin that works? (It's for my Master Thesis project) Best regards!
