DBLD
158 -
Everything posted by DBLD
Thanks guys, when I reopened the file the following day everything was where it should be.
Hello I have imported a document as a referenced view port but some of the symbols are not in the correct place and the incorrect symbols aren't selectable. Anyone got any ideas?
I have both of them back in my original document now. They seem to come and go but next time they have gone I will try turning off soft shadows.
Ahhhh I see. It must be my file
Hmmm, good to know. Thanks for having a look at it. Its strange there is 1344 light objects when the file is empty besides the two directional lights.
Here you go Directional lights.vwx
Yep both same class. I duplicated the second from the first. I am on Vectorworks 2023 SP7, Windows 11. Top/Plan view shows the one on the left, Top view shows the one on the right.
I have two directional lights in a drawing (90 degrees offset from each other) but only one symbol is showing. Is this a bug or only one will show? They both cast light. It has happened in a number of documents I have created. x
Accessories not showing in section viewports
DBLD replied to DearAlexJohnson's topic in Entertainment
It seems that even one clamp isn't visible if it is inserted as a symbol. I converted it to a mesh and it came good. I 3D edited a lighting fixture and added a clamp (rather than add it as an accessory). It wasn't visible once I exited the 3D edit window so I converted it to a mesh and it can now be seen. -
Thanks Scott, I just DM'd you the file. Thanks! -
Unfortunately I don’t have any solutions.
No ceiling or wall pieces, its just a stage, risers and lights.
Hello I am having a similar issue where the fixture has a clamp (edit 3D from Resource Manager), but aren't showing them when put on to the plan. They do however show in some of the Graphic Legends. I have every class and design layer turned on. I am on version 2023 SP7. -
No worries, I just DM'd you.
I am having an issue with the lines of the steps not rendering in the hidden line render. Anyone have any suggestions? There is two sets of treads there as in the plan view below:
I am having an issue when I try to edit the 2D component of a label legend where it only shows the 3D view. When I open the 2D label legend editor the view looks like this below. Top/Plan view is selected. While I am still in 2D label legend edit I can go to a front view and it shows what looks like the 3D editor. Editing in the 3D view has makes no changes to the 2D label legend. This has happened over a number of Vectorworks files. I have deleted all label legends from this file and started fresh but still having the same issue. I am on version 2023 SP6 but this was also happening in SP5.
Hello, this has just happened to me again. I am on version 2023 and updated to SP6 yesterday. Clicking the multiple view panes icon fixed the issue.
Copy that, thanks for your insight Pat. I got a similar result as you with a single cell for each deck size. It is the combined deck size, heights and casters that is really useful for me.
I got this working by adding a purpose note to each deck and reporting by purpose. I would be interested to know if there is another way around this.
Hi, I am creating a graphic legend to show the stage decks I have used. Currently it is showing a quantity of one for each deck, rather than saying quantity of two for matching decks. Does anyone know how to get it to summarise the quantities?
I ran into this issue again yesterday with bloom not rendering on both a 2k and 4k video. Without bloom the video looks very flat lifeless. I feel that not being able to render a movie at a higher resolution than is displayed on the screen is a major flaw in the software. In my mind the whole idea of rendering a movie is to achieve better looking output than the graphics card can produce in real time. I get a better result recording a screen capture.
Thank you!
It appears that when creating walls in Vectorworks, adding a texture then exporting as MVR to Vision the mapping information is not the same as it is in Vectorworks. I have a Renderworks concrete texture applied to all faces of a wall and it looks correct in Vectorworks but when I import it into Vision the texture isn't aligned to all planes. It appears that it is mapped to the ends of the walls and the texture is extruded through the length of the wall. Is there a way to fix this? Vectorworks: Vision:
