2,004 -
Posts posted by Kevin Allen
I’d also try from another SLVP and see what happens.
I’m sure you’ve investigated the file and what ever might be referenced in, but could someone have brought in some crap geometry?
what happens when you makes a section VP and do you make that from a design layer or another SLVP?
seems odd, but I think "drawing list" and "sheet list" are two different reports. either draws on data from the title block objects. I do not have to rework the Drawing List when I add sheets. I do have to "recalculate" from time to time.
FYI, the ReShaper PIO help to layout the array.
- 1
If you have the Landru Tools version, there is an additional PIO to map a texture across multiple Instances. Otherwise, you might just create a curve, tapered extrude, and use that for the image.
- 2
I think it comes with Architect or Designer, but there is a worksheet called "Index of Drawings."
I think you can turn that off in the TB settings, or set the number to whatever you like
Use a Graphic Legend?
- 1
well, some objects, like softgoods respond to the commend "create objects from shape" in the contextual menu or Modify>convert>convert objects....
you might also use the move by points tool
- 1
This has come up often. It is, hopefully, on the radar.
I have been able to get counts in a graphic legend?
30 minutes ago, DianaK said:
Glad to have a lesson if anyone has the time.
Happy to help.as I recall, it was pretty straight forward, my issues were with the limitations of the report formatting. Everything I wanted to report HAD to be a symbol, but I make almost everything into a symbol.
13 minutes ago, DianaK said:
Do you know that it can be used to read off the contents of a Space?
I know a graphic legend can filter by viewport. Not sure about Spaces, in the VWX sense of the word.
I am also not sure if they can be updated en mass.
Have you considered a graphic legend?
I think if you compose them into a more logical NURBS surface and then convert to Generic Solids you might be best. I would save as frequently. Test your textures, but you knew that.
5 minutes ago, grant_PD said:
When we do the curved array it is always about the angle of the facet, and laying them out becomes a very rudimentary process.
This is one example where the ReShaper PIO/Command is very helpful.
- 2
39 minutes ago, Lunar Waneshaft said:
Acknowledging that this is heavily skewed toward entertainment,
I do not agree, plus as someone said; the cross pollination is very valuable. I know I started to read the mailing lists before I had much of a clue and I have learned a lot from people in and out of my field. I think the 'architectural' bus tours of Chicago were valuable to all.
- 1
3 minutes ago, Don Seidel said:
Have you been to a VW Design Summit in the past? If not you don’t know what you’ve missed.
I think I've been to three of four? Philly, Chicago, Baltimore, and Phoenix (or Phoenixish, I should say). I preferred the cities to the resort. That is why I really didn't consider the last one. Might it have been canceled? In any event there seems to be much more 'design' in the city than in the desert. Also, the resort in Phoenix was a half hour from anywhere, so if a small group wanted to leave the resort for a drink, at least an hour was was required for a taxi/uber/lyft.
- 1
Isn't it more complex than just a curve? I have done shows with 'stands' for the panels that facet into curves. Having access to that hardware and being able to readily add that would be terrific.
- 1
what do you mean by non-parallel walls? Walls with uneven thicknesses?
- Popular Post
- Popular Post
49 minutes ago, Don Seidel said:From a 30-yr VW veteran, Summit or Open House on-line is massively disappointing. Having attended Design Summits in person in the past, there's simply no comparison. Covid is over, let's move on from that excuse.
Going back to in-person should not be done with the idea that covid is over.
I am a proponent of Hybrid events. I might go to an on-peson Summit, depending on location.
- 7
4 minutes ago, TomWhiteLight said:
I rendered out a camera view and made a screen texture.
That has been my workaround, BUT if I am showing something and there is iMag, it would be ideal if the screen updated as the design evolved. Pretty much a first world 'problem.'
- 2
On 4/25/2023 at 7:48 AM, Pat Stanford said:
I read the question differently. I thought Dendecko wanted to have the camera view show up on a "monitor" object in the VW drawing. And I don't know how to do that or that it can be done.
That is how I read the question as well. I agree it cannot be done, BUT it would be nice.
- 1
try the split tool
- 1
Foreground rendering and clipcubes
in Troubleshooting
Posted
If you have a plan view SLVP, use the command and draw the section line as normally. You can also 'cut' a section from an elevation.
I would check those PIOs
