Kevin Allen
  • Content Count
    692
Posts posted by Kevin Allen
  1. 23 hours ago, milezee said:
    @Christiaan just tried the Nomad app on my android device, pretty useless to be honest, app crashes every time using the AR viewer. And viewing the 3d model is ok, except when you click the set view button it puts the model on some strange axis, really bad app as it is right now, hope to see work put into this and improved, so much potential for showing clients quick 3d snippets of work 🤔
    How big is your original file. I work in iOS, but I gather everything is the same. I've had minimal issues with the AR and the Panorama, and my issues were operator errors.
    • Like 1
  2. It's the corners that give you the look. IRL, I don't think twisting a round rod will give you the appearance you want. I imagine that in your model and in fabrication you'll have to transition from the rectangle to the circle. IRL, the welds can be ground down to make the transition appear seamless. Virtually, I would add a subdivision element to make the transition, of to make the entire piece. That's appreciably more complex modeling.
  3. Use the Twist option in the Deform Tool. You'll need three extrudes of the square rod. Twist one, and Use Model>Add Solids to put the three together. It might be possible to use one extrude and just twist the one area, but I'd have to check that functionality.
    • Like 2
  4. If I correctly understand, you'll likely need the objects to be symbols. You'll need to create a data record for the object and include the parts and costs. Then you can create a report based on the data record and include on the sheet. You may need to recalculate the report to get updated information.
  5. I am attempting to create a number of Linear Animations. I'm seeing an odd cropping issue between saved views and the overall compositions. What I see in the animations has been cropped down from the saved views. Hoping this isn't a bug, but user error.
