2,315 -
Reputation
1,067 SpectacularPersonal Information
Occupation
Experiential, Scenic and Lighting Designer
Homepage
klad.com
Hobbies
figurative drawing
Location
United States
Recent Profile Visitors
9,473 profile views
split tool changed? ...then changed back?
Kevin Allen replied to jason schneider's topic in General Discussion
If this is WAD, it is also PITA -
you would have to build the lights as spotlight lighting devices, but then I would think it would be a great assistance.
Highlight specific areas of the stage in Viewports / Renders
Kevin Allen replied to Cristiano Alves's topic in Entertainment
only light certain areas, leave the rest dark -
create a template file
I thought I recalled the PDF including links, might be wishful thinking on my part as well.
There is a stock report called something like index of drawings
IIRC, the standard ToC that ships with the app does this?
It would help to see the file, but are you using Loy fog or depth of field?
a plan might help, but a sweep and solid subtractions
not seeing your images, I usually start with a sweep.
Many of us have 'systems' in place, that have to be changed or forced to work around choices made by software engineers. Not sure that standard naming does the trick. The solution needs to work for all users. It gets more difficult with collaboration, but I want VWX to understand that I just don't use or care about the Lighting-LED class, even if I might be collaborating with someone who really needs that information. I want my own autoclassing and I want to override the internal autoclassing.
