109 -
Posts posted by nikihoops
Hi all
More often than not when I update a viewport or all viewports my VW 2019 SP1 crashes. Its getting very frustrating now. Finding myself saving my work before I update viewports just incase but occasionally I do forget! (my autosave is set at every 5 minutes but that doesnt always seem to happen!)
Hoping for an easy fix. Its not a large or complicated file either. (52.2mb)
I was hoping this would be in 2019 also :(
1 hour ago, michael john williams said:
We are thinking of going. We are in Somerset so a bit of a long haul and early start and travel will be expensive.
Why can't training be a bit more regionally rather than just in London? Bristol would be a great venue for the South West and South Wales.
Also will the event justify the travel time and expense? It may be more of a product promotion rather than training.
Anyway just jump on a train in Bristol. Paddington is the London end stop and simply catch a bus or taxi to the venue. Quite an easy London location to get to from Paddington.
Yes now I have done more research you're right Bristol to Paddington is very simple. I just need to convince my employer that its a good idea now.
Bristol would make a fantastic venue for the South West yes.
As you say it will be expensive, hopefully be worth it.
Be good to meet you all if we all do go.
Ah I love Bristol, nothing scary here.
I've been to London a couple of times but with others. Just wondered about getting lost!
My partner goes all the time and says its so easy to get around.
Just thought if anyone was driving (which I imagine would be a silly thing to do) a lift share makes sense
Hi
Is any one from South West England going to the Design Day in London 2nd October?
I'm considering it and thought it was worth checking and sharing a lift with someone - or even just getting the train there together. (I haven't been to London on my own before nor travelled by train alone!) -
Ok thank you. I will take a look and have a go myself first.
Thank you for all your help and time.
So I've created a new title block following Jonathan's youtube video (as mentioned above) and have added some revisions to see if it works and then created the Sheet revision log worksheet instead. This works fine but I much prefer the layout of the revision history sheet - this looks like a drawing register as I'm used to seeing them but it won't update with my revisions.
I've uploaded my test file. -
2 hours ago, Jonathan Pickup said:
Are you using the standard Vectorworks Sheet Border tool for the title blocks?
I've just had a play with a standard one and cant quite get it to work 100% - I'm watching your video on youtube about the VW 2018 title block and am editing the standard sheet border to suit and still cant get the revisions to come up on the sheet. There is nothing in the formula box - what should be there?
Um I'm not sure? The title block was half set up when I started with this company and I've been adding to it and amending. There is a file attached to my original post which has the title block in.
Well that seems pretty pointless! Might as well create the register in excel.
I thought the idea would be that the register would update as I add revisions/issues to each sheet - or least update when the sheet name changes.
Will wait and see what others say too.
Thank you for your response Line-weight
Hi all,
I'm trying to create a 'clever' drawing register. I've created a worksheet data object and its on a sheet; looks great etc. However when I change the name of a sheet for example it doesn't update on the worksheet - I have tried recalculating it. This is also the same with adding revisions. I have my own sheets set up with title blocks that all seem to work fine.
I've looked online for videos/explanations with no luck.
Can anyone point me in the right direction/give me some pointers?
1
Serial number issue now resolved.
Still getting Error Loading Vision Library though
I just followed the steps above and now my computer says my vectorworks cannot be activated because the license has been activated on the maximum number of machines allowed...?
Are there any design summits coming in the UK?
On 6/29/2018 at 3:11 PM, JimW said:
Not here, first thing I'd recommend for this would be to wipe preferences after installing SP4, then a full reboot.
Can you remind us how best to wipe the preferences please?Thanks in advance.
I'm getting the 'Error Loading Vision Library' message again after updating to Service Pack 4....
1
Yes similar. Not the original question as such but the topic soon leads to white/black viewports.
Looks like it was never resolved?
And now its just come back....but I haven't done anything, just updated it again for like the 20th time!
Hi all
So I have a 3D viewport on a sheet layer and it has been was rendered with 'Final Quality Renderworks' since yesterday (it was fine and visible yesterday too). However all of a sudden the viewport is now blank, I've only made changes to the actual model and not the viewports. If I change the render to Open GL I can see the items again.
This has happened many many times and different files. Its slowing driving me insane (more so than normal!)Please can anyone help?
I'm using Vectorworks 2018 SP3
Thanks @Kevin McAllister
Yes its regular and across all my files. No-one else works on the files at the moment so its definitely not that.
So I have a class structure set up and therefore set my attributes to 'class style' but I have noticed that this changes and I'm not sure what key I''m pressing or what action I'm carrying out that is changing this?
Any ideas? Its driving me crazy. I guess sometimes my active class changes to others too sometimes - I might start drawing on my '1 EXTG Walls' class and then all of sudden it might be back to my '0' class? -
Hi Thomas
Have you spoken with Tech Support regarding the undo issue? Mine doesn't do it anymore, and hasn't for some time. They suggested I delete the 2017 preferences/library from my machine. They said not to delete VW 2017 though incase I need to revert back to using it if this issue carries on.
It could be worth giving them a call. I feel your pain, nothing worse than losing work! -
Thanks for the update Jim and SP3
Just installed and reloaded, still getting 'Error Loading Vision Library' message! Any ideas on that?
viewport update crashes VW19
in Troubleshooting
Posted
Hi Tim
Sorry I've been meaning to update my post. I have spoken with technical support UK and George has sorted it out; fresh install I think.
Do you still want to take a look at the file incase?
