Damon Design
    286
Posts posted by Damon Design
  1. Also make sure you have set up the exact/and or unique layer and class names in the destination document to "take" (VW will import all new class definitions) the source items. Once the layers & classes are defined in the destination document you would need to either multible cut and paste all items from each layer name into the corresponding layer in the source doc, or paste all items at once into one layer in the destination doc and then by adjusting class visibilities cut and past those items to get into the layers you wish them to reside in.
  2. This is a minor problem but a bit of an irritation that I'm sure has a quick fix.
    On two projects I am working on right now (and sporadically in the past) when invoking an arrow to a line end there is no data as a default defining the arrow parameters, and I have to enter an angle and a length to see the arrow (actually you have to enter the length first and then the angle -opposite the sequence presented) I know I have attached an arrow to a line in the past and it has a default size to it-I think .125 mils and 15 percent angle.
    Obviously I duplicate the line with the arrow definition after I create one on these projects but... I have no problem editing a default size but it is quicker to have one already there to work on.
    Does anyone know what I have done in these projects to have dumb arrows?
    Thanks
  3. I would recommend developing the model as much a possible in the Design Layer and keeping it as a 3D model to generate the viewport elevations from-you just loose to much connected data when you turn it into lines.
    Some people do use the viewport of the model more as a template to convert to lines and annotate to their needs for elevations though.
    You can create a viewport from a 3D model or a bunch of lines (or a model converted into lines) from the design layer.
    For your specific needs of custom muntins just create the correct window size and type for the model, use no muntins, and then annotate the viewport with lines to create the muntin pattern. The lines will stay linked to the view created for the viewport-and you can still edit the model. This same process can be done for other graphical needs on the viewport/elevations.
  4. There are going to be limitations to every CAD app on the market but I find the 3D capabilities to be quite robust for our needs, certainly improvements are welcome.
    The floorplan design development document eventually becomes roughly half of the construction documents:plans, and the rendered presentation model derived from that document-which invariably sells (or at least best communicates to clients the design)-stripped of its textures -will produce all the elevations, sections and some details with graphical or text annotations as necessary.
    Each of those docs stripped down to their basics becomes the files sent to consultants. We don't design trusses or do the engineering for our projects-thats what the truss company and engineer does.
    I am sure there are more efficient ways and improvements to be made but the program produces what is necessary for us.
    We just presented two projects yesterday and the rendered model sold the designs.
    Granted we are a very tiny firm and do almost exclusively single-family home designs.
  5. Yeah they are pretty pathetic compared to xfrog though
    I already have a nice conifer in the presentation doc with a sketch hidden line overlaying a final quality renderworks viewport and the cartoonish Palm Tree from VW wont make the cut.
    Thanks though.
    Update- OMG I figured it out. Sorry, I have never used image props before (other than the defined ones with the xfrog symbols) so haven't really explored that file. I should have read cbaarch's reply more closely.
    So for those of you who want to know where they are open up the image prop high res folder (found in libraries) and they are hiding among the Toyota Camrys and fire hydrants.
    Yay!
    Cheers
  6. OK so it appears I'm not going crazy.
    Odd though that xfrog has some nice Palm Trees (I went to their website, but it seems they are not in the format that I can use) and VW has included so many of their impressive plant/image props for us to use-like, way more trees and plants that one could ever want-and not include three or four Palm Trees!?
    Not a biggie, just thought for sure they were hiding there somewhere.
    Thanks for all the replys to what is just a simple presentation wish.
    Cheers,
  7. Hey Peter thanks for the shout out
    I can't navigate to that for some reason. The hierchy that I am able to access is VW>Libraries>Xfrog Objects and then the aforementioned files in that folder- I have tried both a VW search and a Spotlight search per your recommendation but that is not in my VW folder for some reason.
    From what I can discern I have Xfrog objects but cannot access or find: Libraries>Plants>Xfrog plant images> and so on...
    Any other hint would be much appreciated because I know they are hiding here somewhere.
    Have a client proposal meeting in a couple of days and ya think that a couple of Palm Trees are a part of the existing site/surrounding area here in San Diego?...
    Thanks
  8. I am flumoxed!
    Just tell me that files in the XFrog library folder includes, 21 deciduous, 6 conifers, 2 shrubs and 1 others plus front and top for each of those catagories and no other files.
    ...cuz Palm Trees would only belong in others in that list and they do not reside there.
    Then I will give up because they are hiding too well for me to find.
    Thanks
  9. Thanks Katie, I'll keep looking.
    I am at this point finding a whole bunch of files labled: 21 deciduous files (are they somewhere in deciduous?-that doesn't make any sense), 6 conifers and 1 other (which seems to be desert plants) but seems like there just should be one saying Palm Trees- I know I stumbled upon them before...
    I definitely need to take some time and just pick a dozen or so plants and create a folder for quick access to create presentation drawings.
  10. Computer list I use is updated, still old school but I think (hope) both will be supported for a bit longer. Trust me, I don't even attempt radiosity...
    Using OS 10.4 I am certainly used to the increased functionality provided vs 10.3- I can't even use widgets or Goggle Earth on this office machine.
    I am so salivating for a new MacPro and at least a 23" monitor and to be able to use my other monitor for pallets-hoping the "firm" -if you can call two people a firm- will provide some funding to that end...
  11. I am in the process of convincing my boss-I am the one and only CAD person in our two person firm-to jump from ArchiCAD which we also have and I struggle with, to now make the complete switch to Vectorworks 2008 now that I have been producing full CDs and nice 3D rendered models for our clients with Vectorworks 12.5, and she also concurs that the flexibility and graphical quality-at least with my more limited knowledge and ability with ArchiCAD-is superior with VW (I know ArchiCAD is a full featured program-I just don't get it very well). I still am on Mac OS 10.3.9 on this computer and will need to upgrade (I wish the computer but only OS for now) to Leopard when it comes out
    So... two things. One: Katie or Dave, I haven't read or heard anything on compatiblility with Leopard Mac OS 10.5?
    and two: those of you who are starting to use VW '08 what are the best selling points -workflow efficiency-I should be using to best convince my boss to pay up and upgrade soon?
  12. Go to Jonathan Pickup's great podcast
    http://web.mac.com/jpickup1/Site/podcasts/podcasts.html
    archoncad
    Listen to Pat and Dan's informative and entertaining podcadtv
    http://www.podcad.tv/podcad/Home.html
    Check out hints on Vectorworks hints on the dispatch
    On all of these go throught the archives- I learn something new everytime
    And don't discount this Forum as I don't think there is a more responsive and helpful group out there for you-just ask.
    Just a few-I'm sure there are more
    ...and DTM's are hard-
    also, when you come across something that seems overwhelming-especially 3D related-just give a shout out to islandmon-he seem's to have the answer to everything. ;-)
    Good Luck
  13. Lately I have been having some issues with the add surface command in edit group mode on a roof surface. After pasting and placing a polygon over the roof polygon and then selecting both> add surface the roof polygon dissappears and the new polygon which I wanted to add remains-which is neither add surface or clip surface-over and over again. I end up double clicking the roof and editing its geometry (adding nodes) using the new polygon as a template but not the quickest way to achieve what should be instantaneous results.
    A hiccup or a bug? Doesn't happen all the time but enough to irk me.
  14. What parameter do I need to input to always show window hinge lines in various render modes?
    Specifically, why do all of my windows (and doors) show hinge direction in wireframe, as I have selected in OIP, yet only some are showing the hinge line when in hidden line or other render modes? I can't tell the difference in settings or OIP between those that are and those that aren't.
    Thanks
  15. I have been listening to the PodCAD podcasts and have also discovered Jonathan's ArchonCAD podcasts both of which are brillant resources of info and tips-kudo's to all of you producing these for us.
    I noticed in one of Jonathan's quick movies that he seemed to have additional items available in his context menu-particularily the "add/edit surface commands", I haven't edited my workspace at all but from my quick glance there it wasn't readily apparent how I might also add these items, which would be quite useful.
    Anybody (Jonathan?) have the info on how to do this?
    Thanks
