teddy4174
    9
Reputation
0 Neutral
Recent Profile Visitors
444 profile views
  1. @Benson Shaw Ok thanks, will go through about it.
  2. @Benson Shaw Thank you if only it appear in my pc. What could be the problem? Is the graphic card the culprit? Or my computer spec is not enough to support the texture.
  3. @Alan Woodwell https://www.dropbox.com/s/7mb6wvu3e32j8fu/TEST Run (Empty Space).vwx?dl=0
  4. Hi Alan, Apologies for being absent on this issue. · Updated VW2017 and now I have problem exporting my image file. · Create on a new black page, VW 2017 crashes every time it renders · Still unable to solve the texture problem but surprisingly on another computer, I’m able to apply existing textures from the library but not creating a new one.
  5. Hi Alan, No, I haven't update yet. Will do it then. Thanks. .Heidi.
  6. Ok thanks for advise, will give it a try and let you know again. .Heidi.
  7. Hi Benson Shaw. Happy New Year to you! Anyway, its alright and Thank You for your reply. I did add a signature once I sign up, should be view able. Followed both of your methods but still getting black texture. Attached here is how it looks like even I try to edit with the existing texture. And you will notice that my textures in the file that I imported from VW2016 are all invisble except one which I added in from VW2017 The black flooring is the Wood Flooring Maple from the existing libraries while the black wall is images that I imported. I'm pretty new to VW and VW 2016 works just fine for me but not VW2017. Sigh. Upgraded my graphic card to 6GB and 16GB ram. Oh did I miss out anything like quicktime? Really appreciate your reply. Thank you! . Heidi .
  8. Hi Benson Shaw. Happy New Year to you! Anyway, its alright and Thank You for your reply. I did add a signature once I sign up, should be view able. . Heidi .
  9. I am getting this error when I try to make a new texture on VW 2017 ("Unable to create a graphics importer for the file. The system may not have an importer installed or memory may be low") as I'm getting some texture in black after imported from an older version. Solid colours are doing alright but not those with texture/patterns. Any comments appreciated. Thank you!
