the.dreamer
23 -
Everything posted by the.dreamer
Hello, I'm editing some lighting instrument properties (weight, wattage…) in Spotlight using the Lighting Symbol Maintenance window as I always do. This time it looks like most of my instrument types are not retaining the information. For example I edit the weight of an Ayrton Eurus, hit OK (and say Yes to the 'Do you want to update instruments?' popup) and when I open the Lighting Symbol Maintenance window again, the weight I entered is gone. It also does not reflect in the instrument summary or anywhere else. Any idea what's happening? Running VW 2023 v28.0.7
Thanks for your help @klinzey! I already checked all of that without success but weirdly today it's working. So restarting Vectorworks did NOT solve the issue but restarting the whole Mac did the trick!
Hello, Since yesterday the Draw Beam tool on all my Lighting Devices is not working anymore. Ticking the box won't draw the beam on plan. Ticking the "Draw Beam as 3D Solid" will only draw the bottom (impact) circle but not the rest of the beam. It only does that on a particular file as far as I'm aware. Maybe I hit a key which triggered a shortcut I'm not aware of? Or is it a bug? Any idea how to solve this? Vectorworks 2021 SP4 macOS 11.4
Exclude Views from Undo History
the.dreamer replied to ericjhberg's question in Wishlist - Feature and Content Requests
Still the same issue in 2021… please change this annoying behaviour. -
Ipad Pro 2018 and Vectorworks
the.dreamer replied to O Design's question in Wishlist - Feature and Content Requests
I’m actually waiting on VW to release an iPadOS app to buy the iPad Pro... -
Perfect, thank you very much !
Very cool workaround ! Thanks !!
I see... thanks for the explanations !
Is there any way to generally custom the hanging position titles ? Ideally, I would like to be able to do it like with lighting instrument labels. The idea is to have more than just text customisation (adding a shape around it, etc.). What would be the simplest way of doing it ?
I want to create a scroller list using a worksheet. As Vectorworks already knows gel colors from numbers, I want it to automatically color the background of a row corresponding to the entered gel color. Is this possible out of the box ?
Still no easy way to add a box around a text ? And with rounded corners ? Would be awesome to add this directly in a text style. I specifically want to add this to the hanging positions names in Spotlight.
Trying VW2020 SP1. Great, two new issues found in the unusable Schematic View : The new Data Visualization tool won't apply colours (or whatever) to the corresponding Lighting Devices in Schematic View The 3D label of a Lighting Device won't show the text on the Schematic View (blank white rectangle) I attach my test file with the two issues. You can find a Data Visualization called LX Fixtures Types and two lighting devices on a Lighting Pipe. Good to know that my file was created in an educational version of VW. A third issue, not related to Schematic View, I had while trying all of this : big full VW crash when using the Close Active View Pane. VW20 is not ready for real-world use… Schematic View.vwx
I updated to v2019 and opened a document produced on v2018. Now if I use the Export PDF command and uncheck the Rasterize PDF option, the produced document is rasterized… And if I use the Print command and then save the PDF from the macOS printing dialog, then the PDF is not rasterized. So it seems there is a problem with the Export PDF tool. Anyone has a solution ?
Hanging Position total weight
the.dreamer posted a question in Wishlist - Feature and Content Requests
It's possible to see the total weight on a hanging position in the Object Info palette. It would be very useful to be able to use this info in the Position Summary or in the Instrument Summary, so we can quickly check if the weight exceed the rig limit. And also an option to include in the calculation the weight of the Hanging Position itself or not. -
Thank you very much to have taken some of your time to help me Mark, all is resolved !
- 8 replies
- texture
- renderworks
(and 2 more)
Tagged with:
Ok, so I worked a little bit more in my own file with the elements you sent me. Apparently it's the lighting instrument (ADB ACP1000) which has a problem, because with another one (tested with an ADB F101) it works well (like on your screenshot). The odd thing is that in OpenGL the light is shown, but not in Renderworks.
- 8 replies
- texture
- renderworks
(and 2 more)
Tagged with:
Oh sorry, I forgot to name them. The first one (gray) is a Renderworks rendering with the group and texture of your file applied in my file. The second one is an OpenGL rendering of the same thing but with the intensity of the texture set to 90% (if I keep the intensity to 10% like in your file, then in OpenGL it's black). It's the only case where there is something approaching my needs (where I see the light through the cyc in fact). But in Renderworks the cyc is white in this case.
- 8 replies
- texture
- renderworks
(and 2 more)
Tagged with:
Thank you for the quick reply ! So, I tried with your file (by copy-pasting the group and exporting the texture) and… it's even stranger. It work well in your file, however in mine in OpenGL it's just black and in Renderworks it' gray. If I set the intensity of the texture to 90%, I have something in OpenGL, but still nothing in Renderworks. I attach two screenshots to show you how it renders. Maybe there is a problem with the lighting instruments… ? Your second solution isn't suitable for me as I want to use the lights behind the cyc.
- 8 replies
- texture
- renderworks
(and 2 more)
Tagged with:
Hello everyone, I have a rendering problem with Renderworks. I created a cyclorama with the Soft Goods tool and created a special texture for it, to allow it to be lit from the back. The texture settings are : Color : White 100% Reflectivity : None Transparency : Plain 99% Bump : None Cast and receive shadows Override Indirect Lighting, Emit Light and Receive Light checked. With these settings it works well with OpenGL, but with all the RenderWorks (I tried Fast, Final and Custom with different settings) modes the scrim is just black. And I can't only use OpenGL as I want to use more than 8 lighting instruments in my renderings. Anyone ?
- 8 replies
- texture
- renderworks
(and 2 more)
Tagged with:
Thanks guys, resolved by adding a texture to the lens object ! Simple but I had to know it.
Hello everyone, I have a strange behaviour on VectorWorks Spotlight 2018 SP2 on macOS. If I apply a gobo (R71005) to an ADB DW105 (didn't try with other models, but maybe there is the same problem), set a Focus Point and turn on the light, nothing appears in Fast renderworks (I also tried with Custom and Final). Thought I was doing something wrong. So I tried with another fixture (an ETC Source 4 36deg), applied exactly the same settings (with the same gobo texture) and no problem, it works like a charm. Anyone has an idea ? A bug in the lighting instrument ?
VW16 crashes on new MBP with Touch Bar
the.dreamer replied to the.dreamer's question in Troubleshooting
I didn't notice this update. Thank you very much, it works with the SP6 update !- 3 replies
- 1
- crash
- macbook pro
(and 3 more)
Tagged with:
Hello, I have an issue with my new MacBook Pro 15" with Touch Bar and VW 2016 (student version). I installed VW 2016 after a clean install on macOS Sierra 10.12.1, updated the software on SP4 version and when I launch it, the software crashes while loading, more precisely when the pop-up menu "You are using an educational version of Vectorworks" and I click "OK". I already tried to uninstall and reinstall it. I also tried to launch the software without doing the SP4 upgrade (SP1). Same result. And I don't have yet access to VW 2017… Do you have any idea to solve my problem ? Thank you very much !
- 3 replies
- crash
- macbook pro
(and 3 more)
Tagged with:
