ford519
  • Content Count
    50
Everything posted by ford519
  1. hello... where can I find my Vectorworks receipts? I'd like to be able to report my software purchases on my taxes... Thanks! also, it looks like I can't access my account for some reason. What should I do?
  2. thanks. the pillow works, but the comforter produces jagged results around the perimeter. also, i'd like to be able to have realistic messiness - folds in the fabric, pulled back sheets, etc. edit: also i don't want to use 3dwarehouse, as it makes my files enormous if i use the beds from there. the 2d plan looks bad too
  3. @Benson Shaw @Benson Shaw it won't let me post pictures, but basically a realistic bed/comforter plus pillows
  4. is this still the best way to create cloth in Vectorworks? or do I still need to use another software like marvelous designer to get more accurate results? Thanks
  5. Is there a way to convert ALL solids to generic solids? All my object history is slowing down my file a lot... EDIT: nevermind! duh! you can just select everything and do it all with one command
  6. I need this as well. Using the Combine Into Surface command a million times to create some graphics, and it's NO FUN pulling down the menu every time. Also, I'm trying to create a shortcut for this command and I just noticed we can ONLY use CTRL, or CTRL + ALT, or CTRL + ALT + SHIFT as modifier keys... why not SHIFT alone or ALT or ALT + SHIFT? As a c4d user, it would be really cool to see the breakout palette idea used as well.. both the split-off window and the "U" or "M" breakout menus. It creates a ton of possibilities for shortcuts when you only have a certain number of keys available.
  7. Hi Everyone, I really need to flat pattern some 3D objects to create some custom graphics, but the unfold command isn't working for me... When I use it, the surfaces are in seemingly random orientation, and not attached or next to eachother (more of an "explode" command). Is there a way to make this tool actually UNFOLD my object? Thanks
  8. Nope. Everything is visible.
  9. Sometimes, when I use the "apply attributes" mode (the bucket) after eyedropping an object, it will delete the object and I have to undo. Then the object will appear again with the applied attributes. VWX 2019 Spotlight sp5
  10. Is there a fix for this yet? Every other 3D software I use can do this... 🙂
  11. Hi everyone, What's the fastest way to create a new image-based texture in vectorworks? In Cinema 4D, I can drag an image to the material manager, and it will automatically create a basic texture with that image in the diffuse (color) channel. is there something like this in vectorworks? Thanks
  12. @Alan Woodwell UE4 I see the "[Virtual Reality Enthusiast]" in your sig.... what's your experience with VR?
  13. When I mirror an object, the pieces/parts that generate it are left in their original positions. I find that this makes it hard to edit the mirrored object based on other existing geometry, since I'll have to find the inner component geometry and guess how it should be edited (there aren't any local references). Is this an intentional in the Vectorworks software? Is there a way to mirror objects and keep the components with them? Please see attached (double click on the extrude) for an example of my issue. Thanks mirrored extrude.vwx
  14. some funny things happened. I was able to export the textures via the resource manager, but they all exported as .pngs and with some 1's and 0's after them instead of 'bump' or 'color' so I have to rename them all. OBJ export gives me 'texture_#' format so it's pretty useless
  15. RickR, this is certainly a 3D file with a lot of 3D data.
  16. Vectorworks is very slow, so this would've taken quite a while. I often find myself sitting, waiting minutes for Vectorworks to do anything before it updates anything in a working file. It seems that Vectorworks can't handle larger files very well. It would be wonderful if disabling layers actually made it faster, but it doesn't really help much.
  17. Hi there, I was able to export a large file ~400Mb to c4d, however none of the textures exported... need to get this done ASAP. Going to try to export the textures and relink, but please fix this. Thanks
  18. I have a large file ~400Mb... trying to export and the 'geometry' bar bottom right fills up w/green, then the operation is over with no notification and I don't see a file in the directory I've selected. Before anyone says "maybe try splitting it up", yes, that's what I'm going to do, since I need to get this done, but shouldn't this just work??? Thanks
  19. sounds pretty complicated for something which should be simple
  20. I have multiple symbols in my file with the symbol origins at the symbol 'center', but I need them to be at the lowest z-point of the symbol so that I can see and adjust the z-height (effectively the trim height) of my flying objects. If I could simply move the origin and leave the symbols in place, this would solve my issue. Is there another way?
  21. yes. this. would be helpful with symbols as well... (plus i'd really like it if there was an option to gray/hide/keep visible the other stuff in the file... sometimes it's useful to have visible references)
  22. adjust the origin for a symbol without moving the objects within the symbol (as an option) - would save a ton of work when origin needs to be moved for a lot of symbols
  23. Hey guys, is there a way to adjust the origin for a symbol without moving the objects within the symbol? I have all my symbols placed already, and would prefer not to double my workload by moving stuff and moving it again........ Thanks
  24. Has something like this been implemented in Vectorworks yet? Using 2018 and just trying to remove overlapping lines to calculate grout footage.... seems pretty hard without an automated command. I'm not a math whiz, and the shape of the surface is weird.
  25. looking for this... 7 years later... can't access the link tho anything like this available? Thanks
