437 -
Everything posted by Wesley Burrows
Apple macOS 13 Ventura Compatibility - Feedback
Wesley Burrows replied to JuanP's topic in News You Need
FYI, Maxon released updates to Cinema 4 and Redshift that have solved the shaders compiling issue for me in Cinema 4D on Ventura 13.1 beta 2. I assume Vectorworks won't be too far behind with an update. Other than that 2023 SP1 on Ventura 13.1 beta 2 is running great for me. -
Whenever Redshift is asked to render something, it has to compile some base shaders before it can start rendering, on previous OS versions there were some "pre-compiled" shader libraries that reduced the amount of shaders requiring compilation and thus let you get rendering much faster. As of yet, these pre-compiled shader libraries don't exist for Ventura, so it has to compile them each time thus triggering a delay. As I mentioned earlier, this is also the case when rendering directly in Cinema 4D on Ventura. So Vectorworks isn't the only software affected by this. -
For what it's worth Redshift does the same thing in Cinema 4D, takes several minutes to compile shaders the first time. (with Ventura). I didn't previously do this. -
Attaching a Single Motor to an Audio Array
Wesley Burrows replied to Wesley Burrows's topic in Braceworks
Thank you! -
I swear that this works/breaks every other release. I think it might have even worked with 2023 SP0, but with 2023 SP1 it doesn't work. It shows the red smart attachment point just like every other motor. I would think this would be one of the easier things to get working consistently in the complicatedness that is braceworks. It doesn't matter if I snap the motor to the bumper.... Or bring the bumper to the motor: Either way, i get this: We are 5 years in to Braceworks and it's still doing stuff like this. Help!
Stage Deck Tool - Xs
Wesley Burrows replied to Andy Broomell's question in Wishlist - Feature and Content Requests
bump -
BUG: Locked Objects are still able to be duplicated
Wesley Burrows replied to Wesley Burrows's question in Troubleshooting
In most other software, if you lock an object or a layer, that means you can't interact with it period. If you need to duplicate or interact with it you unlock it. The entire of point of a locking something is to prevent access to it. So, to me, it's either poor function naming or poor functionality. It should be called "restrict" or something, perhaps with assignable restrictions, much like the cinema 4d protection tag, cause it certainly isn't completely locked down. -
I have to assume this is sarcasm. -
Anyone? -
Vectorworks 2023 Crashed 2 times since I installed several hours ago.
Wesley Burrows replied to rjtiedeman's question in Troubleshooting
Amazingly enough, for me 2023 has been more stable thus far than any release I've used since 2016. And believe me, I've been vocal about it. I still have 2022 waiting in the wings if 2023 decides to start acting a fool though. I'm a crazy self-sabotaging early adopter, but the general consensus around here has been wait till SP2 or SP3 for each new release. -W -
Videoscreen Tool Worksheet Problem
Thank you! -
Hi! I'm trying to make a worksheet that shows only screen sizes for objects that don't have their screen hidden. Pretty simple right? Well, everytime I set my criteria: Looks good right? Hit ok, and it doesn't show the desired result, it wants to only show objects that's screens are hidden, the opposite of what I'm after. So I edit the criteria again and low and behold: It reset itself to true. It doesn't matter what permutation I make of "is" and "false". Or "is not" and true. It always resets after ok to the equivalent of showing only screens that are hidden. Anyone??? @C. Andrew Dunning This is the stock plugin on VW2023. I haven't tried in 2022 yet.
It's really odd, they render clean sometimes, but most of the time not. It doesn't seem to matter what 3D conversion level I have I have set either.
@klinzey Here Ya Go. Hidden Line Test.vwx
Wesley Burrows posted a question in Troubleshooting
Hi, I tried filing a bug report for this maybe 6 weeks ago. Never heard anything. But if you make an object, select it, right click and choose lock. (It should turn grey). If you select the grey (locked) bounding box/object and option drag, you can still duplicate it and move the duplicate. If you command+D it will duplicate but you won't see it unless you have offset duplicates on. The move tool will also duplicate the locked object. If something is locked I would think none of the above should be possible. This is particularly irritating if you have say a venue base plan that's locked and you inadvertently grab it and whatever item you're actually trying to duplicate. This has behaved this way for a while, all of 2022, and still behaves this way in 2023. Can anyone here lookup if the bug I submitted about it actually went anywhere? -
Does anyone have any insight on why hidden line rendering often produces stuff like this as seen in the truss end. Please note I'm not cutting through the truss at all. Truss objects seem to have this behavior most often, but it seems to be hit and miss. This was from VW2023, but it behaves similarly in 2022.
FYI, just found it in the portal.
Hi! I actually did the bottom (CHC 2018) render several years ago. I draw/model most everything in Vectorworks (though I do replace chairs/people with high poly assets in Cinema) and then render/texture/light it all in Cinema 4D, that image was rendered using the Corona Render Engine. I've since switched (mostly) to using Redshift because it's super fast, particularly with volumetrics, also in Cinema 4D. Previously I was comping a standard volumetrics pass over the base render in photoshop. There is just way more control available in Cinema and it was nice not having Vectorworks tied up rendering for hours when I could've been working on another project. I know Vectorworks Cloud Rendering is a thing, but I always had really hit and miss luck with it, which isn't a fun game on deadlines. Though I have found it become more consistent for me recently with cloud publishing. Quite honestly I could never get anything I was particularly proud of out of Vectorworks alone, believe me, I tried. That's not to say it can't be done, but to quote Evan Alexander it was a lot of "Render, Render, Suck. Render, Render, Render, Still sucks". repeat ad nauseam. Once you use something with an IPR (Interactive Preview Renderer) you'll never go back. To be fair, once I switched to this workflow I haven't attempted to use Vectorworks to render since. I know there have been improvements/changes and Redshift is in some capacity available in Vectorworks today, but I haven't messed with it. Also, to be clear I'm not trying to illustrate exact 1:1 lighting looks for clients either, I'm just giving a visual representation of the intent of the design. It's been a while, but I think the above render took about 40 minutes to cook vs like 5 minutes for the below (which is also twice the resolution of the above, and full disclosure I have 4 GPUs so that helps). Screens blurred for client confidentiality, but other than that no post processing was done. I think ultimately you have to choose what is most important to you, render quality, convenience, speed, flexibility, cost, etc. Would it be easier to keep it all in one piece of software? You bet! But I don't think I could achieve the quality I'm after doing that. Asking questions is how I started too. @EAlexander helped me very much on my journey, dude's a rendering wizard, wealth of knowledge, and just excellent human being. I wish you the best of luck!
- 10 replies
- 2
- moving light
- rendering
(and 2 more)
Tagged with:
Vectorworks abandoning perpetual licences
Wesley Burrows replied to line-weight's topic in General Discussion
I mean, compared to any other commercial software, I feel like I've been running a beta version since 2016. Vectorworks, by a landslide, is the least stable, greater than $200 software I've ever used. I love Vectorworks, when it vector-"works". I tried to get in on the actual beta process sometime ago, but that sure is an elusive process. I genuinely hope this is a positive move for stability and update frequency. -
I had this problem for a while several months ago and it vanished with the latest version of cloud services. The below version works for me. You might make sure you're current, I've found mine doesn't always auto-update. Also FWIW, all my stuff is on dropbox. I don't use the vectorworks cloud for storage.
Schematic Views cannot be Pasted without the Model Object they are Based On
Wesley Burrows replied to pfalvi's question in Troubleshooting
I thought the whole point of the new updater was the fast deployment of hotfixes and stuff. It's been a month. I take it we're waiting for SP4 for this to get fixed? I get you can roll back to SP3 to fix this, and that just breaks other stuff. -
Broken here too. -
I round up to the nearest foot using this: =ROUNDUP(0.5+VALUE('Soft Goods'.'TTLSGLngth'), 0) Then use cell formatting to be a dimension.
Apple macOS 12 Monterey Compatibility - Feedback
I was having full on system lock ups and force restarts after periods of time. Only occured when using VW. Just regular modeling and stuff. It would happen several times a day. After more reading, about some memory leaks in 12.1 particularly when using a "custom cursor". (which I don't use) but it occured to me VW changes the cursor often to reflect different tools and tool functionality. So watching the activity monitor over the course of a day it seemed like the ram usage would go up some with each change. Granted I have 96GB of system ram, so it's pretty hard to swamp that. And honestly I never saw VW use anything egregious in the ram department. So it might have been something else. Either way something changed with VW SP2.1, I no longer had complete system crashes, but I did experience strange stuck geometry after a while of drafting. Random symbols from really any layer, off or otherwise . They would have a stuck plan view on the screen plane where the pen changed to white, and the fill to light grey. They would just appear, and I couldn't interact with them, i couldn't figure out the series of events that led up to that happening. A screenshot example is below. (those were the tops of some simple chair symbols). And this is milderer, other times it was all sorts of random stuff from the venue DWG. (which was mostly off). It wasn't all symbols either, and most of the time it wasn't even all of the SAME symbol. Super odd. Either way, MacOS 12.1. was No Bueno for me. MacOS just released the 12.2 Release Candidate, 12.2 has been good to me since the Beta 2 of it. Props to @Gunther and @Mike Lamb for trying to help me work through this. -W -
As an update to my earlier post. I updated to Monterey 12.2 Beta 2 and VW 2022 SP2.1 and it seems to have resolved my problems. 12.1 seems to have some problems.
