444 -
Everything posted by Wesley Burrows
Data visualisations in Equipment Summary Key
Wesley Burrows replied to Mike Wright's topic in Entertainment
So, two visualizations work, however the problem then becomes keeping your colors synced between the two as fixtures change etc. So it works, but isn't ideal. Data Vis with Schematic Views and Equip Summary.vwx -
@Scott C. Parker, So with that criteria, the 2D/3D geometry and the Equipment Summary shows the correct Data Vis, however, the Data Vis does NOT work on lighting devices in a schematic view. When I shift the Data Vis criteria to make 2D/3D geometry and the lighting devices in Schematic View work the equipment summary no longer responds to data vis. Is it possible to get it ALL to work at the same time? -
This doesn't exactly fix your complaint but you can: change the display view from regular to compact mode and that will stretch out the bar to the right in the otherwise unoccupied space. Also that's odd about the snapping, when I unpin it in the view bar settings it drops to the bottom right corner also.
- 99 replies
- vectorworks 2024
- new ui
(and 1 more)
Tagged with:
Yup, that easter egg has been there for a number of years now. 😀. I'm not sure when they added it, but I remember seeing it as far back as 2016 I think.
- 1 reply
- 2
bump
I suspect that the Vectorworks Design Summit ended up being a casualty of the pandemic. Though I hope it comes back some day. I enjoyed the ones I attended.
Vectorworks Cloud Services - Font Missing
Wesley Burrows replied to Wesley Burrows's question in Troubleshooting
@inikolova Hi! While the link is informative for understanding what could be happening, it doesn't really offer a solution, and I realize there might not be one as I'm on Mac and the servers are on Windows. But if it is font related, I'd love to see if we could get that working. I did download Font Forge, but I'm not really sure what I'm supposed to try and convert that font too. Or if that's even what the problem is. -
Script to create selection scripts of used Light Instruments
Wesley Burrows replied to Tom M.'s topic in Vectorscript
I've used this plugin for years, it's a select similar wand tool specifically for lighting instruments. You can select by name, type, position, etc. https://benghiatlighting.com/software/product/savvy-select-similar-instrument-3/- 8 replies
- 4
- vectorscript
- light instrument
(and 1 more)
Tagged with:
I have a some custom fonts in my title blocks/etc that all generally seem to work fine now when cloud publishing, I do full integration on a dropbox for business account, and the fonts are uploaded in a folder there. But there are a couple of font's in particular it just refuses to use. The one that bothers me the most is Gravitica-Light.otf. I don't know if there's anyone that could help me with this? And on a side note, when you publish a pdf locally, the Vectorworks remember's the last directory you published to and takes you there initially with a successive publish. When publishing on Store on Dropbox and Process on Vectorworks Cloud it goes back to the root folder every time. Rather than remembering. I don't know why it behaves differently. -W
Elevations and depth of field
Wesley Burrows replied to AlanW's question in Wishlist - Feature and Content Requests
Upvoted and bumping. -
Attaching a Single Motor to an Audio Array
Wesley Burrows replied to Wesley Burrows's topic in Braceworks
@jcogdell So, it seems these bugs still persist in 2023 SP4. -
Is there a way like with regular snapping to temporary disable rigging related snapping? I know there's a spotlight document preferences option, but it's clunky to go back forth to quickly. For example. You've created a truss, hung lights on it etc, and say for some reason you need to shift the truss L/R of it's current location without moving all the fixtures, or maybe even rigging points, cause say they are fixed hook points in the ceiling. Is there a smart way to do this? I generally want the loads to attach to the truss on creation, but sometimes I don't. Screen PIO's in particular I may want a a specific fixed height from the ground, but they snap to the truss, then you fix it, and say you need to adjust the trim on that truss, but want the screens to stay put, how do you deal with that? I typically have been cutting whatever objects I want to stay put and pasting them back after the move, but this isn't without flaws, that works with L/R moves etc. But projection would just re-snap to the truss. Am I missing something?
Caching Graphics
Wesley Burrows replied to Eric Chase's question in Wishlist - Feature and Content Requests
I can't quite figure out Vectorcaching. On my 16" 2021 M1 Max it seems to work fine. However on my 2019 Intel Mac Pro with Vega II Duos it seem like Vectorcaching just makes it run slower when it's enabled. -
As far as the laggy/slowness/freezing goes with 2023, I've found this: I am 100% convinced that something with the VGM got jacked up in SP3. I've been using 2023 SP2 for a few days now, and it works fine. I "upgraded" back to 2023 SP3 and the problems come back. Doing same mundane navigational tasks, zooming, panning, orbiting, etc in various files yield different results in different service packs. In SP2 the GPU stays low most of the time, occasionally hitting half way on the GPU usage history. SP2: However, in SP3, doing the same activities will randomly peg the GPU. This is when VWX will lag out, or the drawing window will lock entirely, though you can interact with menus, tools, but nothing in the drawing window, it's frozen. SP3: (The first screenshot was a laggy hang that recovered, the second was the drawing window completely eating it) I've switched back and forth between SP2/SP3 and the problems consistently go away in SP2 and return in SP3. I haven't even had so much as a laggy interaction with SP2.
Update to this, I did a repair installation of SP3, and the hesitations and beach-balling remained. I've since reverted to SP2, and SO FAR, I haven't had any of the hesitation, lagging issues. I'll report back after more time passes. But so far so good, you know, other than having to deal with all the bugs in SP2 that SP3 fixes. But I guess it's a trade off I have to live with to make the software more useable. I've been rolling with 7 or 8 drawings open all day, so far so good. Vectorworks has been open all day here, with the above 6, 7, 8 drawings open simultaneously and this is where I'm sitting so far:
This. This right here, super fun.
This is becoming infuriating. Even with a single file open, zooming, beach ball, layer change, beach ball. Whatever mundane task it is, the thing just chokes for no reason, at random. I can't say for sure it didn't do this in SP2, but it is loud and clear in SP3. Based on peoples signatures in here it seems to be a cross platform problem too.
I also seem to be seeing this more if there are several VW files open at the same time. A lot of the same types of stuff happening as mentioned above by others. I don't understand why this is. When I deal with even larger amounts of high poly geometry in C4D, (I often replace geometry from VW exports with higher poly replacements for renders) and it goes all day without missing a beat. I'm not modeling high rises or anything, just live events. I have a hard time believing 96GB of RAM just isn't cutting it anymore for what I do. Particularly when the problems soley arise in Vectorworks.
It sure feels like something happened with SP3, i get random HARD beachball hangs when orbiting in wireframe, seemingly at random times. Usually after using the program a while, sometimes Vectorworks will come back to life after 20 seconds or so, other times the drawing window just freezes, I can interact with the tool bars but the drawing is stuck, once or twice the drawing window turned red, like it crashed the video card driver. It also likes to beachball so hard the system reboots. I've never had that happen in any other software. Only happens when using Vectorworks, and seems to be file agnostic.
If I remember right you have to have a lighting device in that DLVP for it to allow you to rotate it.
As the title says, just looking for a decent suggestion of drape folds in 2D hidden-line section views via a hatch assigned to the drape texture. Any help would be appreciated. I currently have the above, which is ok, but I'm not super happy with it. If anyone has an improvement on this, I'd appreciate it.
Graphic Legends Recalculate on Publish?
Wesley Burrows replied to Wesley Burrows's topic in General Discussion
Thanks @Pat Stanford! This is a nice work around for now. (Provided I remember to run the script 🙂 ) For anyone else interested, wishlist item is here: Please upvote if you would like this too. -
For some reason Graphic Legends don't seem to update on publish, and thus require manual re-calculating for each one. I'm not sure if this is a bug or working as designed, but I do know it's inconsistent with how worksheets behave. It would seem to me, to best avoid errors and mismatches with drawing revisions, these should recalculate on publish, as this is how I'd expect them to behave and would be consistent with worksheets. -W
