VClaiborne
93 -
Everything posted by VClaiborne
Spotlight > Vision dmx patch options
VClaiborne replied to allannathan's question in Wishlist - Feature and Content Requests
@bbudzon Vectorworks Export menus should do this kind of mapping for you.... -
@JustinVH yep, i just found it there.. i thought i had deleted my last goofy comment in time... 🤭
so i realized that i have folders in my RM in VW2019 that I don't have in VW 2018 sp6.. I installed VW2018 SP6 on my Mac laptop yesterday, and that was what I was using when i wrote about needing those rigging bits.. now that I'm back onto VW2019 Sp3 I do have the CIty Theatrical folder you showed with the arms and the search for c-clamps shows alot of symbols, thanks!
@JustinVH thanks for this!
sounds great. Ideally, by having these types of things connect to objects like truss and pipe just like fixtures, BW could then properly account for weight. in the meantime, I'm just trying to draw up all the bits I need to extend a source 4 leko 48" below a truss LOL
@JustinVH thanks for the tips, Justin, I did try a RM search for c-clamps but nothing showed up. Would love to have these types of symbols available to insert using the insert rigging tool and/or insert lighting tool, and for them to connect to truss like a fixture as well 🙂
Looking for generic symbols for things like C-Clamps, Mega Claws and Clamps, Side Arms, tail downs, extenders, tube extenders, Safer Side Arms, etc. Does this exist already? I've checked the Service Select Portal and don't see anything there...
vision Vision needs a Virtual Software Console
VClaiborne posted a question in Wishlist - Feature and Content Requests
How many Vision users out there think Vision needs to include a Virtual Software Console that gives you the ability to control fixtures inside of Vision without a lighting console??? Click Like if you agree! Shown Below: WYSIWYG Realizzer Light Converse -
hey Mark, I've tried putting this fixture request through your link on this page as well as through the service select portal but neither seem to be going through.. so here is my request:
We need to add all three PRG Ground Control Followspot fixture profiles into Vectorworks as well as Vision please:
Bad Boy
Best Boy
Super RayCurrently, none of these are in the Vision profile library so you can not export them to Vision
https://www.prg.com/technology/products/luminaires/groundcontrol-followspot-system
thanks!
Vickie
Vision & Backspace and/or Delete
VClaiborne replied to VClaiborne's topic in Vision and Previsualization
i didnt enter a VB, but will do so now 🙂 -
Hi Jim, this has been happening for me with build 459802 when I open the Spotlight Preferences window, turn on the 'Perform Complete Reporton Exit'and click ok. I entered this into Jira already as well.
VWX Beam Directional markers: how to disable in Viewport?
VClaiborne replied to VClaiborne's topic in General Discussion
thanks LJ! thats a great tip!- 4 replies
- 1
- spotlight
- vectorworks
(and 1 more)
Tagged with:
@JimWoodward thanks Jim, that is exactly what I was looking for!- 4 replies
- spotlight
- vectorworks
(and 1 more)
Tagged with:
Hi VWX team, how do I turn off all beam directional markers while in Viewport? I inserted LEd and moving lights and created a viewport and have these directional arrows and angle markers that I want to turn off but can't seem to locate any settings for this thanks!
- 4 replies
- spotlight
- vectorworks
(and 1 more)
Tagged with:
@Rob Books thanks Rob!
thanks Jim, how about requesting it for the Vectorworks library, is this the same link?
@JimW "What if I need a fixture that isn't included in the library? If you need a fixture that is not included, simply submit a request to Vision Support via the fixture request link on the homepage, and we will make every effort to provide that to you within 72 hours, often sooner. Additionally, we will make that fixture available to all our users via the update server." Jim, where can I find this link? I need to request a fixture in the library thanks! vickie
vision team, is there a trick to getting zoom to work in Quad view? in the attached image, I have not been able to get zoom to go far enough in towards the stage and vehicle before it completely disappears off the screen and i get weird 'artefacts' instead of a close view of the stage... any tricks?
hello vision team, i have a few questions in reference to the "Toggle Grid" option in the Window menu.. are there preferences for this grid? is there a way to move the grid? What is the grid relative to? what is the spacing? is there a snap to grid function? in the attached image, why does my grid appear off to the side away from the 'Looked at Point" marker? and how do I reposition the grid?
So I'm noticing that when I click in a value field in the Root Properties menu that backspace will delete the values as long as the entire value field is highlighted in Blue, but if I click into the field and then try to use backspace to backspace out a single number in the field that neither backspace nor delete will delete the number preceeding it.. this doesn't seem like expected behavior to me and is inconsistent with the backspace functionality in Vectorworks, so I'm curious if this bothers anyone else? I would expect the backspace or delete key to back up a space while removing the number, enabling me to type in a new number without an extra step of having to highlight the individual number first...
Dealing with Vision Application/Document Settings
VClaiborne replied to bbudzon's topic in Vision and Previsualization
@bbudzon here are the settings I prefer to change from the defaults: In the Document preference/Root properties menu: Render Shadows TRUE (ON) Camera FOV somewhere between 60-90 Rendering Normals TRUE (ON) Specular Strength 100 (I like the appearance that the beam closest to me appears brighter) Bloom Percentage- I set this to 0 Bloom Lens strength- I set this to 0 Resolution Quality: 1920x1080 Texture/Shadow/Surface Light quality: all stay at Medium for me but I can lower the surface light quality to Low without really affecting much if i leave texture quality at medium I have my looked at Distance set for 1000 also -
far clip plane vs look at distance
still not seeing any difference with the mouse scroll wheel, zoom seems the same to me... same with Pan as well. -
i am not seeing any difference in the reaction time while using the flyover tool, is that what I'm looking for? -
"Push Looked At Distance is a way to make the camera tools interact the way you want them to. Small numbers mean you can get closer to objects, but this can make large motions take longer. Larger values mean you can't get as close to objects, but large motions will be faster. We decided on 90 as a default. I often use 300 unless I'm trying to get close to a fixture or scene object." Brandon, I'm inside an esc that has a object, the 100x100x60 room with ceiling and walls. If I'm understanding looked at distance based on the description above, adjusting the looked at distance, should I see something happen on my screen if I'm currently inside the walls of the room, correct? is this like a wider camera viewing angle? I don't see anything happening at all on the screen even if I set the number to 1 or 1000.
