joestewart4669
26 -
Reputation
3 NeutralPersonal Information
Location
United Kingdom
Recent Profile Visitors
Hi all a pop up saying “Vectorworks 2025.app” would like to access data from other apps' Should I allow it? See screen grab. Thanks all.
absolutely brilliant. Thanks all !
Hi all, stumbled across this looking how to model a mobius strip. I’ve come across this which is interesting http://demonstrations.wolfram.com/MoebiusStripAsAHalfTwistedSquareTorus/ Also I’ve attempted to create a mobius using the subdivision primitive. Anyone else had any luck with that. ?
You are amazing. Thanks so much!
Hi, Am I using the wonderful script you sent correctly as it doesn't seem to work in VP annotations? Many thanks Joe
Hi Alan, Thanks for sharing the file. How do I use this with the railing/fence tool please?
Hello I cant run the script as only this file is in zip folder. 'Clear Print Setting.txt' Not 'Clear Print Settings.vss VectorScript' Please re-send the .vss file. Many thanks in advance
Global editing of callouts from a database worksheet.
joestewart4669 replied to Boh's topic in General Discussion
Hi Boh, This is so very kind of you. Thanks. Im going to have a play around and try and figure it all out which Im sure I will be able to now. I'll come back to if I have any problems. Thanks again Joe -
Hi again, I think I should add some more to my post above to explain further. I cant figure out where the worksheet I pulling the text from. When I click on the database header for Column A / Note the fields are blank and I cant relink it as there is no ' Text option in the records of callouts. I have the same for Columns C, D, E, F, G, S, T, W, AA, AF and AG Please see attached screen grab. Ive tried opening it with VWX 2020 and 21 but to no avail. Im no expert on this so apologies if I am missing something obvious. One more question if I can be so cheeky, how do you create a custom column in a database row so I can enter my own text alongside database information? Many thanks in advance. Joe -
Hi Boh, Your HOUSEKEEP worksheet is absolutely brilliant. I don't suppose you have one for VWX 2023 as I think some of the functionality has been lost when opening the one you kindly shared. Maybe not but I'd like to check if possible. Many thanks Joe -
HI Iskra, Thats amazing I had no idea ! Thanks so much! Regards
Hi Dave Thanks for yours. I should have mentioned that I don't have VSS anymore. Sorry. Regards Joe
Hi there, How do I email the exported to panorama file to a client? Ive tried adding the java, jpg and html file but im not allowed to attach a Java file. Any help appreciated.
