32 -
Calendar
Everything posted by Hamo
All 3D hoists are shown without gates on the hooks. Please change this. All 3D Reeved / double purchase hoists do not show reeve blocks. Please change this.
I shall give that a whorl. Thank you
Also, can the icons be moved from the bottom right of the drawing page? It's so close to the bottom the every time I go near it I get my MAC dock appear.
Is it just me or is the new snapping pallette a pain in the bum to get right? Setting the 'Snap' and 'Smart cursor' was (for me) a 'set & forget' in 21. Now I don't know whether it's on or off. Hamo
Thank you Pat. That was going to be my next port of call. Just discovered something else about the Nut & Screw assembly. Change the fill colour of the bolts and it changes the the colour of the whole assembly. Another path to travel down. Oh well. H
Hi Pat. Think I've found the answer. Using individual components, we get loci. Using the Screw & Nut assembly, we don't get loci. Now I just have to replace everything. Thank's for pointing out about 2019 - I'll update the profile H
Change posters status name.
Hamo replied to Hamo's question in Wishlist - Feature and Content Requests
Exactly. that’s interesting about the commercial web service. I’ll have a look into that. H -
Good call. -
The status of ‘Greenhorn’ for forum posters is insulting and misleading. It implies the poster is an amateur and new to VWX. just because someone doesn’t post that often should not be taken to mean they are not experienced with the program. Recently in posting to the community I get replies that make an assumption I’m an amateur and respond accordingly. status could quite easily just be the number of years a poster has been using the program. 1 to 10+ would work. it’s insulting and needs to change please.
Hi Pat. ive been using VWX since it was Minicad back in the 90’s. I’m not sure why you would suggest I should check out the demo version. Can you enlighten me please as I may be missing something? not sure why you can’t see the 3D loci insertion points. They are definitely there. You must have something turned off in your prefs. Love to find out what it is. As an excercise (please humour me). Drop an M10 metric 3D hex bolt from the ‘Fasteners’ tool box into a drawing. In wireframe, zoom in on the head of the bolt and see if you can see the 3D insertion point loci. H
This is what i'm referring to Pat. If I have 20 screws in a detail the 3D loci zoom up as I zoom out. Now, if I can get to the original symbol of the plug-in object then I can edit it and change the class to 'NonPlot'
Old shot, but there’s an hydraulic drawing board under there somewhere. H
Hi Markdd. Thank you. unfortunately, the 3D loci are fully embedded in the plug in without a separate class allocation. Something that needs to be fixed at source please VWX. Plug in’s now cannot be edited at the working drawing insertion level, but rather need to be found in the application files (if you can find them that is) and then ‘drilled’ down still further to edit one simple symbol. Whenever I create a plug in from scratch I ensure that the insertion points are classed as ‘NonPlot’ to avoid the visual cluttering that can happen, particularly when drawing detailed machine drawings with lots of nuts, bolts, washers etc. Another little nugget for the VWX wishlist pile. H
I'm using the Logitrch MX Vertical and whilst it takes a bit of getting used to at first, the reduction in wrist strain and and RSI has been very noticeable. Certainly recommend investigating it.
I would like to add a class of 'NonPlot' to Plug In insertion points (3D Locus). I'm aware they don't print, that's not the problem. However, when I'm using a lot of plug in's from the the 'Fastners' or other tools pallets, they start to clutter up the drawing and I would like to turn them off. Anyone know how this can be done now? H
I'm trying to understand the logic behind how the 'Drawing Label' change in 2021 is more efficient than the legacy version. As far as I can make out, if I need to get my drawing labels to look like the Legacy version (see attached image) I have to go through a whole process of editing the style. Somebody enlighten please.
If it’s purely based on how often a person posts, then a frequency rating might be better.
Is it possible to change or remove the term 'Greenhorm' from the forum members ranking status please? Just because I don't post very regularly doesn't mean I'm not an experienced user. The title 'Greenhorn' implies that I don't know anything and other forum members who don't know me assume that I'm a novice.
@jcogdell Logically the 3D symbol should be stacked on the truss as that is what will eventually be rendered and calculated in the total load calculations. At present the 3D locus for the sling is offset from the symbol insertion point by 300m in both the horizontal and vertical. I have had to edit all the 3D symbols so that the insertion points are correctly positioned under the hoist hook. It's a bug and needs to be fixed. Turning off the class 'Rigging Accessories' also turns off other 3D un-associated items such as clamps, shackles and slings. This is not useful. I have remedied this by editing the 2D symbol and renaming the class as 'Pick Up 2D'. I've had to do this for all the resource pick up's. This is not time efficient. Apologies for sounding grumpy. H
I'm having interesting problems with the insertion of hoists and slings in 2021. Slings do not automatically centre on the truss. It appears that the insertion point is way off centre. Slings appear as a 2D elevation icon in 'Top/Plan view. Allocating a separate class and making it invisible is the only way to get rid of it. Selecting a sling from the 'Pick up symbol' only raises the hoist position (motor down) and doesn't include the sling. Pointers would be much appreciated please. Hamo
One for the wish list. Can we please have an option to include hanging clamps for all fixtures?
In my humble opinion the button labeled 'Click to insert a dead hang bridle' is misnamed and causes confusion. As a qualified & ticketed class1 rigger, I would opine that there is no such thing as a 'deadhang bridle' (happy to be corrected of course). In my world, a bridle has 2 or more 'legs'. What this button should refer to is 'Click to insert a deadhang dropper'. A 'Deadhang dropper' is usually used to extend the length of the hoist chain down from the rigging point if the hoist chain is too short for the height of the venue roof. It can also be used from the truss up to the hoist hook if the motor needs to be 'out of camera shot'. A Dropper (or 'Stinger') is usually FSWR with a thimbled eye on either end.
So, with 2020 are we any closer to getting fully detailed bumpers and speakers into the Array tool?
@DBruhnke No, the workspace hadn't changed. Managed to fix the problem by running the updaters and 'Repair' mode. Still not sure why it happened.
For no reason I can see or understand. Renderworks has disappeared from the program completely. Renderworks commands are no longer available in the rendering drop down menu. Worked fine yesterday. Today, vanished!!!!! VWX 2020, MAC OS Mojave Any clues?
