Hi,
I am finding that after ~30mins of using Vectorworks 2017 & 2016 the redraw rate and the object info boxes flicker and the program becomes really slow. Changing between tools and moving objects around the screen is laggy to the point where it affects my workflow. Text boxes are almost impossble to work with as i can't select text or move text without waiting a few soconds per operation.
I would like to think that i am running powerful enough hardware to not have a problem but clearly something is not right and i can't seem to track it down.
I phoned up the Vectorworks support line and they tried to fix the issue but to no avail. The girl was very helpful but basically just changed some of the graphics properties within vectorworks which made no difference.
It does not matter how large or small the file is, how complex or how simple the geometry is. I am working only in 2D plan.
Sketchup, 3DS Max, Photoshop, Illustrator, Premier Pro etc. all work absolutely fine without any issues but AutoCAD suffers the same issue.
I am hoping someone else had had the same problem or knows where i can next look for a solution.
My specs:
AMD FX 8350 CPU (8 cores overclocked to 4.7Ghz)
AMD radeon R9 270x 2gb dedicated RAM (this is a dedicated graphics card)
16GB Corsair DDR3 1333mhz ram
both programs are running on an SSD (samsung 840 pro)
ASUS TUF Sabertooth 990FX R2 motherboard
Windows 10
2 screens @ 1080pi each.
i would be hugely grateful to anyone who could shed some light on the problem. I am not sure how to track down if its a hardware issue or a software issue.
Many thanks
402-102-B-GroundFloorPlan.vwx
