Ornette
24 -
Posts posted by Ornette
ok that might be it - I am upgrading both computer and vw in the next few weeks
file attached thanks
hi,
thanks - the wall is unstyled and has no components
doe anybody know why vw prevents wall thickness editing in the object information palette - why would this convenience be removed?
Thank you - pretty obvious, not sure how the class options changed, but anyway problem solved, very grateful for your help!
hi thanks, file link attached (vw forum is not uploading the vw file for some reason maybe too large @ 24MB) - a good example re: problem in the file is the ground floor plan - both layer and viewport
https://www.dropbox.com/s/ofnru50zjyghqov/230227 Amess Planning Permit Application.vwx?dl=0
all windows symbols have disappeared in the layers (even with all classes on) however all the same window symbols are visible in the viewport - weird - hope this is not another corrupt vectorworks file
Thanks, I did switch Safari off which didn't work at the time, although I understand Safari can impact panning.
My nudge tool has been disabled today for no unknown reason. I have tried the preferences settings to no avail. Has anyone else experienced this?
My line attributes are repeatedly changing without prompting.
I often select an object to change its attributes, however this automatically changes the default attribute settings to those of the selected object. This is specifically an issue with VW19, and has never occurred on previous versions.
20 minutes ago, dtheory said:
can you be specific about bugs, include what your machine is etc...
I have gone back to VW18 - simply do not have time for Nemetschek's crowdsourcing of problems with weak beta standard releases.
- 2
I have to agree with this. VW19 is unfit for commercial use.
- 1
My scroll zoom is disabled on VW19. This occurred yesterday without any prompts. Scroll zoom works normally on other software. The loss of this function makes VW19 pretty much useless. Does anyone know why this is a good idea?
Can no longer scroll vertically in palettes in SP4 update - is this supposed to be an improvement
Tech support have suggested that perhaps I have too many viewports, and that memory is likely to be an issue. What I do not understand is that the problems occurs with 'fast render works' and not with 'fine quality render works', so I am not sure if this is entirely a memory matter. Tech support have suggested 15-20 rendering viewports maximum.
I still have this problem from the upgrade to VW17 including the SP3 update. Needless to say it significantly devalues any reason for purchasing VW in the first place, or using it in a grown up commercial context. I am not impressed that my business is being used as an experiment for a permanent VW beta phase. Extremely unlikely that I will be renewing my subscription.
I am also having this issue + renders are low resolution. Can't keep restarting every 10 minutes - something seriously wrong here. Render works is fundamental to the appeal of VW. Needs to be fixed asap or no point persevering with VW.
This happens to me all the time. Is there any other solution than restarting?
Render works is crashing very often in VW17 - this can happen with very simple renders at only the 2nd or 3rd render of the day.
Hi Allan
That certainly solved it! I am very grateful. I have usually not applied textures to windoors - is this a VW17 change?
Are you also able to advise why the number of doors always defaults to 2, regardless of changes I may make to it. Thanks again!
Hi Alan
Please find attached the link to the simplified file.
https://www.dropbox.com/s/xe5haqx0xciozss/161118 Windoor Issue.vwx?dl=0
I appreciate your willingness to assist.
Hi
Thank you for the responses. I am very familiar with the advice you have provided, and have tried all these measures once again. Regardless, I am unable to control the 3D finishes of indoor symbols, in particular interior doors. Can anyone else provide any advice re: my initial questions?
I am unable to control my windoor settings, eg.
a.textures applied to classes are not appearing in the renderings.
b. the number of doors always defaults to 2 even after I change the setting to 1.
The windoor symbol is also unstyled - can anybody help?
can not edit win doors inside symbol
in Troubleshooting
Posted
can not edit win doors inside symbol - in fact they disappear - really need to fix this problem!
