HI,
I use VW2016 on a MAC book pro and have a 30" auxiliary monitor that I also have plugged in that I work from on both screens. When I updated and reloaded 2016, I lost the ability to see my ATTRIBUTES palette. VW went back to default setting which means that the palette windows were attached to the working space instead of moving freely. All were there but the attribute palette even though it was checked and showing as being open. I normally work with pallets outside of working plane so I pulled them off to usual placement, clicked to hide the attributes palette thinking that might help, but to no avail...I've done the short cuts, clicked un clicked. Still no palette. This also happened when I first downloaded the new VW and I was able to get the window open, after numerous tries and looking online for the answer. I believe that it was stuck in this no mans land of the two monitors, as absurd as that sounds. That said, once the program went back to default it went missing. Any suggestions???? I need to change my lines, and attributes! Thanks!
