Andre L
Vectorworks, Inc Employee-
52 -
Reputation
16 GoodPersonal Information
Occupation
Senior CAD Content Developer
Location
United States
Recent Profile Visitors
"Howdens" (UK kitchens) base cabinets have wrong dimensions
Andre L replied to line-weight's question in Troubleshooting
@line-weightWill be removed. The tool at this time can not reproduce these types of cabinets. -
@line-weight The depth has been changed to 575mm. The L Shape would have to be added by the user manually. It's not supported as a feature in the tool at this point. I will submit a tool enhancement request. -
The Drawer-Line Corner Base Units and Base Hi-Line Corner Units depths have been corrected to 575mm and the front legs have been moved back from the front of the cabinet. I created an enhancement request to support specific customization for offsetting the leg insertions. The tool currently only has one parameter (globally) to set the Apply/Kick/Inset front, back, left and right. However, cannot set the back or the sides with specific number settings to control each side independently. The doors have been set to overlays. Also added appliance tower configuration. These changes will be in the next 2024 update. -
@line-weight Howdens specifications are very limited about these cabinets. Also, I can't find any model numbers for the actual cabinets. From what the PDF shows, the nomenclature is size (800mm) and Left or Right door swing is what we are using. The PDF's is very general, and it only provides DXWXH. The Drawer-Line Corner Base Units in the PDF say D631mm and the Drawer-Line Base Untis is D575mm. We can correct the legs to move back to 92.5mm from the front. As for the Clerkenwell doors these should be overlay not insert. Will make these fixes for the next update. Also @Tom W. provided reference for the corner cabinets. -
@line-weight Those cabinet type were removed for 2023 and have been re-designed for 2024. The corner cabinets have the correct sizes. Im not sure what you are referring too? -
We will remove these cabinet types from the catalog for VW 2023 SP5. Thanks -
@line-weightNo. The cabinet tools are being redesigned for 2024. The engineers will redesign the geometry. All content will be revaluated. If you like, please give more details of the issue. Thanks -
Okay. The catalog in Vectorworks was built correct based from the Howden catalog. Then I must of misunderstood of what is the issue? @Tom W. -
The catalog says, "800 Hi-Line Corner Base Unit." H890 x W1031 XD631. The width 1031mm doesn't not reflect to the name of the model. Looks like the first three Corner Base Units model name does not match the Width. The pdf that Howden provided Tewkesbury "Range Summary" seems to be missed typed saying 800. If you look at all Sink Base Units for example 800 Drawer-Line Sink Base Unit (LH & RH) H890 x W800 x D575. The width 800mm does match the title/model in the pdf. See images please. "Where do those 1031 and 631 numbers come from?" They came from the Howden catalog see image. 800 Hi-Line Corner Base Unit - Height 890 x Width 1031 x Depth 631. "I can choose between 3 models, "800", "900", "1000". What do those model nos refer to? Something in the Howdens naming system? Don't think so. The basic width? Well, an increase in 100 in the model number seems to be reflected in an increase in 50mm in the actual dimensions. So, doesn't look like it." Please see Howden catalog PDF. H890 x W1031 x D631 and the dialog box in VW does have it correct. The Model #800, 900, and 1000 are wrong for the first three Corner Base Units. Need to be fixed in the VW dialog box to say Model - 1031 Hi-Line Corner Base Unit to match Height 890mm Width 1031mm and Depth 631mm and etc.... Look at SInk Base Units and these match the Howden PDF catalog see image. -Overall, this will be fixed in future release. Thanks. -
We don't have a timetable as of yet.
We can look into adding Therma-Tru.
VW Entourage People - Need Diversity
Andre L replied to cberg's question in Wishlist - Feature and Content Requests
Currently we have African American on our Vectorworks Service Select . We are going to add more diversity for future releases. -
As what Rob has commented, we will be releasing more. -
Resource Content Request - Drinking Fountains
We could add more fountain drinks
