Collyns LD
33 -
Reputation
2 NeutralPersonal Information
Occupation
Production Everything
Location
United States
Recent Profile Visitors
Here's a reduce version of the file as i cannot post the one i was working in. Same issue in this file. Array Test.vwx I need a wall that is 12 x 12' horizontal tiles that i can rotate in any direction. What i think is happening is that it is that it does not take into account the first tile insertion.
Attaching Record to Plug In Object create from Node
Collyns LD replied to Collyns LD's topic in Marionette
Will this work with setting the class as well? I'm stuck there too... -
That seems to have done the trick! Thank You! -
Thanks for the response. Do i break the link and just place the PIO Parent in the file as link it to the hObj input of the record? See images attached. -
In this marionette, i have records being attached and updated as the size of the truss is changed in the IOP. The records are name and weight so i can sort them and pull weights in a area based on x/y. The records work great as a marionette object not yet wrapped up. However, once it's wrapped and then converted to an object node, the records are no longer attached. I guess before i bang my head against the wall, i should ask " Is this is even possible?" Tyler Truss GT Marionette.vwx
Marionette Set Class not functioning properly
So I jammed a second group and a second set class after the frost ones and now it's working. It wont work with only 1 set class at the very end. Now on to adding the legs 🙂 -
I'm kinda stuck and need a little help. I'm creating a Tyler GT Plug-in object that contains all the truss i use, and allows the connectors to be flipped. For easy sorting on big shows all symbols are in a "master class" but i would also like them Marionette symbol that is created to be placed in classes according to length for easy sorting. Everything is working and the debug print is showing the proper string, but the class is not assigned the the object the first time around. it's takes two presses of the run command to assign the class by the radio button length option. As a result, when creating a plug-in object out of the wrapper, you cannot run the script twice so the class is never changed. Can anyone please point me in the right direction. The only thing i can possibly think of it's trying assign the class before the object is done being created, and second time around, it's already there. Is there a way to time the script? Maybe a sleep function? TRUSS v2019 Marionette Test V2.vwx
v2019 3D Label Legends not working in 3D
Collyns LD replied to Collyns LD's question in Troubleshooting
It appears that i cannot have a container present for the 3d to work. And after the file has been introduced a container into the lebel legend. the 3d portion no longer works at all, container or not. Then the scaling gets real weird and wont let me do any 3d in the file at all. See video in this link post container: https://drive.google.com/file/d/1mfVJGnAXtQluvfXOzqKGP2lZYGjykAVb/view?usp=sharing -
It turns out the label legends that were used in 2018 are only semi compatible. Create new label legends in a blank file with no 2018 influence was key. -
Has anyone else given this a try? Just tried to make a new label legend for a lighting instrument and it will not appear in 3d not matter the class assignment.
v2019 Hangs when editing annotations on a section viewport
I sent the info the support via premium tech email. please see that email. I included a video
