Taproot
    516
Posts posted by Taproot
  1. I'm curious if a VW Employee could chime in on this topic.  When I spoke with the sales department last year, they told me that perpetual licenses were non-transferable.  The work around being that the software could be transferred to another party, but the original owner would still be the one in their records ...
    That would make on-going upgrade fees complicated.  It also seemed counter-intuitive.  Why I am I paying thousands of euros / dollars to buy an equity stake in the software if I can't then re-sell it to someone else?  I think the logic is that a perpetual license holder pays a lower annual fee.
    Still - this seems like a point of confusion and it would be helpful to understand just what rights are attributed to 'perpetual license' holders.
  2. Yes, I asked for this feature back in 2017 and to date it doesn't work.
    I became so annoyed by the lack of this essential feature that I moved all of my product scheduling out of Vectorworks into Airtable and now just ID elements on the plan but use the online database to manage the content.
    One would think that for a Building Information Modeling software where nearly all of the "information" is on the web, there would be better means of linking to it.
    • Like 4
  3. You just need to add the .vsm file to the "Plugins" folder located in either your Vectorworks app folder or your User folder (depending upon how you organize your custom plugins.
    You'll then need to restart VW.  When it starts up again, the available plugins will be refreshed.
    Then go to menu: Tools>Workspaces>Edit Current Workspace
    Select "Menus" (not Tools or Keys)
    On the left sidebar, flip down "All Menus" and scroll the list to the new plugin name that you want to add to your workspace.
    Grab it and drag it into the menu location of your choice (at right).
    Once there, you can assign a hot key (short cut).
    • Like 2
  4. I can't speak to the plug-ins issued in each version of the software package, but one possible work around would be to use the v.9 software and create a symbol library of "exploded" fasteners.  that you can use in the current version.  Obviously, they would be a little less convenient to use, but if you set them to import as "groups" then you could pretty easily adjust the length of the bolt shank, etc. to meet your needs.
  5. This isn't a VW specific question, but rather a Theater Lighting Question.
    Giving the amount of theater lighting talent here, I'm hoping you can point me in the right direction.
    I've designed a small gathering space for a non-profit that wants to light a speaker podium / stage with (2) frontal lights and (2) side lights.
    I did some quick calculations on lighting levels and our client selected a 50w LED dimmable unit for the four locations.  This one.
    They ordered one to try it out and learned that it's DMX and too sophisticated for our ultra simple direct wired system (which is already installed).
    They would like to just have each light on it's own dimmable switch.
    Can you give me a recommendation on:
    1. Is this possible?
    2. What would be a suitable unit / dimmer combination?
    Thank you.
  6. @vassen Since migrating to 2021, the rendering problem that launched this thread hasn't been a problem.
    As to rendering style, here's some tips:
    • We use two lights for each elevation - one that casts shadows and one that does not.  The secondary light acts as a fill light (like in photography) so they are aimed at the facade at opposing angles (from above).  The four pair of lights are rotated 90° from one another so that each one will optimally light one of the cardinal directions.  Each pair of lights is classed so that they can be turned on or off per elevation.  We then turn on the appropriate lighting pair in each viewport so that the shadow best illuminates that facade.
    • For schematics, we set the elevation viewport display to Open GL with the foreground set to Hidden Line with the "Certain" sketch style applied.
    I hope you find resolution to your slowness issues.
    • Like 2
  7. @KrisM For what it's worth - I tried using the 'check for update' menu item and then the updater appeared to update my version, but in fact did not.  It didn't ask me to close the software as a part of the update process - which was a red flag for me.
    I then restarted the software and went through the process again.  The second time, it asked me to close the software, displayed my serial number and took considerably longer - all good signs (except maybe that last part).
    That did the trick and now it works fine.
  8. @Boh  I think you've taken notes and callouts to a more advanced level than we employ.
    With just two of us presently in the office, we haven't invested in a rigorous callout system just yet.
    I think your note / symbol technique is a clever way to carry duplicate information across multiple sheets.
    We currently use simple worksheets to achieve the same end - as all copies of the worksheet will update simultaneously.
    In the big picture, my sense is that VW is going through some growing pains in terms of how it handles data.
    There are records and worksheets and notes and data tags...
    Personally, I'm cautious about investing too much time entering data into VW - as I've found that managing that information over time tends to be challenging.
    I think earlier in this thread I referenced fixing our Notes Database.  A simple name change to the title of the database took days to fix.
    With cloud and web information being the clear future for digital information, we've been moving more of our drawing related product data out of VW and online.
    Currently, all of our scheduling (with the exception of Doors and Windows) is now in Airtable. Schedule markers are not live-linked (manually numbered), but the data is so much easier to work with that for us, it's worth it.  Airtable's user interface, database controls, and live linking are considerably superior to VW - so much so, that we are presently working out how to relocate our specifications database there as well.
    I don't know what the perfect solution is - but so far, this is working for us.
    Here's a little excerpt from our lighting library.  As we research and include new products into each project, the range of options grows.  Given that it's a database (rather than a spreadsheet), it's incredibly convenient to adjust display, sorting, field visibility, etc.
    1999490072_ScreenShot2021-02-18at5_49_50PM.thumb.png.2ce2fe79cb9b13d8a0541f5bbbd97bb7.png
    • Like 2
  9. @Christiaan
    I gave it a go.
    Pluses:
    Simple to use and understand - great tutorials
    The grid tools are excellent
    Cons:
    The icons and text are too small for my eyes.
    Importing PDF's is somewhat limited: Via Adobe Creative Cloud or iCloud (for an additional fee)
    Doesn't utilize gestures well - i.e. Undo is a tiny button in the lower corner.  Redo is a tinier button in the lower corner.
    That's as far as I got before I decided that I prefer what I'm using already.
    Some may prefer it over TRACE and ProCreate, etc, but not me.
    • Love 1
  10. @Donald G. Martin
    CONCEPTS was one of the other apps that I liked before I settled on ProCreate.  It has some nice features, but if you favor TRACE, my recommendation is to just stick with it.  I've found that once you find an app that you mostly like - practice generally reveals work-arounds for the problems.
    Case in point - Vectorworks.   Finding my way around software obstacles has definitely enhanced my problem solving skills!
    • Like 2
  11.
    7 hours ago, elepp said:
    Now we are using PDF Expert and Adobe Reader.
    We're also using PDF Expert on our iPads.  It's not really optimized for dimensions (i.e. no dedicated dimension tool), but we use it for in-house redlines, Existing Conditions Drawings - field notes & measurements, etc.
    I had been using Bluebeam, but it was time consuming getting data imported and exported out of the program.  PDF Expert works directly with our files in the Cloud.  The apple pencil works seamlessly, and the user interface works well.
    • Like 1
