BG
    391
Everything posted by BG
  1. We have just started using VW26 Update 2. When re-positioning dimension lines, the text turns a solid black rectangle. Is this a known issue? It doesn't seem to affect workflow, but is annoying. Thanks
  2. Not being able to lock the pitch (from either end of the member) is a real issue.
  3. It would be good if there was an option to make Graphic Legends Black & White only like viewports have.
  4. Hi. I still like using screen plane objects, yet when selecting 'Enable Legacy 2D features', every time I reopen the file, I have to enable this again. This is occuring only since upgrading to VW2025. Is it meant to be this way now? It's annoying if so. Thanks
  5. We have had this happen too. Roof faces randomly disappear. Then reappear usually after restarting VW. Haven't noticed it happening with update 2, so not sure if it has been fixed?
  6. We also have an issue showing hidden line textures (cladding lines) on curved walls, where the textures do not show up.
  7. Since posting this, update 6A became available & whatever the issue was, it seems to have been fixed. What a relief, very thankful 🙂
  8. I'm having issues with a graphic legend window schedule constantly crashing. It seems to have started since VW2024 Rev6. I can't update the schedule otherwise it crashes. I have tested this on a windows machine and it's fine, so seems to be a mac issue. Attached is a small sample file. When defining the legend image, and changing the dimension settings in the annotation settings, causes VW to crash. Is this a known issue? Thanks I'm using VW2024 Rev6 on an iMac Win Sched Test File.vwx
  9. Good to hear that highlighting objects that are behind visible objects is being worked on, as we frequently have this issue.
  10. Hi Joseph Just got the same message again. Here's a link to the project file before the Metadata has been cleared. https://www.dropbox.com/scl/fi/8j6wpt10ahu7x5asjb65v/2311-WD01.02.vwxp?rlkey=m0oesrrd9289t4ccacyc9qxso&dl=0 Thanks Brett
  11. We've just cleared it unfortunately, so will have to wait until it pops up again. Thanks Brett
  12. Hi Joseph This message popped up again yesterday. Did you have a look at the file? What causes this to happen? Thanks Brett
  13. Hi Try this link https://www.dropbox.com/scl/fi/nsrnngec5iyngftq8o5lj/2311-WD01.01.vwxp?rlkey=k8ainefxt7x9oeudj52zxo7o2&dl=0 Thanks Brett
  14. Hi Joseph What is the best way to do that? Thanks Brett
  15. We have just started working on a new project. The file is only about 50mb. We received a message today saying that the metadata is too large. We have only just started, are we going to get this on a regular basis as it's a bit of a pain? Is there anyway to prevent this happening?
  16. BG
    Graphic Legend
    Thanks Julian. What is the release date for update 2? Just want to check if I need to manually re-draw the schedule or wait? Regards.
  17. BG
    Graphic Legend
    Hi After installing VW2024 Update 1, the window schedule I had drawn using a Graphic Legend seems to have an issue. The design layer that the windows are drawn at is not at '0' and has an elevation of 293900. However the graphic legend is now drawing the floor level at '0' and is also dimensioning the windows from '0' and I can't see how to make it show the floor level at the correct elevation? Attached is a PDF of what the legend used to look like plus a VW file that has this issue. Is there anyone that could spare a minute to check if there is a setting I am missing? Note, the windows are 'Windoor' objects. Thanks Graphic Legend Issue.vwx Window Schedule 2023-10-12.pdf
  18. When dragging a structural member that is pitched, the pitch changes. Being able to lock the pitch (or other values too) would be much more user friendly. I will try the tab suggestion, as this sounds good. We gave up using the structural member and went back to the framing member as it is easier to manipulate. Having a 'direction' indicator would also be helpful. Thanks
  19. I agree, this seems like a very simple tool to upgrade.
  20. Hi Does this resolve the issue? test comments.vwx
  21. Hi See attached. Windoor Window Example.vwx
  22. Try setting the offset (3) to the same thickness as the window frame member thickness. This eliminates the offset for us.
  23. Thanks, that is helpful. It is frustrating that a tool is close to being useful, just needs a bit of further development! fingers crossed before retirement, although with the state of the worlds finances, that may not be for some time yet!
  24. Yes, I agree with everything you have said. I can't believe that you can't change the length of a sloping member without it changing the pitch? We had some issues with an IFC coordination with a structural draughting company where the framing members were 'shifting' in the file transfer & we had better results with using the structural member. These were however, horizontal members so were easier to reshape. It is a pain not being able to change the length of multiple structural members in one go.
  25. Hi Did you get an answer on this? I'm using it for roof framing members, but when I change the length of the structural member, the pitch changes & I can't see how to 'fix' the pitch? Thanks
