54 -
Reputation
24 GreatPersonal Information
Occupation
Training Content Specialist
Homepage
https://www.vectorworks.net
Location
United States
Recent Profile Visitors
3,346 profile views
Hi Scott, I've seen this behavior in both Vision and Showcase on my macbook. The first time you see it can be a little confusing, but the good news is it's not an unknown behavior. In my experience this only occurs when there is no sACN stream coming into the macbook, or in the case that the sACN stream has been running prior to Vision being started which causes Vision to not be able to see the steam. In the case of no sACN, once the console starts sending, it should clear everything up. In the case of the sACN stream has been running prior to Vision being started. Shut down the console/show file, restart Vision, load your file, then restart the console. Generally speaking, it's always best practice to have Vision running with the file open prior to started your console. If for some reason you don't have anything that can send sACN and you want to work with the file without all your lights doing weird things. Switch your DMX Provider to Artnet.
TL;DR It sounds silly but in all seriousness, have you tried turning it off and on again? I think you're correct in something else on your computer that is causing this. If for some reason another program didn't shut down properly, or is open in another virtual desktop, it could still be acting as an sACN station without you knowing. It's kind of impossible to say what, without going over every program you've got installed, so turning it off and on again should clear everything out. One important note in case you aren't already aware. Shutting down the computer and turning it back on is different from restarting. When you restart, some of the things in memory are saved to make the startup process faster, which can cause issues. That's why I say turn it off and on again. This is normal. Vision and the DMX Viewer will hold the last DMX received for a predetermined amount of time. I don't remember how long that is at the moment, but it's done to avoid flickering and other issues as some consoles will only send DMX when something is changed. If you restart the DMX Viewer in this situation, it should show zeros. This too is normal. I double checked to be sure and, the only other message that could possibly come up is "Stopping ArtNet Provider". Although the window should be closed before that message is actually triggered. I also tested with MA2onPC with a command wing and Artnet worked for me, but of course different setups do different things.
This looks like there's another sACN source on the network. When I say somewhere on the network, that could be somewhere in the room with you, somewhere in the building, or even larger areas depending on how things are setup. The simplest way to test would be to switch to a different network that isn't attached to the first. Alternatively, if you have a unused router/managed switch, you can connect your computer to it. Nothing else needs to be connected to the router, it is just there to give windows a connection and IP address. There is the possibility that unplugging the computer from the network could work, but it's the least likely. Windows can disable the network interface when nothing is plugged in. If that's not possible, you can also try switching to Artnet. This is a less desirable solution because it's possible for the other source to be transmitting sACN and Artnet simultaneously. If it's not though, it should resolve the issue. As a side note, sACNView is a wild goose chase. It's settings and version of the sACN standard is different from Vision. So, it works sometimes, doesn't others, and there's no way to tell the difference.
Mac OS can be a little weird with network interfaces. If you're on a wired connection, for example an ethernet cable plugged into a dongle that's plugged into a USB port. Shut down Vision and the Nomad software, then disable the wifi, and restart the software. For whatever reason, Mac OS will only show one interface if two are available, and it will always be the wrong one. If you're on wifi, make sure you're connected to something. Any kind of router/AP should work, and it doesn't have to be connected to the internet. When there's no connection, the OS disables all the network interfaces, including the loopback which is how EOS talks to Vision.
I think this is a combination of two things. The VL5 was originally created for version 1 of Vision, and used systems that have since changed to simulated the external dimmer Kevin pointed out. This is why the fixture is always on in Vision. So it will need to be updated in the future to include dimmer control. As a work around, I'd suggest using the VL5 Arc, which has an internal dimmer. The color will probably be different, but the modes and channel assignments are the same. The second part is with how MA deals with these types of fixtures. I don't know much about MA3, but I do know a bit about MA2. From the look of things, they handle external dimmers the same. In your screenshot on the left, you see Patch1 (1.059) and Patch2 (1.060). Assuming it's the same as MA2, Patch 1 is the external dimmer, and Patch 2 is the rest of the fixtures functionality. So it's assuming the dimmer takes 1 channel, and the rest of the functions take another 13, making the footprint 14, even though the actual fixture is only 13. You should be able to set both Patch 1 and 2 to 1.059, which should make things line up correctly. On MA2, it does show an error when I do this, but I ignored it and everything worked as I'd expect. Alternatively, you can use the VL5 Arc profile if it's available.
Xform not able to move Martin Sceptron fixture
Mark Eli replied to mhersland's topic in Previsualization
Unfortunately this is a bug. I'm not totally sure what's causing it at the moment, but I will be submitting a ticket so we can get it fixed. @mherslandI've tried everything I can think of, and I haven't been able to make any geometry disappear. If this keeps happening, please do let us know so we can look into it further. I have found a workaround for working for the fixtures you and @Ben59 mentioned. It may actually be an easier workflow for you. You'll create an empty file with empty layers that have your transforms set. When you open a new or modified file you're working on in vision, you'll merge in the file with the layer transforms by using File>Merge. Then drag and drop the fixtures you want to have dmx xforms into the layers. So you'll still have to assign all 81 xforms to 81 layers, but you should only need to do it once, and then after you can drag and drop. Just in case I'm explaining this poorly, I've made a file as an example. You should be able to merge this file into any other file, then move any fixtures or geometry into the layers and each layer is individually controllable. XFormLayers.vsn -
I'll have to investigate if some fixtures not being transformed is intended behavior or not. I don't think it is, but first I'll have to figure out exactly why it's happening. The recommended workflow is, as @TomWhiteLightsaid, using layers. It's faster and easier to work with all around. Using layers also gives you the ability to nest transforms of all objects or subsets of objects within the parent layer, so it has quite a bit of flexibility. As for objects disappearing, I have not been able to replicate it. It could be something specific to the geometry you're using, or something I'm doing different. I'm not really sure. I have way more questions than answers, if you can share that specific file it would definitely make replicating the issue easier. If you're not comfortable sharing it on the forum, feel free to email us directly tech@vectorworks.net If neither is an option, I have a lot of questions. It looks like you were already sending DMX to the X channel when you entered the Delta X, what happens when you pull that channel to zero? What happens of you change the Delta X to something higher or back to zero? Does changing the Delta Y instead of X have the same or different effect? Did this happen with any other objects, or possibly it happens with all the objects with the same geometry? Does it happen after restarting your computer? In general using layers instead of manipulating individual objects should keep you moving forward in any project you're currently working on. -
This happens with some GDTF files. Basically what's happening is that the light emitter is behind some part of the geometry. There's a couple of ways to fix it. The quickest is to, in Vision, select Root in the Scene Graph. Then in the Properties window, in the Globals section, change Render Shadows from True to False. The good, it's quick and easy. The bad, it turns off shadows for all the geometry in the scene. Another options is again in Vision. Go to Edit>Vision Preferences. Then under the Graphics tab, change Dynamic Shadows from Objects & Fixtures, to Objects. This will turn off shadows for fixtures. Meaning that your geometry will still have shadows, but your fixtures will not. Again, this effects all fixtures, not just the ones you're having issues with. If you're finished with your design and don't think you'll be updating it too much more, you can also fix the individual fixtures. Click the arrow next to the fixture names to expand the tree in the Scene Graph. In this example I'm using the P18MK2PRHC, and I've expanded unit 103. Select the Beam (Mesh) in the Scene Graph, then in the Properties window, change the Visible option from True to False as shown below. You can expand and select the beam mesh of multiple fixtures at the same time by holding the Control key on your keyboard. Then changing the visibility. After you've done this for all the effected fixtures remember to save your file. The beams may not update immediately. So if you change the visibility to false and nothing happens, don't worry. Move the fixtures pan or tilt, which will update the beam, and all should be good. Last, you can try editing the GDTF file to try to fix it. On windows only you can right click the fixture in the Scene Graph, and select Update Fixture Type, which will open a window to edit the fixture file. Unfortunately, I'm not sure what exactly is causing the issue, so I can't tell you what needs to be done to fix it. But, if you have the time and want to try, GDTF gives you that flexibility.
The P18 is not currently in Visions library. However, it is available for download on the https://gdtf-share.com/ website, which can be used in Vision.
Alpha Textures Not Working in Vision 2021
Mark Eli replied to Jesse Cogswell's topic in Previsualization
In Edit>Vision Preferences, make sure your texture quality is set to high. IIRC that is a requirement to use alpha textures, and Visions preferences don't carry over from one version to another. -
Hey Jesse, In the properties window, uncheck the "Use Alpha Channel" box. I'm not sure if it's intended to be that way or not. Either way, setting use alpha to false makes it look correct for me. Let me know how things work out for you. -
@Jesse Cogswell is correct, to use MA-Net2 you'll need a Vision dongle. Artnet and sACN will work with both a dongle or serial number. For MA-Net3, you'll need the MA vis-key. Your distributor or customer service can assist you in switching to a dongle, if you decide you need it.
Yeah, Artnet has always been a bit of a pain to set up. If it's not something you want to deal with, I wouldn't blame you. My thought process is always to try to narrow down possible causes. If Artnet works as expected, at least we know it's specific to sACN. If it doesn't, then we're probably dealing with some outside cause. At least that's the idea. Whether or not it's worth the effort to do that, is entirely up to you. One thing you may try, the DMX Viewer is in the Vision Program folder. It's a standalone application, so you can launch it without starting Vision. That's why it doesn't default to the DMX provider that Vision is set to. The two programs are essentially unaware that the other exists. By starting the viewer without Vision, it should do two things for us. If Vision is somehow causing the issue, Vision isn't running to cause it and the viewer should see the sACN stream. If Windows is blocking the viewer from working because it's being launched by another application, starting the DMX viewer directly should stop that. If it still doesn't work, then the only real possibility is some kind of third party interference, or the MA3. Yes, I agree the idea of the MA having weirdness sounds crazy. It's far from likely, but it is a possibility. MA3 is still very new, and new things love to do unexpected things. I've actually had a similar situation in a personal project several months ago. I was using sACN in a program I was writing, and Vision wasn't seeing the stream and neither was the viewer. I did the exact same thing you did, and fired up sACNView, which saw the stream without issue. Unfortunately, it's been long enough ago I can't remember the exact cause. From what I remember I had set one of the bits high when it should have been low or something similar. Either way it was enough that the DMX Viewer had decided it wasn't an sACN packet and ignored it, but sACNView had no issue. Obviously, the MA engineers do a way better job than I do, when I'm goofing around on the weekends but, anything is possible. One of our guys should have an MA3 now. Hopefully he will be able to either reproduce the issue, or give us a different perspective on things.
Please contact support at tech@vectorworks.net so we can look into this further.
Try running the VisionUpdater in the Vision2021 application folder. Win10(default) C:\Program Files\Vision 2021 Mac Applications>Vision 2021 If that doesn't fix the issue, please contact support so we can provide you further assistance.
