11 -
Reputation
0 NeutralPersonal Information
Location
Italy
I've setup a 2d linear Pio that draws insulation layer, with arc and lines, with a given thickness. It works fine but it fails in junction for angles that differs from 90 degreese. Therefore I wish to know if someone knows a method to crop/hide/mask a Pio geometry likewise to the way we use to crop our Viewports or Bitmap images (without using SDK of course). I've tried to insert in my code a white/colored polygon that hides the backmost geometry, but in joining two PIOs it's unusable. If it not exist I would have to proceed in such a way as to check whether the points of each individual arc or line fall within a given perimeter: a job that is not impossible but extremely more complicated. Thank you in advance for your valuable advice!
During PIO development, it is often required to modify OIP by adding, removing, hiding, enabling, or moving fields (via Plugin Manager -> Edit Configuration…) but what I get in the Object Palette Info, is a lot of mess: there’s not immediate update (for me) of the changes to the correct field sequence without restarting the program. This aspect is quite annoying, so I thought that widgets were an advanced method compared to the "Plug-in Manager " method Now, after your valuable advice, I don’t see the advantage of using them. Noting the immense workflow that Josha has laid out for us, I think I will limit myself to the use of the button widgets (kEventID_OnUIButtonHit = 35) or even custom dialogs.
Hi everyone. I'm developing a PIO trying to insert all the parameters via script avoiding using the parameters window (NOTE: I still don't understand if it's possible, I hope so). Thanks to your the previous posts everything works fine but can someone explain me with which function I should use to get the current value (string or real) of the widget field to assign to my script variable? There seem to be only pop-up menu commands in the "VS:Function Reference" list. Thank you for the tip.
I tried to implement your advice but it was unsuccessful. It seems that only some instructions are executed during the dialogue loop such as:AlrtDialog(), CreateText()+ReDrawAll(). Here is my Dialog_Handler function which I'm working at..... def Dialog_Handler(item, data): (ok, objectName, objectHand, recordHand, wallHand) = GetCustomObjectInfo() def update_and_execute():#===== this subroutine is intended to be used with item==1 and item ==12605 # ========retrieving values====== esito,inter.c1 = GetEditReal(dialogID,12,3) esito,inter.c2 = GetEditReal(dialogID,14,3) (outSelectedIndex, outSelectedChoiceText) =GetSelectedChoiceInfo(dialogID, 16, 0) inter.d = outSelectedChoiceText # ========= updating object info palette=== SetRField(objectHand, GetName(recordHand), 'ci',str(inter.c1/10) ) SetRField(objectHand, GetName(recordHand), 'cf',str(inter.c2/10)) SetRField(objectHand, GetName(recordHand), 'diam', inter.d) ResetObject(objectHand) if item == 12255:# SetupDialogC -> My Custom Window Init AddChoice(dialogID, 16, '8', 0) AddChoice(dialogID, 16, '10', 1) AddChoice(dialogID, 16, '12', 2) if v3 =="8": choice = 0 elif v3 =="10": choice = 1 elif v3 =="12": choice = 2 SelectChoice(dialogID, 16, choice, False)#=====update pulldown menu -> OK! elif item == 2:#=====Cancel button pressed -> OK! pass elif item ==1: #==== OK button pressed -> OK! update_and_execute() elif item == 12605 :# ======Preview button pressed -> AlrtDialog(('item= '+ str(item) + ' data= '+ str(data)))#===== THIS WORKS update_and_execute()#=====THIS DOESN'T REGENERATE PIO AS item==1 DOES ! ResetObject(objectHand)#=====THIS DOESN'T WORK TOO ! CreateText(str(item))#==== THIS WORKS WITH ReDrawAll() ! ReDrawAll()
- 2 replies
- pio
- custom dialog
(and 2 more)
Tagged with:
I've got an event-enabled linear PIO that raise a custom dialog with a double click on it. It works fine swapping values between custom dialog and info object palette. I've implemented dialog handle procedure with item 1 (OK Button), item 2 (CancelButton). Now I would like to add item 12605 (preview button) which would operate as the Ok button (updating PIO ), but without exit from dialog. It doesn't work at all because seems that you must exit from the dialog event loop to obtain PIO updating. Thanks in advance for any suggestion.
- 2 replies
- pio
- custom dialog
(and 2 more)
Tagged with:
Why import vs number = "123" vs.Message("Type=", type (number) ) returns : "Types =" instead of "Types =int" ? Thanks
In my Plug-in manager it is seen as a Text file but, I suppose, that is a 2D Path Object. Could you post the parameter list ? Thanks for your sharing...... AB.
Which parameter of Page/Printer setup are you focus on ? Number o pages, printable area ?
This is my answer. I create a new command called "Join Linear PIOs", placed under "Edit" menù and this is its code: Procedure JoinTwoSelectedLinearPios; VAR h1,h2:HANDLE; P1,P2,P3,P4:POINT; P:POINT; parallel :BOOLEAN; intOnLines :BOOLEAN; d1,d2,d3,d4:REAL; BEGIN h1:=FSActLayer; h2:=NextSObj(h1); GetSegPt1(h1,P1.x,P1.y); GetSegPt2(h1,P2.x,P2.y); GetSegPt1(h2,P3.x,P3.y); GetSegPt2(h2,P4.x,P4.y); LineLineIntersection(P1,P2,P3,P4,parallel,intOnlines,P); {====gather P1,P2,P3,P4 distances from P========} IF (parallel=FALSE) THEN BEGIN d1:=Distance(P1.x,P1.y,P.x,P.y); d2:=Distance(P2.x,P2.y,P.x,P.y); d3:=Distance(P3.x,P3.y,P.x,P.y); d4:=Distance(P4.x,P4.y,P.x,P.y); { ===== join PIOs trimming the shortest side...=====} IF d1<d2 THEN SetSegPt1(h1,P.x,p.y) ELSE SetSegPt2(h1,P.x,p.y); IF d3<d4 THEN SetSegPt1(h2,P.x,p.y) ELSE SetSegPt2(h2,P.x,p.y); END; END; RUN(JoinTwoSelectedLinearPios); Well, it doesn't check if h1 and h2 are linear PIO's or other objects, but it works with 2d Lines too. Hope to be useful....
alberto72 changed their profile photo
Hi everybody! Who does know the way to make a linear PIO responsive to Join command ? Thanks.
