FendrickDesign
    6
Everything posted by FendrickDesign
  1. It's good to know it's working. But why does everything disappear when I make the site model? Rendering mode is OpenGL. But I don't see anything other than the building either in 2D or Orthogonal. All layers and classes are on.
  2. I'm new to this, so don't know what I'm doing wrong. I made my 2D contours 3D with the z elevations. Then I tried to make a Site model, but don't see anything! I don't have a 3D option in the top right - just 2D or orthogonal. What am I missing?
  3. This has driven me crazy so many times, and I always forget how to fix it, but this is what's typically awry for me: in the Organization dialogue box, under the References tab, there's a Settings button; on the lowest setting (Use this method to reference Vectorworks files) the FIRST circle (Design layer viewports) needs to be chosen. Hope this helps, if this was still a problem, or if anyone new is coming to this thread like I was today!
  4. Just did the latest update and I think it's fixed!
  5. Ever since switching to 2017 our office has been having some trouble with dimensions. After the initial three clicks (first point, second point, offset) we can't select the offset to drag it. We can select the dimension only by the sides. We've found switching from 2D Plan to Orthogonal sometimes lets us grab and pull, but that's not a great permanent solution. We've also noticed that it doesn't happen in every document, and sometimes within the same document this is the case on some layers but not others. So far we haven't identified anything in common between the files/layers where dragging dimensions works and where it doesn't. Any idea what's going on here?
