CETLV
95 -
Calendar
Everything posted by CETLV
Braceworks Cross Section info From Manufacturers
CETLV replied to Wesley Burrows's topic in Braceworks
Has there been any updates on this? I am still searching for accurate cross section info. on a multitude of manufacturers. -
I have to say, SP2 really helped a lot of the bugs out. However I am curious about the hoist chain cross section only having a fibercore option set available and not typical chain used with hoists? My rigging numbers were off significantly because most of the truss symbols do not have cross sections added to them as of yet, and by default are Rigid, (which can really mess you up if you dont pay attention) Does a Rigid chain cross section do the same?
Fantastic response to this question, thank you all!
Oh thanks! Much appreciated!
Hey thanks for responding. I do know about the border tools. Thats what I do now, but I was hoping to see a top finish style that is more of a bunting style that has a sewn in tie back. Its not that its a huge thing, I was just wondering if anyone had a better method. More or less just me being lazy and wanting a "skirt the stage button" :-)
Anyone have a good workflow for easy stage skirting? I would think that perhaps they would have just a "skirt stage" button on the creation tool. I just get annoyed with having to alter the heights, set the top finishes, and mess with all the pleat settings for a lot of custom stages. If its a square its easy enough, but its still sort of a pain. Anyone have any good tips?
Fantastic! Good to hear. Thanks for the update!
Does anyone know if its possible to say drop a 6 way corner block into an already existing run of truss without breaking connections?
Good day, I played around with this for a while and didnt see how to do it. When using the insert truss tool in braceworks, is there a quick way to scroll through different truss types and keep the command active to connect a new piece? I keep finding myself having to go to the truss symbol menu at the top of the window, and manually selecting a new truss piece from the library. I seem to remember seeing this shortcut in the video that introduced it, but I cannot find it. Thanks all!
hey I was wondering if anyone had any input on files that are done of stage lines... I need to put up a mobile stage and just did not feel like building it from scratch. I have already submitted requests to stage line, and I guess I dont speak enough french.
Thanks!! ill figure it out!
I am also having an issue. I installed the demo version, and I dont have any of the "Vision" menus in VWX, so basically I cannot figure out how to export the vision files... I know how to edit the data, but cannot export the file.
Thank you for your help, however without the vision menu how can you export the vision file?
- 4 replies
- vectorworks
- 2017
(and 1 more)
Tagged with:
Hey, I am running VWX 2017 designer and have just installed vision 2017 demo. I cannot get the "Vision" menu to show up in VWX at all in order to compile my vision file. Does anyone know what I may be doing wrong? Thanks in advance. B
- 4 replies
- vectorworks
- 2017
(and 1 more)
Tagged with:
Well, honestly I do not know what happened whatsoever... I just got a new system, so when I reinstalled I forgot to up my undo amount, so I could not undo back past it... However, all was not lost, the wall shape was still very much in tact, and it was obviously the outer walls of the structure, so all I had to do was simply redraw a new wall around the perimeter and done, but it was just such a strange occurrence. The actual roof segment you are correct is not a roof symbol, but an extrude which in my case works for me since I simply need flat with steel beams. I still cannot figure out how the round wall had mirror properties however, the problem literally fixed itself and I have not been able to re create it since. Thanks all!
This Problem has basically fixed itself... so I am thinking it was a software Quirk.... HOWEVER, I have a new problem with this.... I drew an extruded polygon over the exterior walls, and went to create a roof, but noticed that I didnt have a flat roof option, so I was just going to go with an extruded polygon simply with black paint. However somehow all the outer walls became a roof, and the walls all dissappeared... any ideas how to get that back?
yessir.... like I said, textures and visibility for the object seem right to me... but I am obviously doing something stupid wrong..
Good day, Thanks for checking into it. All the textures are in place, and the mirror effect changes based on the applied texture (i.e. I applied a gold brushed mesh texture and the mirror took on a slightly greenish yellowish tint) I tried class textures, and direct textures, as well as none... The hard part is the bricks and wooden panels are .01" extrusions to I can get my details in there in different classes.. Also I have deleted the wall, re rendered, and the mirror is still in place... im even more confused now... that wall was a pain to create in the first place because of the very long, shallow curvature of it. Here is a SS of the deleted wall.
Hey Hey... I have what may be a simple question.. I have a round wall that looks very good in GL and all artistic renders, however when I give it a fast or final quality RW it comes up as straight, and reflects like a mirror.... Here is some SS...
