Hi!
A very simple trick.
Draw a rectangle, just one, with simple measure...
400x300 for example
then
menu file -> export script
Now you have the vs script for create a rectangle.
Here is it:
Procedure LoadFile;
VAR
hatchName, gradientName, tileName, materialName, objectName:STRING;
result, index, segmentIndex:INTEGER;
colorIndex:LONGINT;
boolResult:BOOLEAN;
top, left, bottom, right:REAL;
tileRepPoint, tileOffPoint:POINT;
tempHandle, tempHandle1, tempHandle2, tempHandle3, tempHandle4, tempHandle5, tempHandle6, gradientHandle, objectHandle, layerHandle, classHandle, viewportHandle, tileHandle, tileGroupHandle, materialHandle, textHandle:HANDLE;
dynCharArray, tempDescriptionText:DYNARRAY [] OF CHAR;
BEGIN
{VectorWorks Version 26.0.5(6227681)}
{Global Characteristics}
DrwSize(1,1);
SetUnits(0,1,0,2.54,'cm','cmq');
PrimaryUnits(0,1,1,2,6,TRUE,FALSE);
SecondaryUnits(1,3,1,TRUE,TRUE);
SetPrefLongInt(162,1);
SetPrefLongInt(169,1);
SetPrefLongInt(171,3);
SetPrefLongInt(172,3);
SetPrefLongInt(212,3);
SetPrefLongInt(219,3);
SetPrefLongInt(221,3);
SetPrefLongInt(222,3);
SetPrefInt(174,0);
SetPrefInt(224,0);
SetPref(167,FALSE);
SetPref(173,TRUE);
SetPref(223,FALSE);
SetPref(175,FALSE);
SetPref(225,TRUE);
GridLines(1);
PenGrid(0.1);
SetPrefReal(73,0);
SetOriginAbsolute(0,0);
SetPref(37,TRUE);
SetPref(38,TRUE);
SetPref(5,FALSE);
OpenPoly;
SetPrefInt(121,0);
SetPrefReal(68,0);
SetPrefReal(69,0);
SetPrefReal(70,1);
{End of Global Characteristics}
SetDocDrpShadowData(FALSE,0,0.01,0.005,#315.0000000000d,75,0,0,0);
{Record Format Entries}
{Begin Visible Record Format Entries}
{End of Visible Record Format Entries}
{Begin Hidden Record Format Entries}
NewField('NNA__MassAndForceUnits','Mass Unit','2',1,0);
SetObjectVariableBoolean(GetObject('NNA__MassAndForceUnits'),900,FALSE);
NewField('NNA__MassAndForceUnits','Mass Precision','2',1,0);
NewField('NNA__MassAndForceUnits','Show Mass Mark','True',2,0);
NewField('NNA__MassAndForceUnits','Custom Mass Unit Name','Kilogrammi',4,0);
NewField('NNA__MassAndForceUnits','Custom Mass Unit Mark','kg',4,0);
NewField('NNA__MassAndForceUnits','Custom Mass Unit Scale','1000',3,0);
NewField('NNA__MassAndForceUnits','Custom Mass Unit Link','2',1,0);
NewField('NNA__MassAndForceUnits','Custom Mass Unit Type','-1',1,0);
NewField('NNA__MassAndForceUnits','Mass Distr Unit','1',1,0);
NewField('NNA__MassAndForceUnits','Mass Distr Precision','2',1,0);
NewField('NNA__MassAndForceUnits','Show Mass Distr Mark','True',2,0);
NewField('NNA__MassAndForceUnits','Custom MassDistr Unit Name','',4,0);
NewField('NNA__MassAndForceUnits','Custom MassDistr Unit Mark','kg/m',4,0);
NewField('NNA__MassAndForceUnits','Custom MassDistr Unit Scale','1',3,0);
NewField('NNA__MassAndForceUnits','Custom MassDistr Mass Unit','2',1,0);
NewField('NNA__MassAndForceUnits','Custom MassDistr Lenght Unit','9',1,0);
NewField('NNA__MassAndForceUnits','Force Unit','1',1,0);
NewField('NNA__MassAndForceUnits','Force Precision','2',1,0);
NewField('NNA__MassAndForceUnits','Show Force Mark','True',2,0);
NewField('NNA__MassAndForceUnits','Custom Force Unit Name','Kilonewton',4,0);
NewField('NNA__MassAndForceUnits','Custom Force Unit Mark','kN',4,0);
NewField('NNA__MassAndForceUnits','Custom Force Unit Scale','1000',3,0);
NewField('NNA__MassAndForceUnits','Custom Force Unit Link','1',1,0);
NewField('NNA__MassAndForceUnits','Custom Force Unit Type','-1',1,0);
NewField('Setup Record_10','Version','26.0.1',4,0);
SetObjectVariableBoolean(GetObject('Setup Record_10'),900,FALSE);
NewField('Setup Record_10','Active Class Std','1-VWArch',4,0);
NewField('Setup Record_10','Active Layer Std','1-VWArch',4,2);
NewField('Setup Record_10','Active Sheet Std','1-VWArch',4,0);
NewField('Setup Record_10','Num Basements','1',1,0);
NewField('Setup Record_10','Num Floors','2',1,0);
NewField('Setup Record_10','Use Zero','False',2,2);
NewField('Setup Record_10','Basement Prefix','B',4,0);
NewField('Setup Record_10','Floor Plan Scale','50.000000',3,6);
NewField('Setup Record_10','Site Plan Scale','200.000000',3,6);
NewField('Setup Record_10','Aux View Scale','50.000000',3,6);
NewField('Setup Record_10','Note Sheet Scale','1.000000',3,6);
NewField('Setup Record_10','Units','Centimetri',4,0);
NewField('Setup Record_10','Border Type','',4,0);
NewField('Setup Record_10','Title Block Type','',4,0);
NewField('Setup Record_10','Use Title Block Border','False',2,2);
NewField('Setup Record_10','Title Block Width','0,000000',4,0);
NewField('Setup Record_10','Title Block Height','0,000000',4,0);
NewField('Setup Record_10','Border Option','1',4,0);
NewField('Setup Record_10','First Time-Setup','False',2,2);
NewField('Setup Record_10','First Time-Model','True',2,2);
NewField('Setup Record_10','First Time-Layers','True',2,2);
NewField('Setup Record_10','First Time-Sheets','True',2,2);
NewField('Setup Record_10','Default Floor Height','106.299213',3,6);
NewField('Setup Record_10','Default Slab Thk','11.811024',3,6);
NewField('Setup Record_10','Default Bsmt Hgt','106.299213',3,6);
NewField('Setup Record_10','Default Fdn Thk','3.937080',3,6);
NewField('Setup Record_10','Default Ceiling Hgt','96.062992',3,6);
NewField('Setup Record_10','Has Roof','True',2,2);
NewField('Setup Record_10','Has Foundation','True',2,2);
NewField('Setup Record_10','Create Slab Layers','True',2,2);
NewField('Setup Record_10','Use Auto-classing','False',2,2);
{End of Hidden Record Format Entries}
{End of Record Format Entries}
{LineType Definition Entries}
{End of LineTypeDefinition Entries}
{Worksheet Entries}
{End of Worksheet Entries}
{Gradient Definition Entries}
{End of GradientDefinition Entries}
{Tile Definition Entries}
{End of TileDefinition Entries}
{LayerLevelType Entries}
tempHandle := GetObject('Piano');
IF tempHandle = nil THEN
boolResult := CreateLayerLevelType('Piano');
tempHandle := GetObject('Pavimentazione grezza');
boolResult := CreateLayerLevelType('Pavimentazione grezza');
tempHandle := GetObject('Ambiente');
boolResult := CreateLayerLevelType('Ambiente');
tempHandle := GetObject('Solaio');
boolResult := CreateLayerLevelType('Solaio');
tempHandle := GetObject('Tetto');
boolResult := CreateLayerLevelType('Tetto');
tempHandle := GetObject('Fondazione');
boolResult := CreateLayerLevelType('Fondazione');
tempHandle := GetObject('Piano di calpestio');
boolResult := CreateLayerLevelType('Piano di calpestio');
tempHandle := GetObject('Pavimento');
boolResult := CreateLayerLevelType('Pavimento');
tempHandle := GetObject('Finitura pavimento');
boolResult := CreateLayerLevelType('Finitura pavimento');
tempHandle := GetObject('Controsoffitto');
boolResult := CreateLayerLevelType('Controsoffitto');
{End of LayerLevelType Entries}
{Story Entries}
{End of Story Entries}
{Hatch Definition Entries}
{End of Hatch Definition Entries}
{-- Begin Simple Material Entries --}
{-- End Simple Material Entries --}
{-- Begin Compound Material Entries --}
{-- End Compound Material Entries --}
{Symbol Library Entries}
{End of Symbol Library Entries}
{Layer Characteristics}
layerHandle := CreateLayer('Lucido design-1', 1);
SetScale(50);
ShowLayer;
CopyMode(8);
LFillFore(0,0,0);
LFillBack(65535,65535,65535);
LPenFore(0,0,0);
LPenBack(65535,65535,65535);
Projection(6,0,1239.519999999999754,-13.809133333333332,13.809133333333332,13.809133333333332,-13.809133333333332);
{End of Layer Characteristics}
{Object Creation Code}
NameClass('Nessuna');
PenSize(2);
PenPatN(2);
FillPat(1);
PenFore(0,0,0);
FillFore(0,0,0);
RectangleN(-214,-147,0.1,0,400,300);
objectHandle := LNewObj;
SetDropShadowData(objectHandle, 0,0.01,0.005,#315.0000000000d,75,0,0,0);
EnableDropShadow(objectHandle, FALSE);
SetObjectVariableBoolean(objectHandle, 1160, FALSE);
SetZVals(0,0);
OpacityN(100,100);
{End of Creation Code}
{Classes}
SetClFillFore('Nessuna',0,0,0);
SetClFillBack('Nessuna',65535,65535,65535);
SetClPenFore('Nessuna',0,0,0);
SetClPenBack('Nessuna',65535,65535,65535);
boolResult := SetClassBeginningMarker('Nessuna',0,15,0.125,0,34,0.05);
boolResult := SetClassEndMarker('Nessuna',0,15,0.125,0,34,0.05);
SetClFPat('Nessuna',1);
SetClLSN('Nessuna',2);
SetClLW('Nessuna',2);
SetCLDrpShadowData('Nessuna',0,0.01,0.005,#315.0000000000d,75,0,0,0);
EnableCLDropShadow('Nessuna',FALSE);
SetClUseGraphic('Nessuna',FALSE);
classHandle := GetObject('Nessuna');
NameClass('Quote');
SetClFillFore('Quote',0,0,0);
SetClFillBack('Quote',65535,65535,65535);
SetClPenFore('Quote',0,0,0);
SetClPenBack('Quote',65535,65535,65535);
boolResult := SetClassBeginningMarker('Quote',0,15,0.125,0,34,0.05);
boolResult := SetClassEndMarker('Quote',0,15,0.125,0,34,0.05);
SetClFPat('Quote',1);
SetClLSN('Quote',2);
SetClLW('Quote',2);
SetCLDrpShadowData('Quote',0,0.01,0.005,#315.0000000000d,75,0,0,0);
EnableCLDropShadow('Quote',FALSE);
SetClUseGraphic('Quote',FALSE);
classHandle := GetObject('Quote');
{End of Class Entries}
{Default Attributes}
PenSize(2);
PenPatN(2);
FillPat(1);
boolResult := SetDefaultBeginningMarker(0,15,0.125,0,34,0.05,FALSE);
boolResult := SetDefaultEndMarker(0,15,0.125,0,34,0.05,FALSE);
PenFore(0,0,0);
FillFore(0,0,0);
SetDocDrpShadwByCls(True);
{End of Default Attributes}
END;
Run(LoadFile);
But it has a lot of setting you don't need at the moment. It could simplified as below:
Procedure LoadFile;
VAR
BEGIN
DrwSize(1,1);
NameClass('None');
END;
Run(LoadFile);
Pay attention that the
Procedure " LOAD FILE " at the very top must to match to the
RUN(LOAD FILE);
That's all to start!
Have fun
L.
