Content Count
22 -
Community Reputation
5 NeutralAbout lucioing
Rank
Greenhorn
Personal Information
Occupation
civil engineer
Homepage
www.archinglabs,com
Hobbies
music, photo
Location
Rome
Recent Profile Visitors
Hi! It could be useful selecting all object of a class, by right clicking over the class pane as Rhino do. Thank you L.
- 1 reply
- 3
Hello to everyone! I'm in trouble with RHINO exporting. It seems to be impossible export by class or layer. Whatever you do, you get a single layer (in Rhino) that contains the whole project... As you can easily understand, it's not workable as it is. There is someone could help in this issue? Thank you L.
- 1 reply
- 1
Here we are! Just wrote two 'tool', one for start timer, to stop it the second. When you start a new drawing/project, click on 'start' button tool (yes, you have to create a palette or add them to an existing one) and star to work. When you stop your job, click on stop button and 'mark' the timer. Of course, you can do it every time you are working to the file... I know it is far to be perfect, but it is just a begin. Hope you like it. Thanks to Pat, I want to share my little job so, any comment is welcome! thank you again, Pat and JBenghiat L. MyFileLOG_Start.txt MyFileLOG_Stop.txt
Thank you, Pat! Great !!! L.
Thank you, for your precious reply. I'll try that way! L. 😉
I need a file log. Until someone will add this feature, I want to try to write my own file log. I mean a text file relate to the WORK file, not in general, as VW is use to write since the mincad release. But I have no idea how to start. The technical (I mean code) in not the problem at the moment. I have, first, to understand the problem, starting with a simple code: I'm thinking to write two tool script LogIN and LogOut, but I never wrote a simple txt file until now (in VScript, I mean)... Another step could be an automatic script, that run each time I open the file project... I have also tried to set a worksheet... but it doesn't works. So, as you can easily understand, I have few ideas but... confused" 😋 Thank you L.
Thank you Josh! I've just try this and it does works. L. PROCEDURE Prova_Porta_01; CONST {capitalized to distinguish them from variables} LOCAL_GREETING_ENGLISH = 'Hello '; LOCAL_GREETING_FRENCH = 'Bonjour '; VAR s:STRING; i:INTEGER; sp:REAL; base:REAL; altezza:REAL; SectObjectHandle:Handle; PathObjectHandle:Handle; FrameObjectHandle:Handle; PROCEDURE DrawSection(s: REAL); BEGIN ClosePoly; Poly( 0,0, 0,3, 3,3, 3,s, { coordinate assolute } -6,s, -6,0 ); SectObjectHandle:=LNewObj; END; PROCEDURE DrawPath(b: REAL; h:REAL); BEGIN {Relative;} OpenPoly; BeginPoly3D; Add3DPt(3,3,0); Add3DPt(3,3,h); Add3DPt(3+b,3,h); Add3DPt(3+b,3,0); EndPoly3D; PathObjectHandle:=LNewObj; END; PROCEDURE MakeFrame(h1, h2: HANDLE); BEGIN FrameObjectHandle := CreateCustomObjectPath('Extrude Along Path', h1, h2); <<<-------------------- END; BEGIN sp:=Ps; base:=Pb; altezza:=Ph; DrawSection(sp); DrawPath(base, altezza); MakeFrame(PathObjectHandle, SectObjectHandle); END; Run(Prova_Porta_01);
Maybe, something's wrong. Of course the objects created (path & sect) works fine using them in main window... The handles works fine... Thank you L. Here's the simple code: PROCEDURE Prova_Porta_01; CONST {capitalized to distinguish them from variables} VAR s:STRING; i:INTEGER; sp:REAL; base:REAL; altezza:REAL; SectObjectHandle:Handle; PathObjectHandle:Handle; FrameObjectHandle:Handle; PROCEDURE DrawSection(s: REAL); BEGIN ClosePoly; Poly( 0,0, 0,3, 3,3, 3,s, { coordinate assolute } -6,s, -6,0 ); SectObjectHandle:=LNewObj; END; PROCEDURE DrawPath(b: REAL; h:REAL); BEGIN {Relative;} OpenPoly; BeginPoly3D; Add3DPt(3,3,0); Add3DPt(3,3,h); Add3DPt(3+b,3,h); Add3DPt(3+b,3,0); EndPoly3D; PathObjectHandle:=LNewObj; END; PROCEDURE MakeFrame(h1, h2: HANDLE); BEGIN FrameObjectHandle:=CreateExtrudeAlongPath(h1,h2); END; BEGIN sp:=Ps; base:=Pb; altezza:=Ph; DrawSection(sp); DrawPath(base, altezza); MakeFrame(PathObjectHandle, SectObjectHandle); {FrameObjectHandle:=ExtrudeAlongPath(PathObjectHandle, SectObjectHandle); } it doesn't works too {Move3DObj(SectObjectHandle, 50,0,0); moving does works fine, so it's mean that the handle works Move3DObj(PathObjectHandle, 50,0,50);} END; Run(Prova_Porta_01);
Great Alan!!! It does works! Thank you so much! L. PS I just checked the column 'Core' over the component 'PlatformFrame'...
Hi Alan... Thank you for your quick reply! What does '..set your core wall location...' mean? Anyway, I'll looking for 'core location'... Thank you again L.
Hello! I'm in trouble with wall style and wall framer. I did set a style of my wall (ParetePlatformFrame) and I'm unable to match the interior component (PlatformFrame) to a frame generated by Wall framer. The control offset is ok... It seems that the Wall framer start to the middle axes instead of the control line, as shown by the dashed red line... You could try by yourself, deleting my wall and drawing a new. Is there a way to do that? Here's the file... Thank you L. PS Of course, I could set a Wall, with a proper offset, just for structure, but it's not what I do expect in 2017... :-)) PlatformFrame.vwx
Here's the code. Thank you again! L. Procedure MyRect; Var a:real; objectName : STRING; objectHand, recordHand, wallHand : HANDLE; b: BOOLEAN; Begin NameClass('MyClass'); Rect(0,0,100,100); b:=GetCustomObjectInfo(objectName,objectHand, recordHand, wallHand); SetClass(objectHand, 'MyObj'); End; Run (MyRect);
- 14 replies
Great jbenghiat! I never though to this! Thank you so much! L.
- 14 replies
I've tryied an old plugin I wrote some years ago... If I define it as 'Point tool', it doesn't works. I've also export an object created straight in VW (2017) and it is the same! Please, let me know about... L. MyHandMadeRect_01.zip
- 14 replies
Ok, got it! It depends on the 'type' of plugin. Here's a picture. It seems that 'point obj' doesn't works correctly, as shown... L.
- 14 replies
