spdygnzls
6 -
Reputation
0 NeutralPersonal Information
Occupation
Architect - G7A | Gonzales Architects
Homepage
www.g7arch.com
Location
United States
Recent Profile Visitors
400 profile views
Exterior walls in hidden line not rendering elevations
spdygnzls posted a question in Troubleshooting
Only one shared file is affected in exterior walls not rendering in hidden line (see attached elevation render). However, when you go to the plan and select a wall with a window and provide a solid fill (to the window), that portion of the exterior elevation or 3D model then shows the exterior wall. All other walls (without windows or doors) have a solid fill but won't render. Not sure how to fix this one file and hoping to get forum's help. We noticed this occurred only after updating to latest VWA 2022 SP2 (Mac, running Big Sur) recently. Thanks in advance! -
Just click on the update button and quit vectorworks (two separate apps running). Once updated, it will begin the process of installing the SP1.
Copying, pasting or moving viewports creates a PDF
spdygnzls replied to spdygnzls's topic in Architecture
Hey zoomer, thanks for that. Yes, duplications preference is set correctly to not offset (unchecked). It's just that the command-option-V doesn't take the copied item and pastes it back in the exact same location for some reason, so I think that it is a bug caused by High Sierra perhaps. It works just fine on our other Mac where VWA 2018 has been installed but their Mac OS remains Sierra. -
Sorry I didn't get back with you sooner, Benson, but that was a genius workaround and am chagrined I didn't think of it. The VWA 2018 has some great new features, but with High Sierra, the typical little hiccups that I'm sure will smooth out with updates and service packs to follow. Another one I found was the "paste in place" command not working as normal. It pastes it somewhere off in space. Minor inconvenience and I've been able to work around as well. Thank you again for the quick response to my tardiness. -
THANK YOUI SO MUCH! -
Hi all, just a quick helping hand being requested as I've deployed VWA 2018 onto our computers, but my own workstation is the only one upgraded to High Sierra on the Mac. The problem is when I copy a viewport from one sheet to another in the same file, it becomes a PDF! As such, I can no longer edit it as normal. Is this a bug, or did I mess up a setting that I can change back to stop this behavior? Thanks in advance for any guidance!
