BrandonSPP
Vectorworks, Inc Employee-
Content Count
223 -
Link VW Render Cameras with Vision cameras
BrandonSPP replied to Gaspar Potocnik's question in Wishlist - Feature and Content Requests
@Gaspar Potocnik It's something we are looking into but will require a lot of background work on the current Renderworks camrea. -
You can build it out in Vectorworks or you might be able to download one for 3D warehouse. You can open 3Ds files into Vision. Currently Vision does not have this tool
That is a bug I will let the engineers know, thank you for reporting it.
I am not sure I understand you completely but is this what you are trying to do? Insert connection.mov
LMorga started following BrandonSPP
Try doing a library refresh, it can be found under the settings drop-down.
@creatrix this may help
VClaiborne started following BrandonSPP
Two more spots than I would need to see your file and settings... Number 1 check the render tab... Number 2 the 3D options on the Stage deck
This look to be in wireframe render, check your settings in Vectowks preferences.
Thanks, @C. Andrew Dunning a bug has been submitted
@DCapp Could you send me the file so we can take a look at it?
You can also use "Replace Lighting Device..." on the OIP
Good to know you are up and running
The line of the cable will take the class attributes they are placed on. So for feeder cable, you can make a class called "Feeder" or whatever you want to call it, set that class to the color code you need. Now place/draw your cables in that class. I made a quick Video with a "Cable" class that has a green pen. Hope it helps! Cable.mov
This looks to be a bug, it's taking the center line of the truss at the load. I will submit it now, thanks!
Looks Great!
