KristjanT
  • Content Count
    3
Everything posted by KristjanT
  1. KristjanT
    IFC import
    I have an issue with IFC import not showing up. Vectorworks says that the IFC import is successful and all the Classes and Layers are imported but phisical model it self is not present. If I press ctrl+A (select all) then Object info palet displays "no selection" in other words there is nothing to be selected. Has anyone else had similar issue? Any tips? The IFC is exported from AutoCAD Civil 3D. Thanks!
  2. Hi. Not sure if this goes into this forum category but I have a problem with colour mapping on IFC export. Inside the Vectorworks program all the vegetation is coloured green, paving is gray, site model green, and so on. All fills are by Class. All the objects have IFC classifications... After the model is exported all the colours get messed up. As you can see from the screenshot all the vegetation is purple, all the paving (IfcSlab) objects are mostly blue, one Slab object with pink outline is gray, IfcBeam objects are pale pink... I am still new in the ifc and bim world so I might have overlooked something. Is this something that is as it is or is it possible to display the model with original colours? On the screenshot I am using Tekla BIMsight but similar problem presist on Solibri as well. The program is Vectorworks Landmark 2020 SP2. Any help is appreciated.
  3. Hi. I am still new in IFC stuff but I have a problem with colour mapping on IFC export. Inside the Vectorworks program all the vegetation is coloured green, paving is gray, site model green, and so on. All fills are by Class. All the objects have IFC classifications... After the model is exported all the colours get messed up. As you can see from the screenshot all the vegetation is purple, all the paving (IfcSlab) objects are mostly blue, one Slab object with pink outline is gray, IfcBeam objects are pale pink... Is this something that is as it is or is it possible to display the model with original colours? On the screenshot I am using Tekla BIMsight but similar problem presist on Solibri as well. The program is Vectorworks Landmark 2020 SP2.
