jtbrooks
    7
Everything posted by jtbrooks
  1. Awesome! Worked immediately. Thank you so much for your help!
  2. Hello, I have created a wall using the wall tool and want to render it using a rendtrworks texture that I have created. Only the top, right and left sides of the wall are accepting the texture, not the front. In the object info pallet, the part selected is overall and the texture is selected. The wall has a solid fill. I have tried giving it no fill, have adjusted the modes and parts to accept the texture. I am not sure what to do to make the front/visible part of the wall accept the texture. I have attached a screen shot to show what I am experiencing. Any and all help is appreciated. Thank you!
  3. Yes, I have copied and pasted the soft goods into the attached file. Thank you! Soft Goods.vwx
  4. Hello, I have used the Soft Goods tool to make curtains. I want to change the color of the curtains from standard black to a pearlescent fabric texture that I have created as new Rendtrworks texture. No matter what I do, the curtains will not take the texture and remain black. I have tried everything I can think of in the OIP, Attributes and Class. What should I do? Thanks!
  5. Thank you very much for your help! I was able to create what I needed.
  6. Hello, I am trying to create a 3D parking lot site in Vectorworks Spotlight. All four corners of this parking lot are at different heights. I have tried extruding a rectangle and reshaping, but I can only reshape 2 of the four corners. I have also tried using the slab and grade tool, but I am unable to create what I am wanting. I need to create a parking lot that is exact to the image attached. Any suggestions/something I am not doing correctly? Thank you!
