fpaniz
  • Content Count
    9
Community Reputation
0 Neutral
About fpaniz
  • Rank
    Greenhorn
Personal Information
  • Location
    Spain
Recent Profile Visitors
290 profile views
  1. @CarolAdoras Hi Carol, I just sent you an email with CV and portfolio, hope to hear from you soon. 🙂
  2. Mmmm so that’s seems to be a VW2017 bug, strange that nobody has reported it, definitely I’ll need to upgrade! thanks Pat!
  3. Thanks for the rounding tip. In VW2019 works even when you rotate the model in 3D view and recalculate the worksheet?
  4. Thanks @Marissa Farrell and @Pat Stanford, I'm using VW2017 version, I previously used frames members plugin to model the parts, but that does not make sense if you need to reshape objects in real time. It is faster and better to work with 3D modeling tools such as push and pull, taper face, etc., and automatically this makes these objects became "generic solid" and that's fine. The problem begins when I need the values shown in the OIP to appear correctly on the worksheet. it seems impossible to obtain correct values if the object was not created with a parametric plugin such as walls, slabs, framing members, etc. instead, with generic solids and extrudes it has to be in top plan only. I attach images and the file Thanks again! Prueba DIM.vwx
  5. Hi @Pat Stanford Pat, I have more or less the same problem. I'm working on a furniture project and I need to get the dimensions and areas on the worksheet to buy the materials. I'm working with generic solids, and I see on the OIP that the basic dimensions are there, but, when I try to place it on the worksheet, the normal formula =lenght, =width, retrieve wrong information... I just want to know if there's a way (or a formula like framing members plug in =('FramingMember'.'width')) to place this information from the generic solid OIP to the worksheet. I think its very simple and very necessary! Thanks!
  6. Hi, I wonder if anyone knows who are the best way to get the height from a solid. I'm working on a single house in a sloped terrain, their wooden posts have different heights but with a standard notched end. The Issue begins when I try to get the heights from those "solid subtractions" on the worksheets. Normally I use the "framing member tool" to get those dimensions correctly, but in this case I've to make an extra operation because the notch. I've tried to convert them in other kind of objects like "generic solid", or "extrude along path" without success, I suppose there may be a formula or something that allows me to get the dimensions I need. Thanks!
  7. Hi there, I have a problem with the linked texts inside the symbol blocks. When I see them in any type of 3D visualization even in wireframe, I can see all the information pulled from the record without any problem, but when I try to visualize the symbol not in plan view, with the hidden line mode on, all those data disappear. Anyone knows how can I do to show the linked information inside the symbol block even in hidden line mode? Thanks
