JF_P
    6
Everything posted by JF_P
  1. I found the problem. Schematic views are ceating this bug. To fix the bug you need to have the schematic view in a closed design layer. Do you think this can be fixed ? I have schematic view in all my drawings for vertical position. Thanks
  2. It doesn't work either. I've tryed to make a new file with a few lighting fixtures and it works perfectly. What in a drawing could cause this ? Thanks
  3. I can't get my instrument to show in the focused positon in vectorworks to Vision. I've send to vision from the file drop down menu. In the user manual: A conventional lighting device is a non-moving lighting device. If the conventional lighting devices are focused in Vectorworks prior to import, they are automatically focused in Vision. Otherwise, these lights need to be manually adjusted so they point to the desired location. Everyhting is focused in vectoworks what i am doing wrong ? Thanks JF
  4. Hi, Is it possible to update Robert Juliat Library ? Some of the fixture do not look like the real fixtures ? In 3d the render is awful. Here is some picture you can compare Thanks JF
  5. Can you had in the OIP the option of a scroll bar for the zoom. like in WYSYWYG. You already have the option in a light for rendering purpose Would be very appreciated JF
  6. Hello, Is it possible to had the option of soft goods insertion point like for the lighting position ? Thanks JF
