Hello Tom,
Thank you for the response. Yes, I am using 2021.
However, I'm not looking to use any of the three variations of "System Check...".
I am wanting to add a key command to "Select System Objects" (highlighted below), if one isn't available already.
You did point out that the "Select System Objects" command is available in the right click menu, so that helps out a little bit. Thank you for that.
I'd still like to have a key command so I can click on a piece of truss, type the command, and instantly have the connected objects of that particular rigging system highlighted, and ready for calculations.
From what I can tell, "Select System Objects" is not available in the Braceworks workspace editor... unless it's hidden somewhere unexpected?
Thank you
