971 -
Posts posted by zeno
In a single wall this beam makes 4 mq difference. 4 mq means 120 euros. This is a single wall for a single stories for a single tower. I think is something like 10x floor so 1200 per floor. The entire project is 12 floors per tower so 14.400 euros x means 43.200 euros.
So, yes, it's very important for me to have the right control for this paramethers, thank you.
22 hours ago, Pat Stanford said:
yes, that was the problem. Another problem is that if you insert a symbol into a wall without Breaks, the component quantities are the same as the wall without the simbol so I need to add also a wall in feature.. and repeat this process for every beam. That's insane..
- 2
hello
I'm working on a new BIM model.
I need to set everything precisely and need to put a beam into a wall to generate a correct material worksheet quantity report
My goal is to put the beam into the wall like a simbol but if I convert a structural element into a symbol it becomes like a parametric element and I can't put it into the wall
How can I solve this problem?
- 1
15 minutes ago, Stephan Moenninghoff said:
Thanks
Hello
I'm trying to apply a macro inside a handle to replicate the model of the video on interiorcad 2021. The macro works correctly. I tried to create a symbol converted into a group after inserting a 3D object to which I applied a subtraction created from the same symbol with which I customized the macro. If I insert the handle, the door is not drilled, but if I apply the same macro inserted in the handle group, the door is drilled. Am I doing something wrong?
8 hours ago, Stephan Moenninghoff said:
Marionette placement appears to be broken in the 2021 cabinet. Thanks for the report, I have filed a bug.
You're welcome Stephan.
14 hours ago, Stephan Moenninghoff said:
You need to check "Ridimensiona oggetto" and then make it stretch. You don't need to use a Marionette any more for this, did you know? You can use two rod bearings (as blue symbols) and an extrude (also a blue symbol) and interiorcad will reshape the extrude to fit the width. No clothes and no clothes hangers (yet), obviously...
Yes, the "object mode" you explain on the video works well. And I know that I need to check "ridimensiona oggetto" but the problem is that I don't see the specific selected marionette object. If I select the Clothes Rail, it doesn't appear on my cabinet.
Symbol method is done.
Thanks a lot Stephan
Hello @Stephan Moenninghoff
could you please let me why the Clothes Rail doesn't appear on this cabinet?
Thanks 🙂
On 2/19/2021 at 5:16 PM, zoomer said:
I always get purple screen - crash - reboot
when try in to change render quality in Twinmotion
The purple windows problem can be fixed by disable this option on general panel on system settingshttps://www.reddit.com/r/macbookpro/comments/kgj0n1/purple_backdrop_issues_on_macbook_pro_m1/
2 hours ago, zoomer said:
But how did you migrate exactly ?
At first I tried Mac to Mac, second Time from time machine backup to Mac, problem with 2 users, no administrator. 3rd time one more time with time machine, problem with dropbox and purple screen. Every time formatting everything
last time i switched to be an apple betatester 😄
I have all documents on dropbox. Then set the mails one by one, than installing software one by one, driver one by one
Today finally I find a good way
- 1
By the way..
MBP is connected with usb c cable to a LG 27’ 4k. Absolutely fine.
If the MBP is open and it is connected with the 4k monitor, navigation experience throug heavy vw files in Open GL are better on my imac 2017 with 8 gb gpu, but using only the 4k monitor it looks the same, for now.
If you switch to M1, absolutely ABSOLUTELY do not trasfer directly data from intel mac or using time machine. It’s a disaster: 8 hour on phone with apple and dropbox support, finally resolved ONLY with a new clean installation.
But yes, i think M1 is the way, quicker than we can imagine..
have a cadmouse and spacenavigator, both from 3d connexion, no issue for now
On 2/13/2021 at 8:19 PM, Paul Johnson said:
Hi. I am a garden designer who has previously used AutoCAD for technical drawing output and Sketchup for 3D presentations. I am hoping to use Vectorworks landmark for both and I thought that was the whole point of the software. Why is it then that you have to assign a scale to draw in workspace and not when you output. I may wish to have a plan in 1:50 and some details in 1:20 and also use the same drawing for a 3D visual. How can I possibly know what to draw in before I start? Do I have to re draw the whole thing for each drawing?! Im sure this can not be the case.
Garden designer using Autocad?
OMG welcome to the new life! -
12 hours ago, Kevin Allen said:
Don't the lines represent cables? Can you take one piece of truss and rigging, put in a document and post?
Here is it
The main class is Bridle Main. Then are also:
Rigging-Bridle-Connection= connections
Rigging-Bridle-Geometry= what I need in gray
Rigging-Bridle-Label= label if exist
You can hide the last 3. If you hide the first one the entire object disappear.
If you set the first class to show, you alway see lines, even if the planar object on viewport is set to off
Yes, i know the process. But lines are connected to the main class object. If you turn off the main class, 3d geometry and lines are turned off -even if classe are visibile-. You can turn off the 3d geometry but you can’t turn off the lines. So in this way i need to hide the entire object but i need to hide only lines.. that’s my issue..
4 minutes ago, Kevin Allen said:
Perhaps they need their own class?
Own class seems to show those lines.. as I understand..
34 minutes ago, Kevin Allen said:
don't the bridle lines, by default, have their own class? Turn that off in the Viewport.
Yes, but the lines are controlled by the main class. If you set it to invisible, you can't see the 3d geometry. If you turn off the geometry, you see only the main class with lines.
Hi
VW allows user to put several color codes for lights directly into OIP. Where can I find a list?
Thanks
Good morning. I would like to ask if this procedure is correct: I want to connect some lights to a sloped truss. In top / plan view they seems connected correctly, but in 3d it is not verified. Does this mean that you have to redo the connections twice? If you redistribute the lights from top view the connections are not easily controllable.
How should you proceed correctly? Thanks
@str you are not alone! :-)
- 3
6 minutes ago, Tamsin Slatter said:
On the Space Settings, click Advanced Settings. Here, you can choose which properties you wish to have available on the Object Info palette.
Yes, but I'm not sure that users can see directly multiple object's area (sum of..) on OIP, like on STR's example.
- 2
Adding a Beam into a Wall
in Architecture
Posted
It would be great if I have only 1 type beam. But this is not the case. I need to put into walls several beams with different dimensions. Symbol in a wall is a good workflow, but the problem is the quantities. I can't create a "hole" inside the wall.
